Old 07-23-2009, 02:48 AM   #51
JDAspenW02
Member#: 179875
2006 WRX
CGM
is there a How-to Brake pad install for 06+ wrx?
JDAspenW02 is offline   Reply With Quote
Old 08-29-2009, 07:48 PM   #52
piecemealBHC
Member#: 106248
2015 WRX CWP
2000 RS 2.5
Check out this thread:
http://forums.nasioc.com/forums/show...lacement+4+pot
a few other things I learned in the process (if you didn't know already):
-if you are doing rotors too, and they are stuck on, you can put some screws into the 2 threaded holes in the rotor to help break it loose from the hub
-be very careful with the pin spring (holds the pins in)... very easy to break/bend
-don't trust the guy at your local auto parts store to get you the right parts... I came home thinking I was all set to go and was just about to replace the pads when I noticed the ones I purchased were for 2005-earlier (non-4-pot). Further research revealed the rotor wouldn't fit either. Unfortuneately the store was closed for the weekend once I noticed this.
-avoid letting air in through the M/C or you could run into issues with the ABS pump.
piecemealBHC is offline   Reply With Quote
Old 10-08-2009, 01:50 AM   #53
illiusionz
Member#: 225836
Default Rear Strut Mounts and Stablizer links
can anyone post how to replace the rear strut mounts and stabilizer links??..the Subaru dealership wants to charge me about $600 for the job. I rather just buy the parts online and do it myself
illiusionz is offline   Reply With Quote
Old 10-18-2009, 04:49 PM   #54
[27]
Member#: 9731
2k2 wrx '13 Audi S4
Midnight Gray
im having issues finding a tutorial on rebuilding calipers, did i miss something in here?
[27] is offline   Reply With Quote
Old 10-18-2009, 05:56 PM   #55
BIGSKYWRX
Member#: 7958
09 GH B+
there is a four pot rebuild thread floating around- it's a very similar process for sliders and Brembo's
Old 10-24-2009, 12:05 PM   #56
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Does anyone have any writeups for Wheel Bearings or Tie Rods?
BeBop86 is offline   Reply With Quote
Old 10-28-2009, 10:41 PM   #57
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
wheel bearing write-up: http://forums.nasioc.com/forums/showthread.php?t=787070
nkx is offline   Reply With Quote
Old 02-15-2010, 12:23 AM   #58
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Old 03-04-2010, 02:39 AM   #59
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Just wondering what steering rack are interchangeable for what years. Also any advantages for swaps from newer to older years.
crpwrx is offline   Reply With Quote
Old 03-09-2010, 11:36 AM   #60
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
2003 Corvette ZO6 400whp
The links to the two threads at scooby mods for brake rotor/pad replacement don't seem to be working... any other links for changin rotors/pads on an 07 STi?
DC5edSTI is offline   Reply With Quote
Old 03-10-2010, 12:31 PM   #61
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
Pads and Rotors:
http://www.iwsti.com/forums/how-inst...e-updated.html
Pads (vid)
http://www.hspn.tv/?do=showtag&videoid=44&tagid=18
PS your car looks good (I think it's you, on rt. 58?)
Longshot55 is offline   Reply With Quote
Old 03-11-2010, 12:03 PM   #62
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
Originally Posted by Longshot55 View Post
Pads and Rotors:
Pads (vid)
Thanks for the links and thanks for the compliment.... yea I'm the SWP STi that lives on rt58.... have I seen you around... i've got a ****ty memory.
Old 03-11-2010, 12:55 PM   #63
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
no problem, maybe I work in Shelton so I'm up and down 58 every day. I think I saw you driving a lil while ago, waved, but no reply
Actually a week or two ago when it was nice out I think you and someone else who owns the s2k were outside with both hoods popped. I noticed as I had to slow down a ton for a slow moving bus in front.
Old 03-11-2010, 01:13 PM   #64
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
ohhh... I was probably zoning... i try to flash/wave at other scoobys when I notice them. What color is yours?
Yea the s2k owner is my room-mate.... do you post in the danbury thread>?
Old 03-11-2010, 01:45 PM   #65
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
lol I hear ya. I have an 05 CGM wrx with a black front mount and STi side splitters, wave if your not zoned out .
I don't typically post in the Danbury thread, I have a few times but I'm not a regular.
Old 03-13-2010, 08:41 PM   #66
TixArmy
Member#: 134248
2007 STi-Stage2 -RIP
"Desert Sand on White"
Thanks for starting this thread. It gave me all the info/courage I needed to install my SS Lines and bleed the system.
Much Appreciated!
TixArmy is offline   Reply With Quote
Old 04-12-2010, 02:26 PM   #67
Swindle1
Member#: 239341
98 2.5RS BDP
benms.com
I have a '94 Impreza L 1.8l, 2WD and I was wondering if there was any info on putting a sway bar on the rear end. I know there are kits and such for AWD Impreza's but I'm having trouble finding any info on 2WD's. Thanks.
Cory
Swindle1 is offline   Reply With Quote
Old 04-13-2010, 12:45 AM   #68
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Any info on steering rack interchangeability?
Old 04-14-2010, 12:40 PM   #69
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Cory
I'm not sure if there is any info out there. Its not something I recall seeing anywhere. I might have to do the same thing on a rally car build I'm helping a friend with. The best I can figure is that we'll need to weld some brackets in place and probably need to use wagon rear lateral links.
Scooby921 is offline   Reply With Quote
Old 07-07-2010, 08:39 PM   #70
ErikAnderson
Member#: 26739
Hi there, i have a 03 WRX with a bad power steering pump (it is leaking, and making a lot of noise). Does anyone have a writeup handy? (i searched, and will continue searching )
dealership wanted 800ish dollars for this, i figure it can't be that bad
Thanks in advance for any help.
ErikAnderson is offline   Reply With Quote
Old 07-12-2010, 09:11 AM   #71
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I've never seen one. I'm pretty sure any '02+ power steering pump will fit your car. You can occasionally find them for sale in the classifieds for ~$100.
Old 10-09-2010, 02:11 PM   #72
theboz32
Member#: 197221
2008 WRX VF48
EFI Logics Tuned!!!
Originally Posted by SUBYDOODIE View Post
any on how to change your brake rotors?
^^^^^ yes please
found it sorry guys
Last edited by theboz32; 10-09-2010 at 02:12 PM. Reason: i'm retarded sorry for the post i just saw it
theboz32 is offline   Reply With Quote
Old 10-30-2010, 01:26 AM   #73
trouble06
Member#: 215990
2006 WRX STI
grey
Any 'How to adjust e-brake' thread for a 06 STI?
trouble06 is offline   Reply With Quote
Old 10-30-2010, 07:44 AM   #74
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Two adjustments one at lever and one at the pads.
turboICE is offline   Reply With Quote
Old 12-09-2010, 04:06 PM   #75
rotelmuffin
Member#: 266556
2002 down and dirty
outback wagon
this seriously made replacing my suspension way easier than I thought it would be
rotelmuffin is offline   Reply With Quote
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING! Butt Dyno Brakes, Steering & Suspension 5 04-09-2008 11:25 AM
ssautochrome install walkthrough? Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2006 06:46 PM
kyb agx and spring install walkthrough?? CXspeed Newbies & FAQs 4 05-09-2006 10:45 AM
Boost Gauge Install Walkthrough? Uncle Ben Electrical & Lighting 4 07-15-2003 04:31 PM
