Old 01-18-2008, 01:04 PM   #1
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Default Injector scaling - top level fuel control
should have put these current questions in to one post but Im generating new ones daily
With regard to injector scaling.. E.g. stock 550 sti injectors.
Currently scaled at 525 cc for arguments sake, I go logging and see I would liek to lean or richen things up across the board prior to fine tuning etc. Would a decrease in scaling generally increase the amount of fuel injected globally? and vice versa...
Apologies if a rather obvious post
Kastley85891 is offline   Reply With Quote
Old 01-18-2008, 01:16 PM   #2
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Decrease the scaler to add more fuel (make it run richer than it is currently across the board). Increase the scaler to add less fuel (make it run leaner than it is currently across the board).
gabedude is offline   Reply With Quote
Old 01-18-2008, 01:19 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
lower scalar = richer
higher scalar = leaner
Do not make the mistake of many & assume the Injector scalar is absolute; assuming that 550cc/min = 550cc/min injector scalar. ALWAYS start with a smaller value than what they are rated at. I recommend starting at ~85% of rated flow, which would be 468 with a 550cc/min flow rated injector.
testes1010 is offline   Reply With Quote
Old 01-18-2008, 01:38 PM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Thanks guys - needed confirmation - got it thanks - this must be the easiest forum area on NASIOC to get straight answers.
RC 1000cc Top Feed Injectors, Apex-i AVCR Boost Controller *BALLLLLLLLLIN* dan avoN7 Engine/Power/Exhaust 10 01-06-2010 12:19 AM
help with fuel trims / injector scaling.. logs inside AaronWRX UTEC 15 09-20-2007 09:37 PM
STI WRX ultimate racing side feed to top feed fuel injectors & rails kit 785cc Ricowrx Private 'For Sale' Classifieds 8 11-28-2004 05:52 PM
Ultimate Racing top feed fuel rail injector problems? Ricowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-07-2004 04:59 PM
Ultimate Racing Fuel injectors w/ top feed rail kit for STI Ricowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 09-15-2004 09:16 AM
