Old 01-18-2008, 09:54 AM   #1
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Default IAM and recognising knock from log data
How do you guys generally tell if your baby is knocking apart from sound /feel - i.e. logs, IAM? comparing your timing tables to logged timing?
Just trying to understand a bit at a time.
The logs are getting more interesting all the time!
Thanks guys
Kastley85891 is offline   Reply With Quote
Old 01-18-2008, 10:03 AM   #2
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
FBKC and FLKC. You have to know how much timing the ECU pulls during a knock event however.
Example 07 STI:
Step vlue for both FLKC and FBKC is -1.4 degrees.
When in Coarse Correction mode FBKC is active and FLKC is disabled:
If the ECU detects one knock event, it pulls 1.4 degrees and then there is a delay and timing steps up in .35 degree increments if there is not knock. If it continues to knock, it will pull in 1.4 degree steps up to -11*. This is instantaneous response to a knock event(s) that just occured.
When in Fine Correction mode FLKC is active and FBKC is disabled:
FLKC may already be negative, so this is more than likely learned timing and the ECU is not knocking. If there was no FLKC in that RPM/Load zone before and you get a -1.4, then the ECU just knocked. The step value for learning to add timimg back in is the same as FBKC (.35*). Also note that if your IAM is not at 1, you may have positive FLKC. This means that the ECU has learned to add in timing to try and achieve full power.
So in short, you have to factor all of this in. I answer many questions about logs where people think their car is knocking when it really isn't as they do not understand how to interpret the logs.
Gabe
gabedude is offline   Reply With Quote
Old 01-18-2008, 10:46 AM   #3
Tea cups
Member#: 103136
FBKC is not disabled when in either rough or fine correction "mode". The modes do not indicate that a change is being made to the IAM (rough) or the current FLKC cell, but rather if the conditions are met, which of these the ECU is poised to make changes to. One of the conditions is the FBKC is disabled for which this is determined separately from the mode selection. That is, FBKC can be disabled and no changes are made to the IAM or the current FLKC cell (although a number of conditions have to all be true is order to disable FLKC). Basically, it is best to think of these three elements of knock control (changes to the IAM, FBKC, changes to current FLKC) as three distinct controls that never overlap in their execution.
To the OP, to determine close to all instances of perceived knock (within the ranges set by your tune), you would need to use Enginuity's logger with the latest definitions and log the following:
1. Feeback knock correction (FBKC)
2. Fine learning knock correction (FLKC)
3. IAM (Ignition advance multiplier)
as gabe said, FLKC could be due to past knock unless the current cell is changing. You can determine this by logging 'Fine Learning Table Offset'. If this value remains the same but your FLKC changes then there was a change to the current FLKC cell (barring any "sync" issues which can occur due to the way the ECU polls the parameters).
Tea cups is offline   Reply With Quote
Old 01-18-2008, 10:48 AM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Thanks Gabe for that response - very helpfull - I wanted to try and understand more as my DTEC knock indicator is pulsing between the 5-6500 rpm range although I coul dnot see knock in the logs, assumed it was a false signal etc, I have your email so will forward a single log if that is ok?, a quick view from you may put my mind at rest at least until I understand more.
Cheers
Example 07 STI:
Gabe
Old 01-18-2008, 10:51 AM   #5
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Thanks Tea cups
Appreciated
Old 01-18-2008, 12:49 PM   #6
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Are the FBKC and FLKC named the same on older models.
Not-EWRX is offline   Reply With Quote
Old 01-18-2008, 12:52 PM   #7
gabedude
Member#: 10108
07 STI
I hate it when my memory fails me and I don't have one of your stickies to reference.
Old 01-18-2008, 12:53 PM   #8
gabedude
Member#: 10108
07 STI
With the latest logging defs, yes.
Old 01-18-2008, 01:55 PM   #9
Tea cups
Member#: 103136
Some of the FBKC disable stuff was not in the last sticky. I've been waiting for Enginuity to come back up before updating it, but that might be awhile so maybe I'll post it up here some time.
Old 01-18-2008, 02:03 PM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
Why not just correct/update the existing Scoobypedia article at http://www.scoobypedia.co.uk/index.p...ategyExplained?
Jon [in CT] is offline   Reply With Quote
Old 01-18-2008, 02:11 PM   #11
gabedude
Member#: 10108
07 STI
Ahh, so my memory is still working. I hate getting old.
Old 01-18-2008, 02:19 PM   #12
Tea cups
Member#: 103136
Well, I can update that too (it doesn't have even the last update it looks like), but I think it would be best to add separate threads to the new Nasioc sub-forum as this is where it seems the technical openecu discussion has migrated to (from Enginuity).
Old 03-24-2008, 11:30 AM   #13
cowtown
Member#: 68435
'07 STI
Question
Hi, I'm resurrecting this thread to get some clarification on actual knock when logging FLKC.
So this is not necessarily current knock, but a learned response to past knock?
