Old 05-05-2008, 08:58 AM   #26
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Got it, thanks
Old 06-03-2008, 01:53 AM   #27
andyboi677
Member#: 179049
2005 Imperza Wrx
anyone know how to resurface the brake rotors on the vehicle? please pm me.
andyboi677 is offline   Reply With Quote
Old 06-17-2008, 05:08 PM   #28
teddyj
Member#: 121796
2005 Blue WRX Sedan
In Subaru I Trust!
Is there a write up on ALK install for an 05?
teddyj is offline   Reply With Quote
Old 06-17-2008, 05:20 PM   #29
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
1) remove stock bushing
2) install ALK
Just come up to Columbus if you want some help. Assuming, that is, that you're the teddyj that is in Ohio
Honestly, there aren't any good ALK install tutorials. The few that exist all miss important details. If anyone around here does one, I'll do a williaty-HOWTO for it.
Old 06-20-2008, 08:24 AM   #30
Butt Dyno
Member#: 17301
is the "dark side"
Updated the credits...
Old 07-04-2008, 05:58 PM   #31
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
I just made a Paranoid Fabrications saggy butt spacer How To thread. If you wanted to add it to the list:
http://forums.nasioc.com/forums/show...3#post22870983
impreza_GC8 is offline   Reply With Quote
Old 07-04-2008, 08:14 PM   #32
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Had you not seen the existing one?
Old 07-09-2008, 11:17 AM   #33
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
Oh, you mean the one that tells you to disassemble your entire suspension just to put in some spacers. LOLz. I'll take mine over that one any day.
Old 07-09-2008, 12:21 PM   #34
Butt Dyno
Member#: 17301
is the "dark side"
Meh, I added it. People can decide for themselves
Old 07-29-2008, 02:14 PM   #35
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Is Kastle's brake pad installation any different from that of a 2005 STi installation? I've never changed the pads on a set of Brembo's yet.
Teh Legacy is offline   Reply With Quote
Old 09-03-2008, 10:55 PM   #36
Butt Dyno
Member#: 17301
is the "dark side"
Added camber bolt installation (thanks Turbojon for the link)
Old 09-25-2008, 08:12 AM   #37
Butt Dyno
Member#: 17301
is the "dark side"
Added the Brembo caliper disassembly. I have this feeling like I missed another one, so if you submitted something recently please feel free to "!" it
Old 09-25-2008, 05:44 PM   #38
ChronicHerb
Member#: 187595
2008 2.5i Hatch
Spark Silver Metallic
I recently installed sti pinks on my 08 impreza. I'm getting a loud clunking sound from the front right spring. Someone told me i positioned the top hat incorrectly. any tips on the proper way to position the top hat before I take it out and adjust it?
ChronicHerb is offline   Reply With Quote
Old 09-25-2008, 07:49 PM   #39
BIGSKYWRX
Member#: 7958
09 GH B+
a couple of potential problems- one the domed washer was inadvertently placed upside down (need to be orientated / \- small side up) or under the upper perch- needs to be on top
or you have the upper perch positioned wrong- there are three holes on the upper perch- the center hole should be centered on the strut facing directly outward
don't forget to look at the sway links first (it's often a source of noise up front)
Old 12-25-2008, 01:26 AM   #40
WRC9000
Member#: 173499
anything on taking apart the rear handbrake shoes/drum etc. ???
pm me please
WRC9000 is offline   Reply With Quote
Old 01-26-2009, 08:57 PM   #41
dlgonsalves
Member#: 200346
2002 Outback Sport
is there a howto outthere for a disk brake swap on a 02 obs, want to get rid of my rear drums
dlgonsalves is offline   Reply With Quote
Old 01-26-2009, 09:03 PM   #42
Butt Dyno
Member#: 17301
is the "dark side"
Check out the brake upgrade FAQ and look for the word "drum". I dunno why I didn't put that in here.
Old 02-23-2009, 10:59 PM   #43
[FIL]
Member#: 203333
2009 Impreza
Dark Grey
Question
Is it possible to put 04-07 sti brembos onto my 09 2.5i ? is there an adapter? Do i have to change the spindle ?
Thanks
[FIL] is offline   Reply With Quote
Old 02-26-2009, 04:04 AM   #44
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
^ 04 STis were 5x100 bolt pattern, so you can use them on your Impreza. Otherwise, the others were 5x114.3, and will require a spindle change.
Carter is offline   Reply With Quote
Old 05-11-2009, 11:38 AM   #45
andrewt461
Member#: 70647
2004 WRX
is there a recommended how to for steering rack install?
andrewt461 is offline   Reply With Quote
Old 05-11-2009, 11:56 AM   #46
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
There was this one put together by fullerton
http://forums.nasioc.com/forums/show....php?t=1489453
You may also find nhluhr's rack bushing vid useful (stickied above)
UkNuck is offline   Reply With Quote
Old 05-15-2009, 02:09 PM   #47
undertow
Member#: 11289
That blue color
Default Rear rotors
I have an 02wrx, and the handbrake is on the rear. Is there anything special that needs to be done when changing the rear rotor? Is the handbrake (which is a drum I would imagine) going to uncoil on me if I take out the rear rotor?
TIM
undertow is offline   Reply With Quote
Old 06-10-2009, 12:35 AM   #48
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
SPT brake line swap instructions. Includes bleeding directions and ABS sequence control instructions for those that have the plug. (06 does not appear to)
http://techinfo.subaru.com/html/down...rake_Hoses.pdf
turboICE is offline   Reply With Quote
Old 06-11-2009, 02:29 PM   #49
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Originally Posted by ButtDyno View Post
Steering installations:
Steering rack bushing install video (nhluhr):
http://wrx.grapon.com/multimedia/Bushings_wmv.wmv
Including me there is at least three occurrences of Steering Angle Sensor errors after changing the rack bushings on 06-07 STi's. Mine occured even though the battery was disconnected and I marked the column and rack.
http://www.iwsti.com/forums/drivetra...ing-green.html
There is also a spattering of other instances of SAS errors when doing mods around the steering column. Faulty SAS causes problems for both DCCD and VDC systems and is a $300 part. Be aware of it and tape and mark positions when working on the steering.
Old 07-08-2009, 07:28 AM   #50
ALLAN SOUTH
Member#: 216520
I have problems removing the rear disc on my o3 Legacy- I have taken caliper off of course and loosed the parking brake toggle , I can not get the diswc to move.
ALLAN SOUTH is offline   Reply With Quote
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING! Butt Dyno Brakes, Steering & Suspension 5 04-09-2008 11:25 AM
ssautochrome install walkthrough? Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2006 06:46 PM
kyb agx and spring install walkthrough?? CXspeed Newbies & FAQs 4 05-09-2006 10:45 AM
Boost Gauge Install Walkthrough? Uncle Ben Electrical & Lighting 4 07-15-2003 04:31 PM
