Old 01-20-2008, 03:00 AM   #1
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Default Enginuity and valet mode
Heya,
Well I was watching vids on youtube and one vid really grabbed my attention. It was a guy who noticed that when valet mode was enabled it enforces a lower rev-limit :P
Basically, this guy in the vid found that while in valet mode thecar was building boost while stationary, so this suggest that the valet rev limit is actually an ignition cut.
I'm sure most have caught on to what I'm suggestng, yes I'm talking about using valet mode as a 2-step limiter launch control system
Firstly is there any way that Enginuity can set/adjust the valet-mode rev limit point and how it is enforced (whether it is ignition cut or ignition and fuel cut etc)?
Secondly, what would it take to have valet mode enabled and disabled on the fly when certain conditions are met - as in when the handbrake switch, demister switch and clutch switch are activated, valet mode is enabled?
Is this possible or am I getting excited about nothing :P
Suggestions more than welcome
wrxsti.l is offline   Reply With Quote
Old 01-20-2008, 09:12 AM   #2
Tea cups
Member#: 103136
There's no valet mode, nor is there a stationary rev limit on the factory ROM. To get launch control you would have to hack the ROM and code for it yourself and obviously know what you were doing.
Tea cups is offline   Reply With Quote
Old 01-20-2008, 05:38 PM   #3
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
no matter.
Another thought, does the wrx/sti range of ecu's have a boost or temp compensation map? If so, could this map used with a modified rpm limit?
Old 01-20-2008, 06:19 PM   #4
Tea cups
Member#: 103136
not sure what you are getting at. There are tables for compensation to target boost based on IAT,ECT depending on the ECU.
Old 01-20-2008, 07:04 PM   #5
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
np. I have most likely misunderstood the functionality of the compensation maps. Perhaps I have used the wrong words.
I was thinking of all the possible times that the ECU might "limit" rpm under certain conditions - as in when boost goes beyond a certain presure, or temp goes beyond a certain temp.
I was then wondering (if the ecu does limit rpm under these conditions) if the actual RPM point where it is limited to was adjustable via Enginuity.
Then, and this is a BIG stretch, all I would have to do is "trick" the ECU into thinking that one of those conditions have been met :P
What do you think?
Old 01-20-2008, 07:38 PM   #6
Tea cups
Member#: 103136
There's no need to trick the ECU (not that there would be anything you could do with the currently defined tables anyway). You simply create a hack based off of the factory rev limiter that switches between two different RPM thresholds based on either veh. speed (for ECUs that don't have clutch switch input) or clutch switch (for FFS too). It has already been tested long ago (before even Cobb came out with theirs). Problem is, coming up with a way to distribute features like these for the general public. It will come, eventually, you just have to be patient.
Old 01-20-2008, 09:06 PM   #7
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
np Teacups.
No point recreating the wheel if you guys have it tested and working. I (like some others) are going stir crazy witing for it to be released - we have been waiting pretty patiently since last year lol
Nah, all good, any idea of an eta? I'm looking at a Bee*R limiter atm, and I would much prefer using enginuity instead :P
Old 01-20-2008, 09:34 PM   #8
Tea cups
Member#: 103136
I doubt it will come out as an Enginuity release. Likely be a separate standalone patching tool.
Old 01-21-2008, 12:13 AM   #9
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
np Tea Cups.
Will it be you creating the patching tool?
Old 01-21-2008, 01:11 PM   #10
Tea cups
Member#: 103136
Originally Posted by wrxsti.l View Post
np Tea Cups.
I would imagine unless development picks up on the Enginuity side. I make no promises, though.
Old 01-21-2008, 01:35 PM   #11
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
I just need to read my Java book. I look at java code and almost want to puke. C# isn't as bad, too bad that was not our platform or C++ modules for the Ramtune/FFS/Valet mode/etc code and whatnot.
gabedude is offline   Reply With Quote
Old 01-21-2008, 04:09 PM   #12
Tea cups
Member#: 103136
For me personally, this is what I have planned:
1. Finish up my standalone tool which reads the entire FLKC table from ram, the FLKC RPM/Load ranges and displays it as a 3D table. Releasing this tool will lay the foundation of a future real-time tuning app (testing and refining communication via SSM and table display)
2. Redo ROM code for the launch control for the 16-bit ECU so that it does not require a flash to change RPM threshold and would work as follows:
A. post-reset, LC RPM defaults to constant in ROM
B. To change LC RPM, rev motor in neutral up to current fuel cut RPM with vehicle below LC veh. speed threshold. Hit defogger switch within a certain delta of current LC RPM threshold (say 500 rpm). This disables current threshold and changes to SET mode.
