Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-19-2008, 01:03 AM   #1
iRace559
Member#: 142654
2007 OBP WRX RA 1-4
Built Motor DOM3XT-R :)
Default Finally got my car back. Not to happy with the RA Gearset.
I'm just sort of bummed out right now. After 3 long weeks of waiting, I finally get my car back with the RA 1-4 gearset and an Exedy clutch. However, getting used to the new gear ratios is going to be impossible. The car no longer has that baddass warp speed hit. I used to love rev-matching from 3rd to 2nd and flooring it and getting sucked into my seat. That is no longer the case. The gears just rev out really quickly, I mean sure theres virtually no turbo-lag, but wheres the fun in that. It's too linear, AKA. Slow.
I wonder if an FPGreen will solve my problem
Anyone with RA gears can you please chime in?
iRace559 is offline   Reply With Quote
Old 01-19-2008, 01:17 AM   #2
dereknmmi
Member#: 101362
05 WRXstg2,BMW135i
Black, Silver
i thought the ra gearset would actually make your car faster, than the stock ratios?
dereknmmi is offline   Reply With Quote
Old 01-19-2008, 01:41 AM   #3
Rickyh
Member#: 40453
I find that it is much easier to stay in boost. I would hardly describe it as slow. I thought it was a huge improvement. Maybe you were just expecting too much? I dunno. I would never go back to stock ratios.
Rickyh is offline   Reply With Quote
Old 01-19-2008, 02:40 AM   #4
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
This is a first...
rhinotech is offline   Reply With Quote
Old 01-19-2008, 03:16 AM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
RA gears where geared for 8k rpms. Your 6500rpms make them run out quick.
FuJi K is offline   Reply With Quote
Old 01-19-2008, 03:38 AM   #6
dereknmmi
Member#: 101362
05 WRXstg2,BMW135i
Black, Silver
Well if its holding boost longer because of the gears we should be able to go to 7250rpms, if you have a cobb.
Old 01-19-2008, 09:14 AM   #7
iRace559
Member#: 142654
2007 OBP WRX RA 1-4
Well the car definitely wants to be revved out higher and it stays in the powerband while shifting almost like I diddnt even shift at all, but I kept the stock 5th gear and 4th to 5th sucks. I guess I just have to get used to it.
Old 01-19-2008, 09:21 AM   #8
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
The 2.0L WRX motor is a rev happy motor, ins't it. Meaning it "likes" to be reved high, right. I mean there is nothing wrong with taking it past 5,500 rpms. Not every shift, but now and then
shamrock 05 is offline   Reply With Quote
Old 01-19-2008, 09:47 AM   #9
iRace559
Member#: 142654
2007 OBP WRX RA 1-4
its a 2.5
The thing is begging to be revved to 8k.
Old 01-19-2008, 12:55 PM   #10
WickedRydaX
Member#: 31900
I love the way the RA's feel over the stockers. The RA box felt better road racing then the 4 and 6 speed. I just wish I wasn't worried about breaking it, thankfully I haven't.
MCL
WickedRydaX is offline   Reply With Quote
Old 01-19-2008, 01:00 PM   #11
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
11.9@117 dd
Changing gear ratios doesnt make the car any faster, RA gears actually made my car a little slower at the track, maybe because my engine was still stock
Str8Gone is online now   Reply With Quote
Old 01-19-2008, 02:05 PM   #12
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
They are great on the more rev happy 2.0L.
jhargis is offline   Reply With Quote
Old 01-20-2008, 02:06 AM   #13
triguy
Member#: 27109
2002 WRX Wagon
2.5L Crawford, 6 spd
If it makes you feel better, I had the same sensation going from the 5 speed to the 6 speed. Each gear has a tighter range and the redline comes on quick at the track. 3rd gear on the stock 5 speed was great - until the teeth broke off. And the tranny was 75 pounds lighter.
triguy is offline   Reply With Quote
Old 01-20-2008, 02:31 AM   #14
subz
Member#: 133379
2004 legacy gt
I race what do u do for a living ? u jus bought 6 grand of gears installation now u want a BIG TURBO haha ... i wish i had money like you
subz is offline   Reply With Quote
Old 01-20-2008, 11:23 AM   #15
shayrgob
Member#: 90959
03 wrx
is that right? I would look into that If I were you. Report back when you're done researching.
