Old 05-20-2013, 06:20 PM   #1
yoshimitsuspeed
Member#: 272846
Default Ball joint to knuckle pinch bolt question.
97 subaru outback legacy
My friend had these two bolts just spinning in place. I pulled them out and ran a tap through there to clear the threads, after which I was going to add nuts to longer bolts. I just realized though that the bolts that came out are 10x1.25 and my 10x1.5 tap ran through real easy. I am assuming these bolts are supposed to be 1.5 pitch but I just wanted to make sure before I order them.
Can anyone confirm?
yoshimitsuspeed is offline   Reply With Quote
Old 05-20-2013, 06:33 PM   #2
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
i've bought grade 8 bolts/nuts from lowes. napa or northern tool has a larger selection. that way you can see the goods and return what you don't need.
mhoerath is offline   Reply With Quote
Old 05-20-2013, 06:35 PM   #3
vision.dynamix
Member#: 139955
# OneBoston
There are no Grade 8 Bolts on a Subaru, as those are not Metric.
There are no M10x1.50 bolts on a Subaru, either.
Old 05-20-2013, 06:56 PM   #4
cal_look_zero
Member#: 294461
1997 Outback Sport
Acadia Green Metallic
Can anyone confirm?
Those pinch bolts are M10x1.25; and it's a terrible design for anywhere that is rust prone.. Your best bet is to run a drill straight through and use a washer>lock washer>nut on the end of the bolt. Had to do that on many Subis so far with great success.
cal_look_zero is offline   Reply With Quote
Old 05-20-2013, 07:15 PM   #5
yoshimitsuspeed
Member#: 272846
Alright, thanks for the tips guys.
Since that 10x1.5 tap went through there so easily and bit some fresh material I decided to go with 1.5 threaded into the knuckle with a lock nut on the other side.
Message Board Statistics All times are GMT -4. The time now is 10:55 PM.
