Notices
Old 11-25-2010, 04:50 PM   #426
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Originally Posted by photog72 View Post
Sweet ride! I used to have a '93 Touring w/ trailer hitch. Never got around to buying the trailer for it though. Engine o-ring failure forced me to give it up.
They're great cars. I miss mine as well. I've had two. That R1 and a base model. I'm sure you'll agree, the S2000 is nearly as fun and a good replacement. The Honda takes a lot of worry off your shoulders if you're into track days.
eastcoastbumps is offline   Reply With Quote
Old 11-25-2010, 04:54 PM   #427
photog72
Member#: 43815
2006 WRX Wgn Limited
2006 Honda S2000
It takes a lot more mods to make the Honda as fast as the RX-7 was. But, the Honda is so much more reliable, even w/ mods.
photog72 is offline   Reply With Quote
Old 11-26-2010, 07:39 PM   #428
Timmay81
Member#: 161575
2002 Wagon
has anyone wired a 2002 wrx without buying one of those 70$ kits?
Timmay81 is offline   Reply With Quote
Old 11-28-2010, 10:23 PM   #429
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I never worried too much. I had the ultimate reliability mod done on both cars...LS1.
Old 11-29-2010, 07:30 AM   #430
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
I bought my hitch from Subaru, it came with a harness (though I still needed to splice). There's more to the harness than just wires, there's a device that gets power from the battery for the lights. Apparently without it the draw is too much and all your lights will be dim.
Snowphun is offline   Reply With Quote
Old 11-29-2010, 10:14 AM   #431
Timmay81
Member#: 161575
2002 Wagon
i ended up buying a conversion deal, cause subaru doesnt have turn and brake on the same line, this converts it over, it was 16$. My trailer only has 1 set of lights so i dont think that will dim my lights, my stereo draws alot more juice than that and it doesnt fade my lights/battery now
Old 11-29-2010, 09:48 PM   #432
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Good luck, this isn't the same as the stereo circuit. The wiring is thin, designed to supply the stock lights, not designed for the extra load, nor the significantly longer wire run.
Old 11-29-2010, 10:00 PM   #433
Timmay81
Member#: 161575
2002 Wagon
guess i will see when i tow, ive seen tons of vehicles do it this way with no issues
Old 12-02-2010, 05:09 PM   #434
sd_wagon_07
Member#: 139820
2007 WRX Wagon Ltd
Clark Turner Tuned
Just installed my Curt hitch last night (from etrailer). Wish I would have gone with the draw-tite or hidden hitch instead. The driver side was bent in and the inner bolt hole on the passenger side didn't line up either. I heard others had similar issues while some said the fitment was perfect. Figured I'd take my chances and lost.
sd_wagon_07 is offline   Reply With Quote
Old 12-23-2010, 04:15 PM   #435
dmitche
Member#: 261430
Default 2003 Impreza Outback Sport
Does anyone know if the stock exhaust on an 03 OBS requires any Kartboy Exhaust hangers for a Drawtite Hitch? It seems the WRX does however it also has a different stock setup.
http://www.draw-tite.com/content/pro...005&part=24710
Also, anyone else with an 03 OBS having trouble finding the wiring harness underneath the right rear panels behind the brake light?
dmitche is offline   Reply With Quote
Old 12-24-2010, 02:15 PM   #436
Studmike02
Member#: 220095
'95 MX-5
with a 06 2.5i sedan, I would need to buy the wirings, but from what website would you highly recommend?
thanks.
Studmike02 is offline   Reply With Quote
Old 12-30-2010, 12:09 PM   #437
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
thanks.
Just get a generic one from Wal-Mart and tap into your tail light harness.
flimflamman is offline   Reply With Quote
Old 12-30-2010, 02:33 PM   #438
dmitche
Member#: 261430
Default Follow Up
This hitch fit perfectly without the need for any exhaust hangers. I wrote up a brief article if you would like to check it out. http://dougmitchell.us/?p=814
Old 12-31-2010, 10:15 AM   #439
10obs
Member#: 268647
2010 Outback Sport
Default 2010 impreza wagon 2.5 (outback sport)
Hi all, i'm new to the forum and i'm sooooo happy to have found this thread, it took me a while to find a thread like this, the information in here is invaluable! thank you for sharing!!
I went with the Curt hitch from etrailer and also got the Curt wiring kit since it plugs into the tail lights instead of having to splice the wires. I installed the hitch myself and had Uhaul install the wiring kit.
