Old 01-21-2008, 05:55 PM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
OMGHi2U "Built Motor Discussion" Links to Great Threads
Hey everyone. Here is a good compilation of reading material for when you get bored and want to read up on Subaru engines.
These are just some threads that I thought were great reading and have some very, very good information inside.
If you have a link bookmarked or know of one that you think should be added to the list...just post it up or PM me and I'll add it to the list!
Thanks and enjoy reading!
INTAKE/EXHAUST MANIFOLD
Exhaust pulses and big turbo spool - Theories
http://forums.nasioc.com/forums/show....php?t=1390611
aftermarket intake manifold
http://forums.nasioc.com/forums/show....php?t=1227220
OILING
*Looking for a Crankshaft? List of Crank Manufacturers*
http://forums.nasioc.com/forums/show....php?t=1890852
Available oil pumps and part numbers
http://forums.nasioc.com/forums/show....php?t=1176430
12mm oil pump: feedback, concerns, open discussion and the like wise
http://forums.nasioc.com/forums/show....php?t=1433697
Oiling system: More volume to the crank/rods
http://forums.nasioc.com/forums/show....php?t=1420864
@ what point is STI oil pump not good enough?
http://forums.nasioc.com/forums/show...ghlight=oiling
Improving the 257's crankshaft
http://forums.nasioc.com/forums/show...ing+crankshaft
Downfalls of the oem oiling system for high rpm engines?
Cross-drilling our crankshafts?
Engine failure due to ECM?
http://forums.nasioc.com/forums/show....php?t=1406883
Crankshaft Question
http://forums.nasioc.com/forums/show....php?t=1720557
PISTONS
Real Reason for Forged Piston Clearance? Thermal Expansion Not Enough.
http://forums.nasioc.com/forums/show....php?t=1061799
Piston FAQ: Read if you are thinking about buying them!
http://forums.nasioc.com/forums/showthread.php?t=907570
Mahle vs stock sti piston & pin weight information
http://forums.nasioc.com/forums/showthread.php?t=999055
*Discussion* Why has a higher compression ratio been a bad idea on a turbo car?
http://forums.nasioc.com/forums/show....php?t=1228477
piston dish comparison...
http://forums.nasioc.com/forums/showthread.php?t=964607
EJ22T Piston squirters...are they serviceable?
http://forums.nasioc.com/forums/show....php?t=1174798
RODS
crower or pauter rods ????
http://forums.nasioc.com/forums/show...ghlight=pauter
Pauter Rods EDM pressure-fed oiling to pin is it worth it?
********The *Official* Connecting rod weight compilation thread ********
http://forums.nasioc.com/forums/show....php?t=1902135
The *OFFICIAL* Long Rod discussion: pro's, con's who uses them and WHY
http://forums.nasioc.com/forums/show....php?t=1181857
Cobb Rods
http://forums.nasioc.com/forums/show...highlight=rods
Subaru RODs: Forged??
Need Builders Opinion On Rods!
http://forums.nasioc.com/forums/show....php?t=1397260
Eagle rods - Any good ?
http://forums.nasioc.com/forums/showthread.php?t=817085
Titanium rods and big power...
CAMS/SPRINGS
Compilation of valve spring options
http://forums.nasioc.com/forums/show....php?t=1555787
HOW TO: (w/ pics) STI cams in WRX heads
http://forums.nasioc.com/forums/show....php?t=1356918
DPR valvesprings can't handle lift, worse than STI
http://forums.nasioc.com/forums/show....php?t=1220672
Analysis of Cosworth AVCS cams vs USDM STI cams
Maximum AVCS Advance w/ Cosworth cams?
http://forums.nasioc.com/forums/show....php?t=1423635
2.0l to 2.5l swap, and what AVCS means to you
http://forums.nasioc.com/forums/show....php?t=1194269
Supertech Valvetrain and Mild Porting
http://forums.nasioc.com/forums/show...hlight=porting
HEADS
Head ports comparison
http://forums.nasioc.com/forums/showthread.php?t=903873
AVCS Heads on Non-AVCS blocks.
