Old 01-17-2008, 11:57 AM   #1
WRB_in_my_veins
Member#: 66540
2004 WRX Sedan
2005 Legacy GT wagon
Default Port & Polish Question on Stock Header
Question for any (self proclaimed) port/polish gurus. I am planning on dropping my stock header off to at least gasket match it and smooth out the openings.
1. Is it going to do anything for me without p/p the exhaust outlet of the heads?
2. Is it worth the time to do the header if I donít pull the uppipe out and do it too?
If you canít already tell: I REAAAALLLLY donít want to pull the uppipe out. I hated that job the first time. I swapped in a gutted stocker about a year ago, and I don't really want to go through the process of getting it out again.
WRB_in_my_veins is offline   Reply With Quote
Old 01-17-2008, 12:10 PM   #2
sti25impreza
Member#: 134937
2005 WRX STG 2
Miata MX-5
the up will be a bottle neck if you dont to that also, how much of one i have no idea.
if you want to get the most out of p&p you should do everything...collectors, crossover pipe, up pipe, and turbo.
sti25impreza is offline   Reply With Quote
Old 01-18-2008, 11:17 AM   #3
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Check out Grimmspeed, they have a PnP offer on everything you need, and also have options to avoid any down time if you don't have another car. All you do is pay the core charge and send them your OEM's back, then you get the money back.
I'm planning to do this in the spring with my exhaust manifold, intake manifold, up-pipe, turbo, x-over pipe......and get them all with the thermal coating and new gaskets. Check out their website.
REXtard04 is offline   Reply With Quote
Old 01-18-2008, 11:51 AM   #4
WRB_in_my_veins
Member#: 66540
2004 WRX Sedan
I don't really want to go with the Grimmspeed deal. Don't get me wrong, they have quality packages out there but I've got a 33 gal. air compressor, some carbide bits, and a car that's parked in the garage until April or so. Winter beater FTW! I have no intention of p&p the turbo, forget that. I just don't care that much. What I'm looking for is a free power adder/spool time decrease.
I guess some input from people that have p&p the entire stock header would be appreciated. Did you take much off the uppipe at all? Are the collectors and crossover the areas for biggest improvement or are all the parts essentially equal in their need of p&p?
Old 01-18-2008, 12:25 PM   #5
TurbojonLS
Member#: 38772
2 Cars, No Bling
Did you put your EGT probe back into the uppipe? Without it, it comes out much easier.
Also, since you're pulling the passenger's-side manifold, you at least need to loosen the uppipe-turbo connection a lot. The manifold-uppipe connection is the one that's most prone to leaking, so its the one you tighten first.
I guess what I'm saying is that if you're taking the time to do this anyway, take a little more time and do it right.
TurbojonLS is offline   Reply With Quote
Old 01-18-2008, 12:32 PM   #6
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
If you port and polish just the stock exhaust manifold and go to a stock up pipe your up pipe will bottle neck your exhaust like said above. Since you have no downtime and wont be driving your car till april you might as well do it.
Josh
GrimmSpeed is offline   Reply With Quote
port & polish stock headers Bluefoton Normally Aspirated Powertrain 12 04-29-2008 09:06 PM
Went a little crazy on Port & Polish turbo, throttle body, TGV delete cky211 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 07-23-2007 08:27 AM
Headers, Port & Polish or Neither silver06wrx Newbies & FAQs 35 04-27-2007 01:19 PM
Stock Intercooler Elbows - Ready for port & polish! drees Private 'For Sale' Classifieds 1 05-31-2005 11:57 AM
I want to port & polish a stock wrx turbo myself any tips? cky211 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-13-2004 12:50 PM
