Old 01-17-2008, 04:27 PM   #1
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
Default Perrin EL header fitment on 06 WRX- Help from those that made it fit...
Have a 2006 WRX. Have a Perrin EL header. Won't fit....
The oil cooler is angled due to the presence of a metal, wedged sandwich adapter between the block and oil cooler, tilting the filter about 15 degrees and causing it to contact the header. Apparently, this is ONLY present on SOME 2006 and 2007 WRX models, NOT STi. And, to make things worse, only SOME of the 2006 and 2007 WRXs have this - WTF, Subaru?
Anyway, you can't rotate the sandwich plate due to its asymmetry. You can't remove the sandwich adapter and directly bolt the oil cooler to the block because the block is not threaded (the threads for the 23mm center bolt are in the sandwich adapter which is held to the block by 6 10mm screws).
I was advised that an older model WRX or any STi oil cooler will work. I bought one, but it won't bolt directly to the block because there are no threads in the block (again, the threads for the 23mm center bolt are in the sandwich plate).
Will someone PLEASE tell me how they got their's to work? Is there some crucial part I'm missing here, like some type of adapter plate???
phlegmon is offline   Reply With Quote
Old 01-17-2008, 04:47 PM   #2
PERRIN
NASIOC Manufacturer
Member#: 6776
PERRIN is offline   Reply With Quote
Old 01-17-2008, 05:25 PM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
Hey click HERE! then on compatibility. Has a diagram!
adam
Old 01-17-2008, 05:50 PM   #4
novacivic
Member#: 117980
2005 sti
wr blue
remove the sandwich plate and just bend the metal lines coming off of it a little to clear the block and timing covers
novacivic is offline   Reply With Quote
Old 01-17-2008, 05:58 PM   #5
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 01-17-2008, 08:24 PM   #6
MattPersman
Member#: 139385
it took me more than a few moments on how to figure it out. if you remove and reuse the correct parts it will work. but primarily I think you remove the parts Perrin said but you do not have to buy anything else. I didn't anyways. it was a combination of removing and reusing that I got it to work. still going strong. lemme take a picture maybe it can help. picture coming up in a few minutes
MattPersman is offline   Reply With Quote
Old 01-17-2008, 09:19 PM   #7
MattPersman
Member#: 139385
here are some pictures (thumbnails click for larger images) I took from the floor with my camera jammed under the bottom of the car I do remember now getting some bulk heater hose to replace the hose that came from the factory as it was too short with the modified set up and position of the parts.
here is what I removed from the factory set up
hope this helps some people.
Old 11-20-2010, 02:48 AM   #9
JKLNHYD
Member#: 255772
gotta bring this back from the dead.
has anyone else removed that piece and can anyone else confirm that nothing but hose is needed to put the oil cooler on the block without that extra piece.
JKLNHYD is offline   Reply With Quote
Old 11-20-2010, 09:40 AM   #10
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I have a 2006 wrx and am also wanting to but these headers come tax season. Does this issue exist with every single 06-07 wrx?
07ImprezaMB is offline   Reply With Quote
I need some help from those that know TVs please. Badmunky Off-Topic 21 09-10-2009 06:28 PM
Need Help From Those That Know Honda Ghomer1 Mid Atlantic Impreza Club -- MAIC 9 12-08-2008 12:10 PM
Nautilus Run, for those that made it down last time, and anyone else of course THE-95-STi Tri-State Area Forum 10 06-15-2007 01:06 AM
*searched* Want to fit 04 sti cluster on 06 wrx. Help ? WRick Electrical & Lighting 29 09-12-2006 11:50 AM
Need help from those that have JDM STi front lip Spec C Wannabe Interior & Exterior Modification 11 03-21-2005 09:29 PM