http://forums.nasioc.com/forums/show...ighlight=heads
Assembly: 2.0L Heads on 2.5L block
http://forums.nasioc.com/forums/show...assembly+heads
Cosworth Heads Vs. Everyone Else
THE Best Full Service Subaru Head Shop
http://forums.nasioc.com/forums/show...highlight=HEAD
DIY PNP Heads?
http://forums.nasioc.com/forums/show...&highlight=DIY
DIY ported WRX heads
Port and Polished heads
http://forums.nasioc.com/forums/show...highlight=port
Double-D Series head ports!!!
http://forums.nasioc.com/forums/show....php?t=1728481
MACHINING
Torque Plate Vs. Non Torque Plate Motor
http://forums.nasioc.com/forums/show....php?t=1899408
Torque Plates
http://forums.nasioc.com/forums/show....php?t=1659712
Builders who use torque plates
http://forums.nasioc.com/forums/show...ight=machinist
Thoughts on main bearing clearances...
Torque/hone plate is necessary when boring!
Whats needed for torque plate honing?
What to look for in a machinist / engine builder? Choose A, B, C, or D.
http://forums.nasioc.com/forums/show....php?t=1136374
Crankshaft balancing and counterweights
http://forums.nasioc.com/forums/show...ght=crankshaft
To Sleeve or not....
D.I.Y
Tearing down a block - A pictorial. Includes head removal.
http://forums.nasioc.com/forums/show....php?t=1435733
DIY: Pull your own motor. Lots-o-pics
http://forums.nasioc.com/forums/show....php?t=1301065
Talk me out of swapping pistons on my own.
DIY Closed-Deck
How To: DIY TGV Deletes
http://forums.nasioc.com/forums/show....php?t=1165948
MISC
Rallispec Street spec shortblock.
http://forums.nasioc.com/forums/show...6#post29236906
Is 1000 WHP possibly and how?
Has anyone hit 1000+ WHP on any EJ motor?
http://forums.nasioc.com/forums/show....php?t=1370387
catastrophic engine damage w/pics!! Expert opinions wanted..
Tony's 2.5 Hybrid Swap Thread
http://forums.nasioc.com/forums/show...ghlight=hybrid
My hybrid build on a budget...
http://forums.nasioc.com/forums/show...ghlight=budget
Built motor guys who have aquired significant milage
http://forums.nasioc.com/forums/show....php?t=1798862
FUEL
What Fuel pumps are people using on their 525+whp
http://forums.nasioc.com/forums/show....php?t=1228437
EJ255 vs. EJ257 FACTS:
EJ257 vs EJ255 facts with pictures
http://forums.nasioc.com/forums/show....php?t=1667168
modaddict is offline   Reply With Quote
Old 01-21-2008, 10:02 PM   #2
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Great thread Mod! A LOT of good info here to keep you reading(and learning) for hours!!!
crazyGC8 is offline   Reply With Quote
Old 01-21-2008, 10:03 PM   #3
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I had several of these bookmarked before starting my engine build, but not all. Now I do. Thanks.
beaviscih is offline   Reply With Quote
Old 01-21-2008, 10:07 PM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Personally, I'd like to see this stickied at the top of the forum for many future references.
Old 01-21-2008, 10:12 PM   #5
crazyGC8
Member#: 107421
I think this is definately sticky material...
Old 01-21-2008, 11:08 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
nice compilation there! I approve
jigga is offline   Reply With Quote
Old 01-21-2008, 11:09 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I too think this should be stick worthy...
Old 01-21-2008, 11:57 PM   #8
Nilesh
Member#: 126987
Sticky!!
