Old 01-21-2008, 04:00 PM   #1
csmith335
Member#: 150530
Default Prosport oil pressure and temp
I posted about this a bit earlier but got a bit confused so i decided to ask in a more simple way...
When you are hooking up Prosport oil presure and oil temp gauges to the oil gallerys on the block, do you need the aftermarket oil gallery plug for both of the gauges or just one.
Please let me know so that i can order the correct stuff the first time.
Oh yea, this is on a 02 wrx..thanks to all!!
csmith335 is offline   Reply With Quote
Old 01-21-2008, 04:41 PM   #2
dru_hill
Member#: 67661
2004 WRX sedan
I think both. Buy 2 just in case, they are cheaper than taking all that crap apart again.
dru_hill is offline   Reply With Quote
Old 01-21-2008, 04:44 PM   #3
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Just get the donut adapter that goes where your oil filter goes, easier to get to, and has the same effect.
camshaft06 is offline   Reply With Quote
Old 01-21-2008, 04:46 PM   #4
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
But if you are doing both, you need two sensors, one for the oil temp, and another for the oil pressure. They are different sensors.
Just get the donut, and thread them in there and screw it on. less things to go wrong IMHO.
Old 01-21-2008, 04:51 PM   #5
csmith335
Member#: 150530
thanks dru_hill and camshaft! i cant wait to get them hooked up
Old 01-21-2008, 04:57 PM   #6
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Correct term sandwich adapter. Prosport has them on their site and they have 2 connectors on it IIRC you can get both Pressure and temp on the adapter.
I was just looking at them I think its alot better than the galley plug.
Sandwich Adapter
Galley Plug
Oil Pressure Sender
Fully hooked up
4ST-AIR is offline   Reply With Quote
Old 01-21-2008, 05:02 PM   #7
csmith335
Member#: 150530
i do agree 4st-air, looks like much less of a pain. one more question, i am also getting a water temp gauge with the billet water temp adapter from fastwrx.com. you have to cut the radiator hose and insert this piece, i was just wondering if it should be fine to use the upper hose?
Old 01-21-2008, 05:22 PM   #8
csmith335
Member#: 150530
and also in the pick of the fully assembled sandwhich adapter, is that the oil temp wires hooked up next to the oil pressure sensor?
Old 01-21-2008, 10:04 PM   #9
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Sandwich Adapter
Galley Plug
Oil Pressure Sender
Fully hooked up
That's what I meant....I just missed lunch and I must have been hungry! I like donuts! But that is what I was refering to there. I have had no problems with mine, and it was easy to do
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
Oil pressure and temp at oil filter aakrusen Newbies & FAQs 9 01-19-2009 07:43 AM
FS: DEFI link gauges, green/black, 52mm Oil pressure and temp, and EGT lotusdrift MAIC Private Classifieds 8 08-12-2008 02:55 PM
FS: DEFI link gauges, green/black, 52mm Oil pressure and temp, and EGT lotusdrift Interior/Dressup/Audio & Security 7 08-12-2008 08:42 AM
want an oil cooler but already using a sandwitch adapter for oil pressure ands temp.. mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-19-2006 03:43 PM