Code:
Time	RPM	FBKC	FLKC	FLTO	IAM	THROTTLE
38:44.3	2628	0	0	6	1	17.25
38:44.7	2666	0	0	7	1	19.61
38:45.0	2703	0	-1.05	8	1	29.8
38:45.4	2678	0	-1.05	8	1	30.98
38:45.7	2779	0	0	9	1	28.63
38:46.0	2735	0	0	9	1	30.98
And this is current knock?
Code:
38:06.4	2629	0	0	8	1	21.96
38:06.7	2674	0	0	8	1	21.96
38:07.0	2697	0	0	8	1	21.57
38:07.4	2737	0	-1.4	8	1	21.57
38:07.7	2776	0	-1.4	8	1	21.57
38:08.0	2764	0	-1.4	8	1	21.57
cowtown is offline   Reply With Quote
Old 03-24-2008, 12:02 PM   #14
Tea cups
Member#: 103136
Code:
Yes, this is a learned correction in the past.
Code:
Yes, this is current knock that is now a learned correction.
Assuming I'm reading these correctly, should I be trying to tune out all high-load current-knock FLKC for a very conservative daily-driver tune?
You need to also look at FBKC and the IAM to get a complete picture - only one is active at any given time. What you need to do is look for patterns. Every time you flash a change to your map (for almost all ECUs), the ECU is reset and the FLKC table is cleared. So, if you see the same negative correction consistently in a particular cell (after FLKC table is populated), especially at moderate/high loads, then that is something you would want to take a look at and do further logging to determine where the issue may lie (timing, fueling, tip-in enrich, etc.). Note, that the FLKC table is cleared every time the IAM changes, so if your IAM isn't stable, obviously the FLKC data isn't going to very useful.
Looking at the FLKC table only is not a substitute for normal logging as it will not indicate knock handled by the other knock control elements - FBKC and the IAM. Also, the FLKC ranges are sometimes quite broad so you need additional logging to narrow down where and under what circumstances the perceived knock is occuring. And it should be noted that the knock sensor/filter/ECU logic is not perfect at determining knock. You will never completely eliminate all negative corrections from FLKC or FBKC. If you want to look at the entire FLKC table at once, DL the learning view tool on RomRaider.
Old 03-24-2008, 12:49 PM   #15
cowtown
Member#: 68435
'07 STI
Thanks very much Tea cups, that makes sense.
I was having a difficult time getting my head around the FLKC because of the offset table.
Thanks!
Old 03-25-2008, 05:48 AM   #16
benw
Member#: 103320
1998 swapped
Forester L
Excellent info as usual by Bill and Gabe. In my experience, I have always had better luck when resetting the ECU before logging, to clear the FLKC tables. The learning view tool is great when friends stop by for a checkup, as it indicates any possible spots the car is knocking when subjected to the rigors of the owner's daily driving style. 15 minutes of around town logging with MickeyD's knock summary sheet usually reveals all trouble spots.
When the ECU is reset, doing some 2000-redline pulls will reveal all knock (in my experience). Some cars don't reset their learned knock when a map is flashed, so I manually reset those to be safe (using the RomRaider test release).
benw is offline   Reply With Quote
Old 03-30-2008, 10:48 AM   #17
TrRex06
Member#: 170472
2006 WRX TR
Default Help me diagnose
Sorry to threadjack, but could someone help me diagnose this log. Its not bad, but it is very consistat, so I would like to get it dialed out. Timing is already pretty conservitive, and I don't think fuel is to lean, So before I go pulling anymore timeing or anything else I would like to get some other peoples feedback.
Code:
Time   Accel(%)	N/A     Load 	(rpm)  FBKC   FLKC    IAM 	Timing	N/A	IAT	KC	 MRP	 N/A 	WGDC	AEM UEGO (AFR)
57906	21.96	4.08	1.08	2292	0	0	1	27.5	10.74	82	2.5	-2.18	1.68	7.45	14.7
