Old 02-02-2002, 02:58 PM   #1
YeeHa
Member#: 8884
2002 WRX Sedan
Default How Do You change the PArking light bulbs?
I did a search and couldn't find anything. Do you have to remove the whole headlight assembly or can you just remove the bulb and put a new one in. The sidemarkers were easy as wel as the turn signal, but I can't get that dang bulb out.
Thanks,
Todd
YeeHa is offline   Reply With Quote
Old 02-02-2002, 06:33 PM   #2
WRX4me
Member#: 4107
I remember changing mine out a while back, double check the manual, I think you have to take the headlight out. Take the grill off, then the 2 side trim pieces, then there are a few bolts holding the headlight in place. Should only take about 10 minutes to do. It should all be in the manual.
WRX4me is offline   Reply With Quote
Old 02-02-2002, 08:19 PM   #3
mywrx2002
Member#: 4613
2002 wrx sedan
SRP
Default yep
wrx4me has got it. Take grill out, if changing both bulbs(one each side) take little incerts out between headlamp and grill, then remove headlamp assembly
mywrx2002 is offline   Reply With Quote
Old 02-02-2002, 09:50 PM   #4
YeeHa
Member#: 8884
2002 WRX Sedan
Thanks guys I'll do it in the morning.
Old 02-03-2002, 04:05 AM   #5
V REX
Member#: 11102
02 WRX,05STi sold
B5 WB Nogaro S4
Does anyone know the bulb numbers for the parking light and blinker bulbs. I remember a thread a while back saying they were 1156 but you had to grind of one of the nubs for it to fit.
Thanks
V REX is offline   Reply With Quote
Old 02-03-2002, 06:06 AM   #6
nqwan
Member#: 2916
02 duburu arr exu
Thanks
grinding the nubs was for the phillips silvervision bulb. so far, the only way to get them is to order them from places outside the us and they seem to have a different pin arrangement then ours, which is straight across from eachother as opposed to the slightly offset ones that the silvervisions have.
nqwan is offline   Reply With Quote
How the hell do you change the rear defroster light? obyone Interior & Exterior Modification 6 05-07-2007 05:58 AM
How do you change the color of the displays ksskateboard Interior & Exterior Modification 4 03-20-2005 02:36 PM
How do you change the fog light? Lagwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-03-2005 10:25 PM
How do you change the fog liht bulbs on a 04 wrx? eshtog Interior & Exterior Modification 2 07-23-2004 11:51 PM
04 REX how do you change the fog lights? kitbar Interior & Exterior Modification 2 04-13-2004 12:38 AM
