Old 01-19-2008, 11:05 PM   #1
wrxrex
Member#: 130196
Old Stage 4 bugeye
Default Power gain from catted DP to catless DP?
My car is protuned with VF34, STi TMIC and catted downpipe. What kind of power gain can I expect from replacing catted downpipe with catless? My catted DP has over 45k miles and will need replacement soon. Instead of spending over $400 for catted one, I am considering getting a catless dp. Wonder if it's possible to just gut out the material? I understand that gutting out the UP is much easier.
Most important question: does it really smell that bad?
wrxrex is offline   Reply With Quote
Old 01-19-2008, 11:13 PM   #2
page02wrx
Member#: 124053
Back to BONE STOCK
Go catless.
Gutting the DP is tricky but can be done....gutting the up pipe is DEFINITELY worth it.
Any time you get rid of a cat on a turbo car you are going to see big gains.
page02wrx is offline   Reply With Quote
Old 01-19-2008, 11:18 PM   #3
bmak21
Member#: 165379
VTEC GOOOOOOOOOOOOOO
BWWWWAAAHHHHHHHHHHHHHHHH
going from catted to catless will gain u 5-10whp from what ive heard correct me if im wrong
bmak21 is offline   Reply With Quote
Old 01-19-2008, 11:20 PM   #4
Mr.ShenaniGaNs
Member#: 153498
2002 ImpreZa WRX
Championship BLUE!
every little bit of flow helps. Just dont forget the treeees.
Mr.ShenaniGaNs is offline   Reply With Quote
Old 01-19-2008, 11:37 PM   #5
wrxrex
Member#: 130196
Old Stage 4 bugeye
I also have a catless uppipe as well. Due to location of catalytic converter, gutting out will be very tricky.
Old 01-20-2008, 06:29 PM   #6
wrxrex
Member#: 130196
Old Stage 4 bugeye
bump for more info.
Old 01-20-2008, 07:16 PM   #7
Blacksails192
Member#: 142686
back to european
go catless! and DEFINATLY do a catless upipe. big difference in spool. be careful going catless though because thats all it takes with certain exhaust systems too loose a beautiful exhaust note. catless can bring the rasp out. and it doesnt smell THAT bad
Blacksails192 is offline   Reply With Quote
Catted DP to catless...retune? dlh1999 Open Source Reflashes 3 10-09-2009 02:42 AM
WTT: Catted Dp for Catless Dp gingertooth Private 'Wanted' Classifieds 2 02-09-2009 07:17 PM
EGT's w/catted DP vs. catless DP? PhastEddie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-13-2007 10:00 PM
Wtt:nj//catted Dp For Catless Dp gingertooth Tri-State Area Private Classifieds 1 01-20-2007 10:08 PM