I had to enlarge the holes for the bolts in order for the bolt to go through, i used a dremmel to widen the existing hole proportionately so that the hitch will be center once installed. i had to unhook the exhaust to get the hitch installed. The only difficult part was trying to torque the smaller bolts since it is very awkward to reach them.
i also got a transmission cooler, i haven't installed it yet and need some help on the subject, i realize that the majority of the members have the WRX or STI - do u think that there is a difference in towing capacity between my car and the turbo? do the turbo models come with a tranny cooler?
I will be towing my bike to the track for track days, my current setup is a tiny trailer called (trailer in a bag) it weighs 140 lbs and my total towed weight is about 700 lbs bike, trailer and gear.
I would love to upgrade to an enclosed trailer, the new total weight will be in the range of 1500 - 2000 lbs.
do u guys think that my car can handle such a setup keeping in mind that there will be increased drag and the above mentioned weight?
i will be towing the bike about 200 miles each way.
Any help will be appreciated.
Curt Hitch from etrailer
10obs is offline   Reply With Quote
Old 12-31-2010, 10:48 AM   #440
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Originally Posted by HERSHEY View Post
I think most have seen these but I'll post them anyway
NOW THAT is bad-ass...!!!!
Old 12-31-2010, 04:17 PM   #441
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
1500+# is way too much to be comfortable with IMO. If you need to go to an enclosed trailer you need a bigger vehicle. I'm in the same boat with kart gear, I find keeping my small open trailer and the Subaru works much better.
Old 01-02-2011, 12:42 PM   #442
TrueSilver
Member#: 152207
2006 OBP STi
2015 Duramax LML
Does anyone have experience with the 08+ STi model yet? I installed the single exit exhaust on mine and was wondering if everything would match up now that the quad tip is out of the way.
Any help is appreciated I need to tow my quad!
TrueSilver is offline   Reply With Quote
Old 01-03-2011, 06:21 PM   #443
Timmay81
Member#: 161575
2002 Wagon
Old 01-06-2011, 08:12 PM   #444
kakdaman
Member#: 245117
2005 wrx
aspen white
So does anyone know what size bolt/thread pattern fits into the frame? I have the hitch all ready to go, but apparently the owner before me had removed the pre-existing bolts. any inf0 would be appreciated.
kakdaman is offline   Reply With Quote
Old 01-06-2011, 09:01 PM   #445
Evil Homer
Member#: 175522
You will be fine, just don't drive like a toolbag. I made a 20ish hour trip from NC to Ma with no problems in inclement weather.
Evil Homer is offline   Reply With Quote
Old 01-07-2011, 09:36 AM   #446
hqp921
Member#: 97072
2008 Mazda Miata GT
2003 GMC Sonoma Crew Cab
Originally Posted by Evil Homer View Post
One of the reasons I want to get a hitch is to transport my motorcycle!
- HP
hqp921 is offline   Reply With Quote
Old 01-07-2011, 07:04 PM   #447
Eriksport
Member#: 5825
02 Impreza WRX Wag
Silver, curb rash, mud
17mm head I believe. Do you still have the tow hook on the one side? You reuse those bolts. Fine thread. Sorry, not much else help.
Erik
edit: reread, those bolts are MIA. My bad.
Eriksport is offline   Reply With Quote
Old 01-09-2011, 03:55 PM   #448
wantsti
Member#: 134764
04 sti
java black pearl
Those with the cobb exhaust and the curt hitch do you need 2, 3, or 4 extended hangers?
wantsti is offline   Reply With Quote
Old 01-13-2011, 08:48 PM   #449
J.biz
Member#: 191825
2009 WRX Hatch
Hi all I planning on buying a Curt Class I Receiver Hitch kit for my 09 wrx 5 door. How tough is the install and wiring for all who have done it on the newer wrx's.
Thanks Josh
J.biz is offline   Reply With Quote
Old 01-28-2011, 08:37 PM   #450
J.biz
Member#: 191825
2009 WRX Hatch
Last weekend I installed the Curt Class I Receiver Hitch on my 09 wrx 5 door and wow! Super easy install! Hardest part was drilling out the holes a little bigger in the frame rails. Other then that install was cake! Took a little over a hour for everything. Wiring plugged right in which was great! Moving to the midwest on Monday! Going to be towing a 5x8 cargo trailer from Uhaul.
Towing WRX behind RV with RV mounted tow hitch Ardrossan General Community 36 03-17-2016 01:07 PM
Tow Hitch flent General Community 2 11-26-2001 05:19 AM
tow hitch kream Bay Area Impreza Club Forum -- BAIC 6 04-01-2001 10:34 PM
