Old 01-21-2008, 01:53 PM   #1
Zumble
Member#: 34860
2005 Forester CGM
Default Problem is enginuity logging
I get the following error when I try to log with enginuity
Error: einguity.logger.exception.InvalidResponseException : Invalid header. Expected:80 Actual:00
My ROM is a street tuner rom though. I've used enginuity to edit the rom in the past since flashing with ecuflash is sooo much faster than using the AP1 to flash.
Zumble is offline   Reply With Quote
Old 01-22-2008, 12:38 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
bump.. anyone?
Old 01-22-2008, 03:34 PM   #3
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Try un-installing Enginuity, then make sure all files are deleted (not your roms). Then re-install software and see if that helps.
icslowmo is offline   Reply With Quote
Old 01-23-2008, 04:39 PM   #4
Tea cups
Member#: 103136
What OS? The only time I've heard of this message before, I think, is when using non-U.S. number format in your regional settings (for example, "," in place of "." for the decimal place). I would also make sure you have the latest version official release of Enginuity (0.4.1b).
Tea cups is offline   Reply With Quote
Old 01-23-2008, 04:41 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
This is Windows XP Professional SP2 and it is Enginuity 0.4.1b. Not sure what you mean about the regional settings.
Old 01-23-2008, 04:47 PM   #6
Tea cups
Member#: 103136
in the control panel -> regional and language options. should be english (united states).
Other than that, you should have no problem with Enginuity's logger. What cable are you using? It won't work with AP v.2 cable, maybe with AP v.1. Make sure you install the latest java runtime.
Old 01-23-2008, 04:49 PM   #7
Zumble
Member#: 34860
2005 Forester CGM
Have the latest java. I'm actually using a Openport 1.2 cable. Just checked regional settings and they are correct.. I just realized that my thread subject title is retarded. Oh well.. hahaha.
Old 01-23-2008, 04:51 PM   #8
cooter
Member#: 23258
2005 STi
I've had this issue before depending on what parameters I'm trying to log. What all parameters are you trying to log? Try unchecking a few of them. The one that was causing a problem for me that comes to mind was either engine load (g/rev) *direct or MAF voltage *direct (didn't have a problem with the "calculated" version of either parameter).
*shrug*
cooter is offline   Reply With Quote
Old 01-23-2008, 04:57 PM   #9
Zumble
Member#: 34860
2005 Forester CGM
AHHH! Thats interesting. I do have some *direct values checked. What's the difference between the direct values and the non direct values?
Old 01-23-2008, 05:17 PM   #10
Tea cups
Member#: 103136
Make sure you update to the latest logger defs (0.3.2b). If there is an issue with a particular extended parameter (ends with *), then let me know as there may be an error in the definitions for your particular ecu.
Old 01-23-2008, 05:21 PM   #11
Zumble
Member#: 34860
2005 Forester CGM
I'll make sure to load the latest def. I have a FXT so I wouldn't be too surprised if there was a problem with the def and nobody noticed it. I'll keep you posted. I would really like to log with enginuity because the logger is so much nicer than the ST logger.
Old 01-29-2008, 10:13 AM   #12
Zumble
Member#: 34860
2005 Forester CGM
It turns out the problem is a combination of logging parameters. I'm not able to log MRP Corrected or Direct and some other features.
Old 01-29-2008, 10:37 AM   #13
Tea cups
Member#: 103136
Probably what happened is that you selected both of the following:
"Manifold Absolute Pressure (Direct)"
"Manifold Relative Pressure (Direct)"
both of these are based off of the same address (absolute pressure) with the MRP (direct) simply removing 1 atmosphere (14.7 psi making the assumption of sea level). I think I'll combine these two parameters for the next logger release to avoid this in the future.
Old 01-29-2008, 10:54 AM   #14
Jon [in CT]
Member#: 2992
02 WRX Sedan
Ambient pressure is rarely exactly 14.7 PSI, even at sea level. When calculating the parameter "Manifold Relative Pressure (Corrected)" the actual ambient pressure (parameter P24) is used in the calculation. Why can't this be done for "Manifold Relative Pressure (Direct)" as well?
Jon [in CT] is offline   Reply With Quote
Old 01-29-2008, 11:05 AM   #15
Tea cups
Member#: 103136
I realize this, however Enginuity's logger doesn't allow you to use derived (reference) parameters consisting of both extended and standard parameters otherwise I would have done it this way. It may allow for derived parameters with extended parameters alone (haven't tried this). If that is the case, then I could add atmospheric pressure as an extended parameter, but then MRP (Direct) would be pretty costly (8 bytes 32-bit ECU) compared to 5 bytes if I could use standard AP.
Note: That although AP at sea level is rarely exactly 14.7 psi, the standard ECU definitions calculate relative pressure this way for Target Boost (the ECU deals primarily with absolute pressure), so at least this parameter would match the table, although it would not give you an accurate relative pressure.
Old 01-30-2008, 09:31 AM   #16
Zumble
Member#: 34860
2005 Forester CGM
Nope, not logging both. I really don't care much about absolute pressure. I'm at sea level so 14.7 on top of whatever the relative pressure is I always assume.
Old 01-30-2008, 09:39 AM   #17
Tea cups
Member#: 103136
Make sure you aren't logging a ton of parameters. Extended parameters for the 32-bit ECU are more costly in the number of bytes transmitted, so you can reach the limit the fast if you are logging a lot of these. Usually, though, the logged values will freeze when you hit the "limit".
If that is not the case, then let me know exactly which parameter is causing the issue (or combination of parameters) and your rom id and I can check the definitions.
Old 01-30-2008, 10:01 AM   #18
Zumble
Member#: 34860
2005 Forester CGM
I'll take not next time I use the logger. I did finally get a useful log from the enginuity logger last night.
I'm going to PM you about a issue I'm having with the knock correction tables.
enginuity log questions nhat Commercial ECU Reflashes 10 10-24-2007 01:16 AM
Advise on enginuity log JOWANKEL Engine Management & Tuning 21 10-05-2007 06:23 PM
Advise on enginuity log JOWANKEL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-05-2007 01:00 PM
Enginuity logging with AP cable/adapter? NorCal06STi Commercial ECU Reflashes 1 04-17-2007 08:14 PM
Stalling Problem - Look @ my Enginuity Log runvusofme Engine Management & Tuning 3 01-26-2007 02:35 AM
