Old 01-17-2008, 09:34 AM   #1
kiwee
Member#: 119232
Default noob q: possible to switch ecutek maps using opensource?
new to this, but i am wondering if you can upload different tunes created by ecutek using the tactrix cable, laptop and some form of opensouce tuning?
IE, 2 tunes, 1 for race gas and 1 for 94?
kiwee is offline   Reply With Quote
Old 01-17-2008, 02:24 PM   #2
Gethin
Member#: 2998
No you can't.
Also once your ECU has a ECUTEK reflash on there only a ECUTEK dealer can modify it.
Gethin is offline   Reply With Quote
Old 01-17-2008, 04:37 PM   #3
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Wrong.
People have had success with reading the maps, so you could get the roms and just flash them. I have no idea how, and don't care to figure it out.
Also, you can overwrite the ecutek and lockout in SHbootmode.
ExpO is offline   Reply With Quote
Old 01-17-2008, 04:39 PM   #4
Gethin
Member#: 2998
Care to explain how you get access to a locked out ECUTEK ecu using open source tools? And how you can write the ECUTEC maps using the tactrix cable?.......hmmm you can't.....
Old 01-17-2008, 04:42 PM   #5
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Whatever you say bro
Old 01-17-2008, 04:43 PM   #6
Gethin
Member#: 2998
Got anything worthwhile to add to this post? Or can u answer the OP's question?
Old 01-17-2008, 04:48 PM   #7
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Speak for yourself, Mrs. Information.
http://forums.openecu.org/viewtopic.php?t=3095
Canadians....
Old 01-17-2008, 04:54 PM   #8
Gethin
Member#: 2998
I've yet to see the ECUTEK lockout removed sucessfully using this method.
And the OP is hardly going to disassemble his ECU and start soldering wires to switch maps now is he? And again answering the OP's question, no he can't write ECUTEC maps to the ECU using the tactrix cable.
BTW i'm British not Canadian.
Old 01-17-2008, 05:27 PM   #9
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Are you saying you've seen people try shbootmode and fail, or just talking out your ass?
If he wants to get rid of that ecutek garbage without selling two arms and a leg, he probably will.
People have pulled ecutek maps, go read the thread. I doubt you yourself have been able to pull one and attempt to flash it, so you have no clue if that works or not. Even so, pulling the map and manually copying the tuned tables into enginuity or ecuflash would asolutely work.
OP, if you want your maps, I suggest reading the thread and sending a few pm's.
The short answer is no, but if you really need other maps, there ARE ways around it.
Old 01-17-2008, 05:37 PM   #10
Gethin
Member#: 2998
I'm saying that i haven't seen the shboot mode work. I can't find a post from anyone who says that it works, only it "should" work. Even then it's a method of flashing the original stock ROM back onto the ECU. That won't help the OP.
As far as I know ECUTEK scramble their BIN files and there is no opensource method of opening and flashing it onto the ROM.
The OP is more than welcome to build his own TTL interface and attempt to flash a stock ROM onto his ECU. But that wont help him swap ECUTEK maps will it? Besides, the shboot mode will only write to the ECU.
I have sucessfully "pulled" ECUTEC maps, before they changed their flashing methods and lockedout the ECU.
Old 01-17-2008, 08:15 PM   #11
Karl S.
Member#: 30871
Yes, EcuTeK scrambles the bins when it is in EcuTeK software, and when it is saved on a HD, but when it is in the ECU, it is not scrambled. And yes you can read a EcuTeK locked ECU. No need for SHbootmode, just need to have the correct software and program away through OBDII connector, just like any stock ECU
Karl S. is offline   Reply With Quote
Old 01-17-2008, 08:22 PM   #12
benw
Member#: 103320
1998 swapped
Forester L
what correct software would this be?
I couldn't do a damn thing with my ECU when it had EcuTek.
benw is offline   Reply With Quote
Old 01-17-2008, 10:43 PM   #13
Gethin
Member#: 2998
Yes please do tell The OP wants to be able to swap ECUTEK maps with his tactrix cable.....
Old 01-18-2008, 12:48 AM   #14
Remnex
Member#: 83790
Have you considered borrowing someone's AP2, marry it to your car, flash a map, and then unmarry it? It should revert the ECU back to stock.
Remnex is offline   Reply With Quote
Old 01-18-2008, 01:57 AM   #15
Karl S.
Member#: 30871
benw,
ah... the correct software, it's proprietery for now (as in not for public), sorry.
Old 01-18-2008, 09:41 PM   #16
HellBinder
Member#: 132385
94 RHD Legacy
w/wrx swap. White
I just reflashed my ecutek tune with a tactrix cable yesterday. easy squeezy.
Anybody want to buy a protune for a (sti short block, fmic, perrin up and dp, and vf43)?
J/k.
HellBinder is offline   Reply With Quote
Is it possible to switch a townhouse from electric to gas? Snoopy Off-Topic 19 01-13-2008 10:08 PM
Is it possible to remove ECUTEK? leonbmx Engine Management & Tuning 20 04-05-2007 02:53 PM
Is it possible to switch front seats left <-> right ? il96 Interior & Exterior Modification 5 01-22-2003 12:46 PM
Possible to switch from synthetic back to dino oil? jotarou1 Bay Area Impreza Club Forum -- BAIC 3 10-10-2002 04:37 PM
possible to switch the MY02 wrx to RWD? n2oFEIN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-12-2001 11:46 AM
