Old 02-02-2002, 11:08 PM   #1
gingerbread man
Member#: 12712
1993 impreza wagon
L. blue (rolled my WRX)
Default ECU problems??
Speedometer reads 60 mph when I am sitting in my driveway, then jumps around 20mph in both directions at highway speeds. When decelerating, the tach goes to zero and the CEL flashes. The coolant temperature light twitches like its on acid and I am getting 18 miles per gallon without ever allowing the car to come under boost. Anyone else have problems like these?
Jason
gingerbread man is offline   Reply With Quote
Old 02-03-2002, 11:01 AM   #2
WRXSTi69
Member#: 12012
The ECU does not control the speedometer. The speedo is electronic and gets a signal from a sensor in the tranny. That signal is then sent to the ECU. You may have a speed sensor or speedo head problem, or an electrical wiring problem. A bad speed sensor signal to the ECU will cause running problems and trip the MIL (what you refer to as the CEL).
Have you added any gauges or anything else electrical to the car? Any mods done with the ECU or wiring? If it's stock and still under warranty, bring it to your dealer for diagnosis.
WRXSTi69 is offline   Reply With Quote
Old 02-05-2002, 08:48 AM   #3
Fast4Door
Member#: 14709
Default Wierd?
Does your car rack mileage from just sitting in the driveway too? I assume it would if your spedo thinks you are doing 60. I would get it fixed ASAP and mention an extension to the warrenty due to the fact there are miles on your car that you didnt actually drive.
Fast4Door is offline   Reply With Quote
Old 02-05-2002, 01:28 PM   #4
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Question Is this a joke?
If it isn't, get your car into the shop ASAP, your car is whacked.
Stanley is offline   Reply With Quote
EGT Problem or ECU Problem??? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-29-2006 10:01 PM
ecu problem eraser1303 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-31-2002 04:32 PM
('93-'01) ECU problems Help!!!!!!!!! Jimmy Impreza Forum 9 04-09-2001 10:29 AM
ECU problems Frank General Forum Archive 4 02-13-2001 12:55 AM
Air/Fuel & ECU Problems... ndmorespd Bay Area Impreza Club Forum -- BAIC 1 09-07-2000 06:11 PM
