Old 06-14-2009, 03:25 PM   #26
charliew
Member#: 125304
Those numbers show that the lowlift was also improved which is very hard to do. What is the individual intake and exhaust port numbers and their variance? How much are the guides shortened? What is the price with new valves and springs complete? Can a customer send you his heads with everything removed and get completely assembled heads back? Do you realize those heads show as good or better than the flow numbers of a ported jdm big valve head? The idea for me would be to flow my stock heads and then take them apart and send them to you and get them back and reflow them on my bench to get a real idea of the improvement to my exact heads. I would expect the exact same perchentage of improvement to my heads as you show on yours for the price you charge. The numbers over 450 are not important. Unless there are some new cams I'm not aware of.
charliew is offline   Reply With Quote
Old 07-17-2009, 11:40 PM   #27
HSaftler
Member#: 217557
Check this out, my buddy completely modded his legacy gt. Its now at 550 hp. We're waiting to get an updated dyno test. Tail pipes are currently out cause of police!!
Anyways check it out
http://tinyurl.com/subaruonadyno
HSaftler is offline   Reply With Quote
Old 08-03-2009, 09:29 PM   #28
strohausii
Member#: 26770
'02 WRX
midnight black
Link to: Tony's 2.5 Hybrid Swap Thread seems to be dead in the water with no updates in 3 years, actually starting to turn into a lounge of sorts.
strohausii is offline   Reply With Quote
Old 11-27-2009, 10:52 AM   #29
modaddict
Member#: 95840
sold to a good bud
awaiting next car
This thread needs more update.
anything you know of..........post away.
modaddict is offline   Reply With Quote
Old 01-06-2010, 11:42 PM   #30
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
FuJi K is offline   Reply With Quote
Old 01-07-2010, 08:54 AM   #31
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Cause I have never seen it!
I'll take a look after work (blocks pics). And add it to the list.
Got anymore fuji?
Old 01-07-2010, 09:13 AM   #32
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It's cut away pics of Subaru heads. Like how they cut the heads in the middle of the ports showing how much meat you have between the port and the water passages...etc. Good for people who want to port. But I want it to be cut up more so I can see places that are on the sides... not just the top and bottom.
humm...... Time to look at piston ring gapping??? There arn't any good ones, but I did find a few. There are a lot more people doing their own engine builds now so ring gaps and oil clearance threads will soon come more and more.
Old 01-20-2010, 09:18 PM   #33
jogfrogjog
Member#: 43421
2004 STi Wagon
the 2.0 heads on 2.5 link doesn't work.
jogfrogjog is offline   Reply With Quote
Old 01-20-2010, 09:33 PM   #34
modaddict
Member#: 95840
sold to a good bud
awaiting next car
fickzed
Old 02-06-2010, 03:21 PM   #35
Pecosdude
Member#: 93033
- SG5 & GVF
Any plans to include direct links to valves (or oversize valves)?
I have been using this guide for my rebuilt.
Just receive a supertech +1mm oversize valves.
I came back to this guide to expedite search.
Was surprise when I could not find a direct links regarding valves.
Thanks.
Pecosdude is offline   Reply With Quote
Old 02-06-2010, 03:47 PM   #36
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Thanks.
You got a thread in mind that has various valve options?
Old 02-06-2010, 11:12 PM   #37
Pecosdude
Member#: 93033
- SG5 & GVF
Top choice:
Flow Data? .5mm vs 1mm oversized valves and/or porting?
http://forums.nasioc.com/forums/show...ghlight=valves
Maybe acceptable (subject to your review):
Supertech valves choices
problem with my ferrea valves
Not sure:
Port & Polish VS. Just Oversized Valves
Old 02-22-2010, 09:08 PM   #38
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
add this link in. Great calculator site.
http://www.wallaceracing.com/Calculators.htm
Old 02-22-2010, 10:15 PM   #39
CatfaceType-R
Member#: 81102
How to read a spark plug from, with pictures
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
CatfaceType-R is offline   Reply With Quote
Old 04-13-2010, 06:32 AM   #40
bluesubiaz
Member#: 151049
Exclamation Cant find what Im looking for and not allowed to post my own question yet PLEASE HELP
I have built 5 motors from the ground up for my 02 wrx, every single one of them has failed due to low oil pressure, with new oil pumps on all of them. I just recently came across a video on youtube of a race team doing a rebuild, and they say that the factory oil cooler once you spin a bearing all the shards of bearing go straight there and clogg it and it must be replaced. This is the one part I have reused on every motor, and it all makes sense now but i wanted to get some other opinions on the subject. if anyone reading this knows anything about this or can confirm it for me i would greatly appeciate it. Please leave me a PM.
Also I'm going to be boring my cylinders and sleeveing my block
but am undesided as to wet sleeve or dry sleeve once again please provide your opinoins.
Thank You
bluesubiaz is offline   Reply With Quote
Old 04-13-2010, 12:35 PM   #41
charliew
Member#: 125304
Think about it a little. The bearings go bad. Where do you think all the metal fragments go? In every gallery and low place throughout the motor especially the oil cooler and under the sheetmetal pieces in the pan. A filter does NOT stop the bypassed oil from moving all the trash throughout the motor including the cam saddles in the heads, the galeries in the heads the turbo and so on. In the case of the sti with cam timing control it settles in the pulleys cavities also.
Old 04-24-2010, 02:25 PM   #42
Tye 33
Member#: 244863
Default Thanks
Just forund this forum and trying to educate myself before asking a dumb question.
Roy
Tye 33 is offline   Reply With Quote
Old 06-19-2010, 04:23 AM   #43
Farnk
Member#: 91093
2002 Wrx
The DIY TGV delete link doesnt work
Farnk is offline   Reply With Quote
Old 06-23-2010, 02:41 PM   #44
Pericles
Member#: 249830
Excuse the newb question, but what is the maximum power that the old iron block motors are/were capable of?
Pericles is offline   Reply With Quote
Old 06-23-2010, 05:11 PM   #45
Pericles
Member#: 249830
Never mind....I just remembered it was the EVo motors that had the iron blocks.
Old 08-06-2010, 12:08 AM   #46
poowasu
Member#: 211540
1997 GC8 2.5 sti
Very useful foe newbie like me.
poowasu is offline   Reply With Quote
Old 11-05-2010, 07:18 AM   #47
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Subscribed!
rek888v2 is offline   Reply With Quote
Old 12-22-2010, 02:48 PM   #48
USMC-VET
Member#: 267912
2005 STI Stg. 2
1st legit reply
USMC-VET is offline   Reply With Quote
Old 12-22-2010, 02:48 PM   #49
USMC-VET
Member#: 267912
2005 STI Stg. 2
2nd legit reply
Old 12-22-2010, 02:49 PM   #50
USMC-VET
Member#: 267912
2005 STI Stg. 2
3rd legit reply...sorry
The "Post a Link to Your Favorite Thread YOU Started" thread DrDRum Off-Topic 59 09-11-2008 11:01 AM
Anyone have a link to the thread where... Digitalfiend General Community 1 01-20-2008 11:21 PM
How to create a LINK to a thread? savka Newbies & FAQs 10 12-14-2001 12:17 AM
Links to good... er Great vendor pages..... subenutt General Forum Archive 7 01-04-2001 11:24 PM
Please help - Link to technical thread. Subu WEX General Forum Archive 1 09-03-2000 08:06 AM
