Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 01-16-2008, 06:35 PM   #1
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Default Enginuity Logger Dashboard
Heya,
Quick question, is there an easy way of moving the gauges in the Enginuity Logger Dashboard to their own window so the gauges are all that are visible?
Also, are there skining options or do I need to go into the source and create my own gauges from scratch and recompile?
I'm basically looking to use Enginuity Logger's gauges as virtual gauges on a CarPC.
If Enginuity can not do it easy, does anyone know of some open source skiniable virtual gauge software?
Cheers.
wrxsti.l is offline   Reply With Quote
Old 01-16-2008, 07:14 PM   #2
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
iirc they're using a premade widget for the dash and graphs, their sources might be listed in the about pages, check ecuflash also.
ExpO is offline   Reply With Quote
Old 01-16-2008, 07:35 PM   #3
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
cheers for that. I have downloaded the source for enginuity and I will look through and try and modify the widgets.
I also want to be able to display the widgets external to the logger in their own window, so it might take a bit of time.
I will check out ecuflash tonight also.
fyi, what I am after is something similar to the PCMSCAN DashXL without the cost so I can then embed the gauges into my carpc :P
basic PCMSCAN vistual gauge set:
Old 01-16-2008, 11:19 PM   #4
kascade
Member#: 124395
i'd rather you just create a new car pc specific tab instead of modifying the existing one.
kascade is offline   Reply With Quote
Old 01-17-2008, 01:23 AM   #5
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I have no probs creating a menu link in RoadRunner for the Enginuity Logger - but I only want to embed the virtual gauges from the dashboard view (skinned) and not the compete enginuity logger.
Kascade, if you have a moment, could you have a quick squiz HERE and let me know if I can do similar with the gauges in the Enginuity Logger.
If not, do you think it could be implemented without too much fuss - or would it take too much time to rewrite the parts to be able to do this?
Thanks for your advice.
Old 01-17-2008, 10:29 AM   #6
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
how are you getting the new dashboard...mine still runs the old digital type....and I;m running the new 785 version. I still have the beta version, could it be pulling the dash board settings from that? I do have the MAF tool though.
Wheeler Bement is offline   Reply With Quote
Enginuity logger sample rate cooter Commercial ECU Reflashes 1 12-07-2007 09:21 PM
NEED HELP with enginuity logger! saab-on-the-cobb Commercial ECU Reflashes 2 11-15-2007 03:40 PM
Enginuity Logger Defs - Quick Help GuiltySparc Commercial ECU Reflashes 2 10-20-2007 11:23 AM
Enginuity data logger questions equinsu ocha 07 Texas Impreza Club Forum -- TXIC 3 09-26-2007 12:14 PM
Enginuity Logger Freezing bdon22 Commercial ECU Reflashes 3 08-16-2007 02:06 PM
