Old 11-06-2011, 08:11 PM   #626
premier00000
Member#: 251060
2008 Impreza Outback
Originally Posted by vision.dynamix
200/2000
200lb tongue weight, 1000lbs towing
OR 2000lb WITH brakes.
premier00000 is offline   Reply With Quote
Old 11-06-2011, 08:41 PM   #627
Studmike02
Member#: 220095
'95 MX-5
Originally Posted by vision.dynamix View Post
Thats because youre WAY beyond the rating of the car and hitch. Youre lucky you didnt bend the body and/or the hitch.
Think twice, my car is lowered so the rear was already lowered and I got an toe in alignment so the tire rubs faster, the limit is 200 lbs and I'm not WAY beyond the rating. The tires were just out of life so thats why I used the bad set.
I stopped every 200/250 miles to check and make sure everything was fine and I am here in New York all fine and good.
Studmike02 is offline   Reply With Quote
Old 11-06-2011, 08:50 PM   #628
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
4 wheel/tires are on average 50lbs each = 200lbs.
However much that frame weighs, Id guess 25lbs.
Thats 225lbs.
Here's the kicker..the 200lb rating is for 4" beyond the hitch (Typical ball mount)
Looks like your center of gravity is AT LEAST 12-16" beyond the hitch.
Ever heard of this thing called Leverage?
Old 11-08-2011, 02:08 PM   #629
MyOtherRideIsUrMom
Member#: 159636
2007 WRX WRB-18G EWG
2014 Outback LTD ISM
I just got done towing a Harbor Freight 4x8 from NYC to WV, and back. I have a 2007 WRX with a TD05-18G EWG, stock suspension, 114k miles, and a curtis hitch. With the side panels and wood it probably weighed 300ish pounds and then I packed it with tools probably weighing 700 or so. I had no trouble the whole trip; going up hills, dead stop up a steep driveway, braking, I probably averaged 75mph the whole way.
I have a bar camera above my license plate that worked great for hooking up the trailer
MyOtherRideIsUrMom is offline   Reply With Quote
Old 11-08-2011, 06:54 PM   #630
05-rsx
Member#: 101188
MY07 WRX Wagon
****ty photos from the Bro of his new ride , and our trailer
05-rsx is offline   Reply With Quote
Old 11-14-2011, 12:34 PM   #631
chiron47
Member#: 35822
03 WRX Wagon
Anybody run a hitch mounted platform on the wide body WRX frame with the Curt hitch? Looking mostly for extra cargo volume, not much weight. Already running a hitch mounted rack on an 03 wagon but looking to upgrade and need to buy back some space for weekend trips.
chiron47 is offline   Reply With Quote
Old 12-02-2011, 10:14 PM   #632
TheBussman
Member#: 293647
2003 WRX
black
Glad to hear there are others out there towing with Subarus. I towed all kinds with my old corolla. After I bought the WRX everyone's been warning me the towing kill the AWD. It sounds like it's all talk though. I'll be buying a hitch in the next cupple of weeks.
TheBussman is offline   Reply With Quote
Old 12-04-2011, 04:40 PM   #633
vweater
Member#: 97620
2005 2.5RS
Obsidian Black Pearl
My New Hitch Mounted Ski/Snowboard rack.
vweater is offline   Reply With Quote
Old 12-04-2011, 04:51 PM   #634
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Thats an interesting setup.
Old 12-04-2011, 05:36 PM   #635
chrSTIan
Member#: 42749
2002 IMPREZA TS
2003 HONDA S2000
My old set up.
I'm using 02 impress wagon TS now. Same trailer and 2 bikes for Trackdays
chrSTIan is offline   Reply With Quote
Old 12-04-2011, 06:55 PM   #636
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Yeah, pretty cool. I was always able to put two boards in the back seat of my MY02 sedan, one behind each front seat. Or through the pass through.
Snowphun is offline   Reply With Quote
Old 12-04-2011, 07:00 PM   #637
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Its messy though.
Im trying to stop putting **** in my interior..so sick of tearing my interior apart.
Old 12-04-2011, 08:06 PM   #638
vweater
Member#: 97620
2005 2.5RS
Thanks I just finished building it out of a cheapy ebay bike rack and some used roof rack borad and ski holders. I already had the hitch for my catamaran and bike rack so i wanted to get a board rack but they are pricey to buy. I also wanted to stay away from the roof racks because of expense mileage and noise. So you guys are seeing my solution for a cheap hitch board carrier.