Nilesh is offline   Reply With Quote
Old 01-22-2008, 01:58 AM   #9
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
I have a few that might be worth adding...
http://forums.nasioc.com/forums/show....php?t=1085359
http://forums.nasioc.com/forums/show....php?t=1082001
Hopefully I didn't miss one of these above
lancelucas is offline   Reply With Quote
Old 01-22-2008, 10:51 AM   #10
Paulys05wrx
Member#: 82433
2005 STi EFR 6738 &
WRX EFR 8734 Twin Scroll
Congrats on the sticky. Very helpful
Paulys05wrx is offline   Reply With Quote
Old 01-25-2008, 02:27 PM   #11
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I Added more and changed the layout.
We've had some good discussions during the last handful of years.
Old 03-17-2008, 11:26 AM   #12
Subaru97
Member#: 174787
97 Impreza
Red
Excellent full of useful; info...ill be using this as a refernce alot lol
Subaru97 is offline   Reply With Quote
Old 04-04-2008, 06:17 AM   #13
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
I'm proposing this thread. Very informative and would be a great addition to the "Built Motor Discussion" Links to Great Threads.
Basic head porting/5 angle valve job. Gains? -----> http://forums.nasioc.com/forums/show....php?t=1483886
Kosmic is offline   Reply With Quote
Old 04-04-2008, 12:48 PM   #14
charliew
Member#: 125304
Except the one from Shaggy about the supertech valves and porting, WHAT A WASTE OF TIME all that shows is too much talk and not enough knowledge and eyesight.
Charliew
charliew is offline   Reply With Quote
Old 04-04-2008, 02:24 PM   #15
Einimas
Member#: 176111
My hybrid build on a budget... link broken?
Einimas is offline   Reply With Quote
Old 04-04-2008, 04:18 PM   #16
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Charliew
are you talking about the rest of the links?
Old 04-04-2008, 04:22 PM   #17
modaddict
Member#: 95840
sold to a good bud
awaiting next car
fixored!
dunno why some of those links have been randomly broken?
Old 04-04-2008, 10:15 PM   #18
Kosmic
Member#: 99140
GD Racing chassis
http://forums.nasioc.com/forums/show...ght=TGV+delete
For the broken "How To: DIY TGV Deletes" link.
Old 04-04-2008, 11:28 PM   #19
charliew
Member#: 125304
No they are all good except the one about supertech valvetrain and mild porting started by shaggy. There is nothing informative in the thread at all except how you can mess things up if you don't do good work and pay attention to details.
Charliew
Old 04-05-2008, 04:38 AM   #20
Einimas
Member#: 176111
Old 12-30-2008, 11:43 PM   #21
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
there needs to be a thread link in here to one of the many Break in theory ones.
Mr_Snips is offline   Reply With Quote
Old 02-18-2009, 11:34 PM   #22
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
i was wondering if there was a really good up to date FAQ on what kind of fuel systems people are using for their monster builds. I saw an old unabomber faq but most of the links are out of date or dead.
efmd3 is offline   Reply With Quote
Old 02-19-2009, 09:32 AM   #23
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Old 06-08-2009, 09:55 PM   #24
WRX Loki
Member#: 208332
06 Hawkeye Wagon
Red
The Link for Assembly: 2.0L Heads on 2.5L block
Is not working
WRX Loki is offline   Reply With Quote
Old 06-11-2009, 10:54 PM   #25
Bully-Perf.
Member#: 213589
Here are some flow numbers we got on a test head we did recently with stock valves.
http://www.wrxtuners.com/forums/f103...r-heads-26378/
Mike
Bully-Perf. is offline   Reply With Quote
The "Post a Link to Your Favorite Thread YOU Started" thread DrDRum Off-Topic 59 09-11-2008 11:01 AM
Anyone have a link to the thread where... Digitalfiend General Community 1 01-20-2008 11:21 PM
How to create a LINK to a thread? savka Newbies & FAQs 10 12-14-2001 12:17 AM
Links to good... er Great vendor pages..... subenutt General Forum Archive 7 01-04-2001 11:24 PM
Please help - Link to technical thread. Subu WEX General Forum Archive 1 09-03-2000 08:06 AM
