Old 01-17-2008, 12:08 PM   #1
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Default Enginuity and LC1 Logging
It is to my understanding that there was a special version of Enginuity released with datalogging capabilities to support the LC1 wbo2.
Where can I find this? I am tuning an LC1 equipped wrx tomorrow.
Thanks guys.
akira02rex is offline   Reply With Quote
Old 01-17-2008, 12:28 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
http://www.ken-gilbert.com/wrx/engin...ase-rev774.zip
-unzip into a folder and run logger.bat
-select com port for Tactrix cable
-select com port for LC-1 (serial-USB adapter)
you'll have to "check" and "uncheck" LC-1 from the list once before it would show data.
Airboy is offline   Reply With Quote
Old 01-17-2008, 12:31 PM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Thank you!
Old 01-17-2008, 02:58 PM   #4
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
kascade posted version 785 here
http://www.assembla.com/spaces/engin...lDkbG/download
The above link is from the source code thread:
http://forums.nasioc.com/forums/show....php?t=1424878
It appears to have AEM and UTEC added as logging options as well.
mickeyd2005 is offline   Reply With Quote
Old 01-17-2008, 05:03 PM   #5
XJDave
Member#: 142173
Spectra Blue
Post
I just tried connecting to my LC-1 with ver. 785 with no luck. I had been using ver. 774 and had no problems. I am going to dl 774 again and will update if I still have a problem or not. Logworks2 is picking up my WB, so I know I don't have some sort of electrical problem.
I re-dowloaded 774 and 785, and in both programs all I had to do is go to the plugins pull down menu, click on LC-1 and reselect the proper com port for it to work in both programs.
Im still not quite sure why 785 did not work before I re-installed.
XJDave is offline   Reply With Quote
RR Logging and LC1 Help 06hwrx Open Source Reflashes 3 12-05-2008 09:01 PM
Help With Enginuity And Lc1 Logging stretchedk7 Open Source Reflashes 3 09-23-2008 01:13 AM
Enginuity and the LM-1 rebizap Commercial ECU Reflashes 2 11-19-2007 02:42 AM
enginuity - how to log LC-1 dynamix Commercial ECU Reflashes 5 11-17-2007 02:39 PM
Logging '07 STI with Enginuity and a VAGCOM cable l0pl0p Commercial ECU Reflashes 15 09-11-2007 07:03 PM
