#1 |
Vendor Sales Rating: (21)
Member#: 33839
South East
Vehicle:2002 WRX Black |
PARTS IN STOCK UPDATED
If stuff is not on the list below we will need to air freight it in for you. ***PLEASE PM IF YOU WOULD LIKE TO PLACE AN ORDER*** APS Part # and Quantity in stock Tube headers equal length, polished stainless steel to suit US Spec STI (up pipe required) APS SSTI-EMK/02 = 5 Stock position turbine inlet (up pipe) 321 Stainless Steel cat delete with 321 SS flex section - to suit APS headers APS SSTI-TIP/07 = 5 Billet Fuel Rails All pre-assembled teflon/ss lines, steel fittings. -Side feed injectors APS STI-FRP/01 = 5 Heat Shields to suit APS Headers APS STI-HKS/01 = 5 Conversion Kit- Permits simple installation of any APS FMIC to 06/07 models APS WRX-FMI/CK = 5 DR725 Front Mount Intercooler Massive bar and plate core 4.5" Thick. Rated to 725+ HP Specify BLACK************ finish APS WRX-FMI/R4 = 10 DR725 Front Mount Intercooler Massive bar and plate core 4.5" Thick. Rated to 725+ HP Specify SILVER************ finish APS WRX-FMI/R4 = 2 DR525 Front Mount Intercooler. Serious bar and plate core. 3.25" thick. Rated to 525HP Specify BLACK************* finish APS WRX-FMI/R6 = 25 DR525 Front Mount Intercooler. Serious bar and plate core. 3.25" thick. Rated to 525HP Specify SILVER************* finish APS WRX-FMI/R6 = 2 APS 65MM Cold Air Intake for Subaru APS WRX-HFA/01 = OUT Compressor Inlet Duct -3" ID hose/tube construction APS WRX-CID/01 = OUT Dual Vent Blow Off Valve, Direct bolt on to any top mount intercooler APS 995-047-000 = 10 APS 70MM Cold Air Intake for Subaru APS WRX-HFA/02 = 10 Turbo back exhaust system, 3" polished 304 stainless steel tube, flanges, TIG welded - single 4" tip - 95 DB APS WRX-HOE/R1 = 10 Dual vent blow off valve direct bolt on. Protect turbocharger at high boost levels. Improves engine response on gear change APS 590-047-000 = 5 Turbo back exhaust system, 3.5" polished 304 stainless steel tube, flanges, TIG welded - single 4" tip - 100 DB APS WRX-HOE/R5 = 5 Top Mount Intercooler. Bolt on bar and plate replacement for stock unit. Rated to 375hp Suites all driven and thottle by wire vechicles. APS WRX-TMI/06 = 5 TSR70 Turbo System- split scroll turbocharger, split scroll up-pipe, tial wastegate 3.5" turbine outlet pipe to any APS exhaust, all hoses/fittings included. 700hp (flywheel) APS WRX-RMT/03 = 5 Tumbler Valve Delete provides provision for auxillary injector mouting. Top feed injector -No tuning re. APS WRX-TDI/01 = 10 Billet 5/8" ID Rails regulator mouting block. All pre-assembled teflon/ss lines, steel fittings. -top feed injectors APS WRX-FRP/03 = 5 3" flanged act converter, high flow, high temperature - suits all 3" APS systems APS 995-019-200 = 2 High FLow Cold Air Intake, Rotated Mount Turbocharger NC Machined. 65/80mm ID APS WRX-HFA/R9 = 5
#5 |
Member#: 33839
South East
PM Sent - everything on the list is in stock and will ship today
![]() Chris, Thank you for the order - I look forward to seeing the pictures on teh car!! my email is jb@slowboyracing.com - shoot them over when you get it! Last edited by Built Industries; 01-22-2008 at 12:51 PM. |
#7 |
Member Sales Rating: (13)
Member#: 134821
E. Canada
Vehicle:2006 STI OBP |
Hi,
Please pm me pricing for the DR725 and DR525, black, FMIC kits. Plus, the conversion kit listed as this will go on an 06 STI. Also, I have a set of APS equal length headers, can you provide info. and pricing on the heat shields you mentioned. Thanks. |
#20 |
Member#: 33839
South East
I believe we only have the 3" one here, sorry about that.
Could you guys do me a favor and post some pics when you get your stuff! - I'd like to put some new ones up on the website of customer's cars! |
#24 |
Member#: 33839
South East
PM Replied to - to speed things up a little bit if you guys are ready to order, just shoot me your phone# in a PM and we will ship the parts out same day
| Thread Tools | |
| Display Modes | |
| These Lips dont do much talking! Come see what we have! | RallySport Direct | RMIC Vendor Classifieds | 4 | 01-25-2010 10:50 AM |
| These Lips dont do much talking! Come see what we have! | RallySport Direct | Exterior/Styling | 2 | 01-08-2010 06:31 PM |
| wtb: parts needed!!!!! check the list to see what you have to sell | jakesurfin | Private 'Wanted' Classifieds | 8 | 02-03-2009 02:30 PM |
| wtb: i need parts.....check to see if you have these to sell! | jakesurfin | TXIC Private Classifieds | 2 | 02-01-2009 07:37 PM |
