Old 01-18-2008, 11:44 PM   #1
gloyale
Member#: 134923
1989 GL w/96 EJ22
Default Phase II 2.5 block with Phase I 2.2 heads
I want to use a SOHC EJ25 block from a 99 Forrester with a set of 2.2 heads from a 93 Legacy. Going into a 91 Legacy. This is so I can retain the stock intake, and keep it non interference. Any issues to be aware of?
Or am I better off using the EJ25 heads and just swapping harnesses? But then it will be interference if the belt breaks.
Thisa is for an off-road rig, so long term durability is key. I can change a belt on the trail, but I can't replace valves.
gloyale is offline   Reply With Quote
Old 01-19-2008, 12:50 PM   #2
gloyale
Member#: 134923
1989 GL w/96 EJ22
Bump?
Old 01-19-2008, 01:24 PM   #3
charliew
Member#: 125304
I am interested in the non interference motors can someone explain this would also be a off road application.
Charliew
charliew is offline   Reply With Quote
Old 01-19-2008, 01:34 PM   #4
gloyale
Member#: 134923
1989 GL w/96 EJ22
Charliew
Well, all EJ22 until 96 or early 97 where a non interference design. Meaning that there is clearance for the valve to be open, and the piston to be at top of cylinder and nothing will hit.
I have a spare SOHC EJ25 from a Forrester, I want the extra displacement, but don't want the rik of a belt breaking and valves colliding with pistons.
My thinking is 2.5 block with old school 2.2 heads on it. Has anyone done this?
Old 01-19-2008, 04:18 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
It has been done. Search for "high compression frankenstein" in either the NA or conversions forums. It's a good reliable setup, but still interference due to the comression ratio. Much less dish on the pistons of the phase II EJ25.
Jay Storm
2.5 block with wrx heads mmmRex21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-13-2008 08:04 PM
wtb 2.5 block with no internals rexfromhell Private 'Wanted' Classifieds 2 02-18-2008 10:24 AM
2.5 block with 02 wrx heads slprwgn Engine/Power/Exhaust 3 01-16-2008 08:22 PM
2.5 block with 2.5 heads((help)) awdhondakiller Subaru Conversions 1 07-03-2006 03:22 PM
2.5 block with STI heads & internals KYScuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2003 11:34 PM
