Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 01-19-2008, 07:58 PM   #1
teeots
Member#: 140731
Default Rough High Idle and hunting
Maybe not the right place to post this...?
I came back from a 530 mile trip in 10 hours, the last two of which it snowed like hell. The car ran like a champ. It sat in the garage for about 7 days at which time I started it and it ran rough, like maybe a misfire and was idling fast almost 2k until warm then 1300 when it kicked down. I tried to take it for a gentle drive to see if it would come out of it, but it would hiccup on throttle and boost and almost stall (hunt for idle)when out of gear. Car was open source tuned by previous owner and has run perfectly till now. I took a look around the engine bay for obvious visible probs-- cracked or poor connectors, loose or leaky hoses. (Does the first gen accessport double as a code reader?) Any ideas are welcome. I will eventually trailer to a Subaru mechanic but am looking for some general easy things to check.
Danke for now.
teeots is offline   Reply With Quote
Old 01-20-2008, 03:33 PM   #2
scherejs
Member#: 169547
2003 Evo VIII
Tarmac Black
Boost/vaccuum leak? Check plugs.
scherejs is offline   Reply With Quote
Old 01-20-2008, 05:54 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
check your air filter. it is possible you sucked alot of snow in and now have a really wet air filter, which doesn't exactly flow air well.
Old 01-20-2008, 08:41 PM   #4
teeots
Member#: 140731
Thanks guys. I couldn't detect a vac leak by simply poking around, but intend to check the air filter. Its an open element and located down in the fender well. I ordered a code reader last night, so I should figure out a little better idea of where to look.
Old 01-20-2008, 11:01 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
so it is probably an oiled filter then? scratch that idea... The stock intake system can suck up enough snow to do this, it is great at separating water, but snow is light enough it can bypass the big jug and stick to the filter. get enough and the engine heat will melt it into a big chunk of ice/water.
Old 01-23-2008, 08:46 PM   #6
teeots
Member#: 140731
Code is P0519- description is idle air
Fluctuating, Rough, High Idle. Cause? wrx0001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-01-2009 12:34 AM
help! rough/shaky idle and ticking noise from engine resideinva Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-15-2008 10:57 PM
Need input for rough/high idle Crazykev Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-09-2006 10:25 PM
Rough/High Idle and P0519 Code SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-20-2006 01:58 PM
Rough high idle Gilla-Machster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-30-2004 10:31 PM
