Old 01-20-2008, 11:07 PM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Engine won't idle after engine install
I just finished installing my new engine. I have a gruppe-s built shortblock, diy ported heads, cosworth cams, perrin gt30r kit w/ perrin el header, modded injectors, walbro fuel pump, tvg deletes, and alot of other crap. I tune w/ enginuity and have a datalog if anyone is interested in looking at it. I programmed all of the idle maps with 2000 rpm for cam break-in.
The symptoms are that it seems to be starving for fuel. With engine running, it trys to idle but lower than 2000 rpm. I have correct fuel pressure. I noticed that the front oxygen sensor does not change from 14.7 afr even when the engine is not running w/ the key on. The resistance and current do not change which is strange when the car is running. 0.00 amps & like 255 ohms. There is also zero change in the fuel trims which is also very strange.
Before the built block and heads, I had stock heads and block along with the walbro fuel pump, modded injectors, and perrin gt30r kit w/ header. It ran fine with my personal tune.
I did not change any timing maps or fuel maps (i didn't think it was needed to get the motor started and cams broken in), only the idle map values. I don't have any check engine lights either. I was thinking maybe a intake manifold vacuum leak, but my boost gauge shows plenty of vacuum and I still think it has something to do with the oxygen sensor.
Any insight would be much appreciated.
Jonathon
wittmer25 is offline   Reply With Quote
Old 01-21-2008, 11:51 AM   #2
wittmer25
Member#: 102970
2004 STi gt30r
Bump for help on no fuel correction. What controls fuel correction other than input from the oxygen sensor and engine load/speed? The afr should be around 21 when the engine is not running but the key is in the on position. Why would it stay at 14.7?
Old 01-21-2008, 12:10 PM   #3
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Your front O2 is broken, unplugged or something. It should never read only 14.7. This is why your car is behaving like it is. Log AFC #1 and AFL #1. If AFC #1 is 0, then it is the O2 (this thing should bounce all over the place rapidly all the time when in closed loop).
Gabe
gabedude is offline   Reply With Quote
Old 01-21-2008, 01:40 PM   #4
wittmer25
Member#: 102970
2004 STi gt30r
Thats what I thought. It says the same thing when its unplugged. Guess I will be getting a new 02 sensor.
Old 01-21-2008, 03:14 PM   #5
wittmer25
Member#: 102970
2004 STi gt30r
I had another thought. Doesn't the ecu disregard the front O2 sensor during cold start up? Maybe I need to adjust the warm up fuel enrichment map due to the cosworth cams (high lift & duration)?
Old 01-22-2008, 12:57 AM   #6
wittmer25
Member#: 102970
2004 STi gt30r
nevermind... I got it fixed. I had originally had my MAF housing located farther away from the turbo. During my engine install I relocated it closer to the turbo but did not change my mafV vs airflow map.... and I had a vacuum line loose. opps, I know... classic rough idle, engine starving for fuel symptoms due to loose vacuum leak. Anyway, its all good now... the cams sound bad a$$!
Car won't idle after new clutch put in? Redemption Service & Maintenance 1 02-10-2010 12:10 PM
Car won't start after engine replacement... rickeolis AccessPort 4 08-07-2007 11:47 PM
Engine won't start after AP conversion to 2005 balrog AccessPort 6 06-11-2007 05:40 PM
HELP - Car won't start after turbo install Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-30-2005 09:23 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-12-2001 12:35 AM