Its messy though.
Precisely why I hate putting it inside and if I leave the pass through open the drone is horendous.
Old 12-04-2011, 08:55 PM   #639
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Its messy though.
Whatever works for you. A good shake in the lot and there's just a little snow/water on the board. For me that's a fair trade off to avoid getting road crap all over the board and the gas mileage hit.
I'm taking the Mini snowboarding this year, fitting boards inside that is not easy.
Old 12-05-2011, 02:55 PM   #640
meifert
Member#: 301676
2009 Forester XT
dealership just told me 200/2000.
meifert is offline   Reply With Quote
Old 12-05-2011, 03:00 PM   #641
premier00000
Member#: 251060
Yeah it's 2000lbs if the trailer has brakes on it. If not, it's 1000
Old 12-05-2011, 05:30 PM   #642
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
For your 2011? Check the manual, SOA now bans towing on WRX's, not sure if that's the case with base Imprezas. Either way anything over 1k# needs trailer brakes.
Old 12-05-2011, 05:40 PM   #643
meifert
Member#: 301676
2009 Forester XT
they said 200/2000 for any trailer...they just recommend going 60 mph max.
Old 12-05-2011, 07:46 PM   #644
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Again, read your manual. The dealer is WRONG. Here's the part you care about, from your manual:
Trailer towing
Your vehicle is neither designed nor
intended to be used for trailer towing.
Therefore, never tow a trailer with your
vehicle.
SUBARU assumes no responsibility for
injuries or vehicle damage that may result
from trailer towing, from any trailer towing
equipment or from any errors or omissions
in the instructions accompanying such
equipment. SUBARU warranties do not
apply to vehicle damage or malfunction
caused by trailer towing
Old 12-05-2011, 08:04 PM   #645
meifert
Member#: 301676
2009 Forester XT
all my stuff only weighs about 1500 pounds and that includes a trailer. i just dont want to have to rent a truck for $1300 to move.
Old 01-02-2012, 03:51 AM   #646
BoneJj
Member#: 222089
Satin Pearl White
would you rather do 1300 dollars of damage to your car????
I'd rather put the car on a flat bed trailer and tow it all those miles VS having to possibly replace all kind of parts or even a transmission or burn a turbo up on such a long haul.
In the long run it's safer to just trailer the car and rend a truck capable of hauling your stuff and the car.
I personally wouldn't exceed 1000 with our cars and that's pushing it a bit. IMO,
I do however need to find a new hitch for my car and I also need to get a trailer to put my bike on. I wanted to get a dual bike trailer but seeing as my bike is 600 pounds and my friends is nearly 700 I told him he will need to get the dual trailer as his mustang can tow both bikes at once and I'll just find a cheap used single for my bike. lol.
BoneJj is offline   Reply With Quote
Old 01-02-2012, 03:55 AM   #647
BoneJj
Member#: 222089
Satin Pearl White
Okay, I have looked through this thread a few times and I'm stumped as to what to get. There are a lot of brands out there and I just don't know what hitch to get for my 2010 WRX (non-STi).
What do you guys seem to like the most for brands? and which ones are the most compatible with aftermarket exhausts?
Is anyone able to help me out on this quest?
Like my post above says this will be for towing my bike. I have a vulcan 900 right now but may be upgrading in a few months if things work out.
Old 01-02-2012, 07:41 AM   #648
Brendin87
Member#: 215987
98 WRX
Blk
Anyone have any take on towing from NY to South FL. Roughly 1500 miles, 1 way.
I'll be using an '04 WRX Trans.
Max weight on the trailor should be 800. (that's including the trailor)
Brendin87 is offline   Reply With Quote
Old 01-02-2012, 07:46 AM   #649
chrSTIan
Member#: 42749
2002 IMPREZA TS
2003 HONDA S2000
Got mine from www.uhaul.com
Used it on my 04 Sti,96 impreza OBS and 02 impreza TS.
Old 01-02-2012, 09:55 AM   #650
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
Have any of you ever been rear-ended with your rack on the back of your car? I have, and I'll update later with undercarriage damage estimates.
The good thing is that the rack saved the rear of the car's body panels.
wrXmon is offline   Reply With Quote
Towing WRX behind RV with RV mounted tow hitch Ardrossan General Community 36 03-17-2016 01:07 PM
Tow Hitch flent General Community 2 11-26-2001 05:19 AM
tow hitch kream Bay Area Impreza Club Forum -- BAIC 6 04-01-2001 10:34 PM
