Old 01-21-2008, 07:18 PM   #1
kalescustom
Member#: 147598
95 Impreza 2dr
Default tuning with meth newb questions
i just purchased my 1st meth injection kit.. i just had a couple of questions about tuning with the meth...
what afr's should i be running at full boost?
does the high oxygen content of the meth throw off the o2 sensor readings? ...
i know the more water to meth i run the cooler it will be, but how does that change the afr you can run safetly?
share your theory's on the subject...thanks
kalescustom is offline   Reply With Quote
Old 01-21-2008, 09:34 PM   #2
Ultimate Collision Center
Member#: 69072
afr's range quite a bit depending on the tuning style and the car's setup...do you have any logs?
Ultimate Collision Center is offline   Reply With Quote
Old 01-22-2008, 12:19 AM   #3
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
thats a personal preference far as safety goes but you can run a lot leaner than fuel alone I'd say .5 to 1 point leaner
no ,but it takes a lot more methanol than gasoline to get to a given lambda reading
my theory says that depends on out side air temperature
I run strait methanol in winter (less than 50f) as weather warms i add water up about 50/50 in summer
I let the afr go rich with the strait methanol (haven't logged in while can't remember specifics)and let the water take it lean in summer
a6n6d6y is offline   Reply With Quote
Old 01-22-2008, 08:12 AM   #4
kalescustom
Member#: 147598
95 Impreza 2dr
i do not have an logs yet... i am pretty much wondering what to expect...
im guessing as soon as i hook it up and go for a cruise, once i hit the selected boost pressure, my afr's will drop below 10's... so to be on the safeside, i will lean it back till i am right below 12 under full boost...
when is the best time to begin injecting... while boost is ramping up? just before peak boost?
Old 01-22-2008, 08:26 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
anywhere from 7psi to 12psi.
I think I'm going for 10psi.
akira02rex is offline   Reply With Quote
Hybrid Tune - Newb Question GLrunner13 Open Source Reflashes 5 10-22-2009 11:22 PM
Old poster with a Newb Question (too lazy to read my manual) rxer311 Newbies & FAQs 0 04-06-2008 10:55 PM
Newb with a newb question... dcon Newbies & FAQs 1 11-01-2007 07:21 PM
04 sti tuned with SMC Meth/water injection AZScoobie Proven Power Bragging 9 09-19-2006 09:21 AM
Tuning required for header install? Newb Questions DaBoxerman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-03-2006 02:21 PM