shayrgob is offline   Reply With Quote
Old 01-20-2008, 04:03 PM   #16
WRXBob
Member#: 12455
02 WRX
I got 50 series tires (lower ratio then the stock tire about 350 rmp) with the 6 speed on my 02. So I thought that would be too low and switched to the stock sized tire. Wrong, the car is noticeable slower. Plus the ECU should be reset so the computer can adjust to the new load. Lower ratio, faster acceleration is true to our engine with small displacement and low compression ratio.
WRXBob is offline   Reply With Quote
Old 01-20-2008, 04:59 PM   #17
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
</yourself>
Please.
ExpO is offline   Reply With Quote
Old 01-20-2008, 06:37 PM   #18
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
It should theoretically be faster with the shorter gears. I think it's all in your head.
Short gears tend to be slower sometimes because you shift too slow, or possibily you lose traction too easily.
It also could be that your powerband is falling on it's face in the upper end when you shift up to the next higher gear. If that's the case, then maybe you could look into a new turbo that would give great top-end..like a Green-size or bigger.
akira02rex is offline   Reply With Quote
Old 01-21-2008, 01:04 AM   #19
iRace559
Member#: 142654
2007 OBP WRX RA 1-4
Well I think it was all in my head, because tonight I really got on it and man that thing flew. I was just taking it easy on the car because of the new clutch and I guess I diddn't get on it hard enough to realize the power. I was just used to a more drastic turbo hit because of the longer gearing, however it really does pull a lot harder now.
Although, I definitely think that I could benefit from a bigger turbo with the shorter gearing. It would be able to build boost quicker and hit great up top.
I've only driven the car a 100 miles so far, so im going to take it easy for a little while longer and bed in the clutch. Then Ill give it a nice good run, and give my opinions again.
Old 01-21-2008, 01:43 AM   #20
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
That sounds more like it. I think you were just expecting something different. With the shorter gearing it didn't make sense that you thought you car was slower. Would like to hear more about what you think of the gears. OEM gears hold up fine to my power goals and driving style but am starting to think the RA's would be better sprinted driving gears.
John__Gotti is offline   Reply With Quote
Old 01-21-2008, 01:46 AM   #21
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
umm 6 grand for a RA set? Maybe your confusing them with PPGs.
sluflyer06 is offline   Reply With Quote
Old 01-21-2008, 02:02 AM   #22
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
^^^but if you want, i can sell you an RA set for 6k
v8eaterWRX is offline   Reply With Quote
Old 01-21-2008, 02:44 AM   #23
bboylocob
Member#: 151809
2007 WRX
hey what all did you have to change to make your fd 3.9???
bboylocob is offline   Reply With Quote
Old 01-21-2008, 03:14 AM   #24
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
IMO the IDEAL tranny for MAJORITY of the complaining guys here who LOVE torque, lower revs, and holding gear longer for the 1320 and that BUTT dyno feeling PLUS good 6th gear for HIWAY....
LEGACY SPEC B 6spd 3.900FD transmission!!!
/thread (IMO)
Old 01-21-2008, 01:09 PM   #25
NJ2.5RS
Member#: 110353
2006 WRX
black
I'm gonna assume you got the RA's from rallispec. What did they charge you for the swap? Thinking about going that route my self unless i can get my hands on the lgt gears by then.
NJ2.5RS is offline   Reply With Quote
Finally got my car back from the shop Louros Tri-State Area Forum 9 08-21-2006 12:44 AM
finally got my car back from the shop... thbalance Member's Car Gallery 45 09-19-2004 11:03 PM
Finally got my car back from the shop phenomenon Vancouver Impreza Club Forum -- VIC 0 07-22-2002 05:18 PM
So I finally got my car back from the body shop, after two weeks and... JGard New England Impreza Club Forum -- NESIC 8 03-23-2002 10:03 AM
Finally got my car back (6 weeks in the shop) BoomerRS New England Impreza Club Forum -- NESIC 6 05-03-2001 09:59 AM