C. In SET mode, in nuetral below veh. speed threshold, rev motor to desired new LC RPM and hit the defogger switch. LC RPM is now set to new threshold. Likely there would also be a minimum LC RPM in SET mode to avoid accidently setting new threshold when defogger is turned on to actually defrost the rear window.
3. Create patching app that will take into account multiple versions of the code and include warnings for use of LC and such.
4. Redo ROM code for 16-bit ECU real-time tuning (more compact -> already have an outline of the new code).
5. Start on app for real-time tuning to support the 16-bit ECU. Test on my own car. Release to trusted testers. If everything A-OK, release to public.
6. Once bugs are worked out, start support for the 32-bit ECU.
Of course, this is all dependent on how much time I have and how well things go. I might only get to #2 and then just release some 16-bit ROMs patched with LC and per gear wg comp. I don't know and I don't want to make any promises. What worries me in releasing hacks like these is liability. I want to make sure there is zero liability for me personally for anything I release (LC, real-time tuning, etc.). If there's not, then I won't do it.
Old 01-21-2008, 05:39 PM   #13
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Sounds awesome Tea Cups. There seems to be a few programmers interested in contributing to Enginuity still. Perhaps they could assist you and help get it out sooner?
Old 01-21-2008, 06:23 PM   #14
Tea cups
Member#: 103136
Well, I don't do Java. So, either someone develops it entirely for Enginuity with input from me on how things operate on the ROM side. Or I develop it in vb as time permits. The only developer currently actively working on Enginuity is Kascade. It sounds like he wouldn't have time to work on real-time tuning (it is quite a bit of work). As far as new contributors working on Enginuity, I'd have to see it to believe it as there have been many in the past that said they were going to contribute but flaked out after a few weeks and were never heard from again. Frankly, I'm quite a bit pessimistic about any major updates to Enginuity due to the site being down (maybe permanently) and no response from Jared or anyway to get a hold of him (for me anyway) about the site.
Old 01-21-2008, 06:40 PM   #15
Tgui
Member#: 44771
My C++ Rom Editing program is almost to v1.0, we need to chat.
EDIT: As I assume C++ is one of the languages you program in. I might be wrong.
Tgui is offline   Reply With Quote
Old 01-21-2008, 06:51 PM   #16
Tea cups
Member#: 103136
No, just visual basic. I saw that you were working on an editor -> looks good, but I wasn't sure how far you wanted to take it. If anything, I can always continue development on my own for testing purposes and then when I have something viable, see where your project and the Enginuity project are at that point.
Old 02-02-2008, 06:21 PM   #17
batchman
Member#: 94656
02 WRX Quicksilver
hums Indiana Jones theme
Sorry if I'm dragging a somewhat older thread but I was thinking of a valet mode myself....
Would simply hardwiring a switch into the BCS wiring allow you to disable boost beyond WG pressure (~7-8psi)? You could run switch into cabin.
Turns car into something akin to my old nissan sentra. Not turtle but certainly nothing like full boost. No redline limit though. But once they feel the weakness... who would want to continue running to redline?
That's right... the weakness
batchman is offline   Reply With Quote
Stage 2 and valet mode question the Stryder AccessPort 3 02-16-2010 11:12 AM
Fast blinking security light? And no it's actually not in valet mode Nick Car Audio, Video & Security 0 08-22-2008 12:58 AM
Question about CEL and Valet Mode ( AP ) Dragonbreak North West Impreza Club Forum -- NWIC 2 08-15-2007 05:22 PM
Valet mode and inspection theicewall Engine Management & Tuning 5 02-17-2006 09:50 PM
Security System stuck in Valet Mode??? cincyRS Technical Forum Archive 2 07-21-2000 09:24 AM
