#1 |
Member#: 168106
South East
Vehicle:2002 aspen white 20g8cm |
ok i have the common boost oscillation, im going to loosen up the wastegate arm a half turn b/c i overboost to like 18 at first then fall to 12-13. im on a stage 2 map so it should be 16-17 , it could be just trying to compensate for the overboost, but if that doesnt fix it...im going to try to clean the bcs and check for the pill, is it ok to run without the pill in? and could i just use a mbc and set it at the appropriate boost level? it seems it would be easier... no boost leaks so far anywhere....i have a small exhaust leak where the header meets the uppipe..i dont think this has anything to do with it though.
#2 |
Member#: 168106
South East
its an 02 btw
#3 | ||
Member#: 123347
NWIC
Vehicle:1993 POS burgandy legacy |
<<<< you should fill out your profile Quote:
#4 |
Member#: 35107
Vehicle:2003 WRX WRB 2006 LGT Silver |
stock BCS? Also what are you running for EM? If you can tune yourself (enginuity for example) you would probably be better off tuning boost/wastegate instead of playing with the mechanical stuff.
#5 | |||
Member#: 123347
NWIC
first thing I did was the gm 3port solinoid http://forums.nasioc.com/forums/showthread.php?t=870619 then tuned it Quote:
read this http://www.cobbforums.com/forums/ima...mWorksv109.pdf |
#6 | |
Member#: 35107
#7 |
Member#: 123347
NWIC
well this thread got twited upside down
#8 |
Member#: 35107
| Thread Tools | |
| Display Modes | |
| Help with EWG install, BCS question!! | litowrx | Factory 2.0L Turbo Powertrain | 6 | 08-04-2008 04:25 AM |
| GM BCS Question regarding my TiAL 44mm EWG | dexterous | Engine Management & Tuning | 24 | 05-21-2008 06:55 PM |
| restrictor pill/bcs question | WILLFUTHEGREAT | Factory 2.0L Turbo Powertrain | 1 | 12-27-2007 01:42 AM |
| GM bcs question with pid boost | Beeya | UTEC | 2 | 04-23-2007 04:48 PM |
| stock BCS questions | smackedownz | Factory 2.0L Turbo Powertrain | 3 | 08-06-2006 07:13 PM |