58266	21.57	3.78	1.12	2290	0	0	1	26	11.21	82	2.5	-1.89	1.71	7.06	14.4
58625	20.78	3.48	1.14	2298	0	0	1	25.5	11.28	82	2.5	-1.74	1.67	7.06	14.6
58969	28.24	3.41	1.19	2286	0	0	1	24.5	11.78	82	3	-1.02	2.13	8.63	14.8
59313	30.2	2.51	1.27	2308	0	0	1	20	12.8	82	3.5	-0.15	2.23	10.59	14.6
59672	32.55	2.07	1.41	2300	0	0	1	18	15.71	82	6	1.31	3.08	13.33	14.1
60016	38.82	0.71	1.6	2334	0	0	1	14.5	19.37	82	6	3.19	3.72	16.08	12.5
60391	45.49	0.31	1.72	2328	0	0	1	13	21.31	82	6	4.5	4.69	16.86	11.5
60734	55.69	0.33	1.84	2356	0	0	1	12.5	22.78	84	6	5.8	7.22	23.53	11.3
61109	55.69	0.77	1.94	2383	0	0	1	12.5	24.36	84	6	6.96	7.5	33.73	11.2
61453	55.69	0.11	2.02	2392	0	0	1	12	25.68	84	6	7.84	7.85	34.9	11.2
61813	55.29	-0.63	2.08	2427	0	0	1	11.5	26.97	84	6	8.71	8.04	31.37	11.2
62156	54.9	-1.22	2.13	2446	0	0	1	11	27.96	84	6	9.58	8.08	27.45	11.1
62516	54.9	-1.58	2.16	2460	0	0	1	11	28.82	84	6	10.16	8.25	19.22	11.2
62875	52.55	-2.38	2.17	2489	0	0	1	11	30	86	6	10.45	7.99	7.06	11.1
63219	52.55	-1.32	2.02	2522	-1.4	0	1	10.5	26.37	86	4.5	9.72	8.3	3.53	11.5
63578	52.55	-0.92	2.06	2560	-1.4	0	1	10.5	27.88	86	4.5	9.43	8.66	1.57	11.9
63922	52.16	-0.56	2.07	2586	-1.4	0	1	10.5	28.2	86	4.5	9.43	8.73	0.39	11.8
64344	51.37	-0.52	2.07	2606	-1.05	0	1	11	28.91	88	5	9.43	8.59	0	11.6
64703	47.84	-1.35	2.06	2609	-1.05	0	1	11	29.46	88	5	9.29	7.3	0	11.7
65063	43.14	-1.8	2.04	2661	-1.05	0	1	11	29.38	88	5	9	6.79	0	11.6
65422	32.55	-2.35	1.9	2676	0	0	1	13	26.66	88	6	7.55	4.22	0	11.4
65781	10.59	0.76	1.05	2663	0	0	1	23	11.49	90	2.5	-1.02	0.58	0	11.8
66141	0	9.53	0.04	2661	0	0	1	44.5	2.8	90	0	-9.72	0.01	0	14.7
66500	0	10.7	0.12	2628	0	0	1	42.5	1.68	90	0	-10.59	-0.01	0	19.4
66859	0	11.03	0.18	2598	0	0	1	41.5	1.66	90	0	-10.88	-0.04	0	19.4
67219	2.35	10.92	0.22	2572	0	0	1	47.5	4.46	90	0	-10.74	-0.02	0	19.4
67594	4.71	10.1	0.3	2558	0	0	1	51.5	5.48	90	0	-10.01	-0.1	0	19.4
67938	5.49	10.17	0.31	2538	0	0	1	51.5	4.34	88	0	-10.16	-0.12	0	14.4
68297	6.67	10.22	0.31	2528	0	0	1	51.5	4.29	88	0	-10.16	-0.15	0	13.3
68656	11.76	8.36	0.54	2484	0	0	1	47.5	6.9	88	0	-7.69	-0.01	0	14.6
69016	12.16	7.86	0.55	2486	0	0	1	46.5	6.36	88	0	-7.55	0.06	0	14.7
69359	11.37	7.29	0.58	2472	0	0	1	44	6.84	88	0.5	-6.96	-0.05	0	15
69703	12.55	7.43	0.57	2480	0	0	1	45.5	6.29	88	0.5	-6.96	0.13	0	14.9
70063	8.63	7.11	0.53	2436	0	0	1	47.5	6.24	86	0	-7.25	-0.23	0	14.3
70406	0	10.27	0.24	2420	0	0	1	48.5	1.55	86	0	-10.45	-0.25	0	14.8
70781	0	10.89	0.22	2403	0	0	1	45	1.54	86	0	-11.03	-0.32	0	15.2
71141	0	10.78	0.22	2356	0	0	1	42.5	1.52	86	0	-11.03	-0.35	0	16.9
71500	0	10.7	0.22	2364	0	0	1	40.5	1.51	86	0	-11.03	-0.47	0	19
71859	0	10.63	0.22	2324	0	0	1	38	1.49	86	0	-11.03	-0.58	0	19.4
72234	0	10.57	0.21	2303	0	0	1	36	1.48	86	0	-11.03	-0.62	0	19.4
72578	0	10.5	0.22	2267	0	0	1	34	1.45	86	0	-11.03	-0.72	0	19.4
72922	0	10.38	0.21	2264	0	0	1	31.5	1.44	86
Mods: TXS catless turboback exhaust, Frontmount, 18G, K & N Short ram, stock injectors (for now) and a stage 2 reflash that I am reworking to suit my needs. I have some more logs, but they all show pretty much the same thing, but I can post them later if nessisary
TrRex06 is offline   Reply With Quote
Power Loss and loud knock from under the hood. STIdreamer17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-05-2009 06:34 PM
Need help w/ data log and AFR / Knock question Tronner AccessPort 1 11-09-2007 02:07 PM
A UTEC question - flashing CEL, no knock seen on data log..what gives? LargeOrangeFont Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-03-2003 03:33 PM
Logged data from my grocery run ninrex South East Region Forum 1 05-22-2002 12:33 AM
sorta OT, how to log data from a potentiometer RidinLow General Forum Archive 0 11-09-2000 08:18 AM
