Old 01-21-2008, 08:39 PM   #1
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
Default Help! Very Frustrated With 99 RS
ok the car is a 99 rs impreza, it just had the mass air go out and had to replace it, then it gave me a MAP Sensor CEL, I just now changed it(Yes it has a map sensor, I dont car what you tell me that it dont I just changed it on the passenger side by the strut) no CEL now but it bogs when you try to drive it, it acts like its under a heavy load, backfires and pops from the exhaust badly, and wont rev past 3500rpms, im very angry and frustrated with the car and Im about to just give up an sell it. I need help here please someone, its very stressful because I bought it because I like it so much but if its gonna be so problematic Im not gonna keep it, this all started right with the Mass Air went out
ScoobaruBoy is offline   Reply With Quote
Old 01-21-2008, 08:41 PM   #2
JLW2007RS
Member#: 162089
2008 G37S IPL
get a re-flash, programmable ECU and kill two birds with one stone, or, get a scangauge
JLW2007RS is offline   Reply With Quote
Old 01-21-2008, 08:50 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Did you clear and reset the ecu after you changed the sensors? I ask because it sounds like your car is still in limp mode. It may seem like a dumb question since many will assume that you disconnected the battery to change the sensors. I assume nothing...
Ps. Ignore the first reply. Your ecu isn't easily flashed like the new cars...
Old 01-21-2008, 09:28 PM   #4
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
i took the battery off for half an hour, then reconnected it all and let it idle for 20 minutes about then it started acting the same agian
Old 01-21-2008, 09:34 PM   #5
novacivic
Member#: 117980
2005 sti
wr blue
give it to me
novacivic is offline   Reply With Quote
Old 01-21-2008, 09:37 PM   #6
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
bring me $2900 and its yours
Old 01-21-2008, 11:06 PM   #7
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Is the CEL still on?
PhilSine is offline   Reply With Quote
Old 01-21-2008, 11:23 PM   #8
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
no, it hasnt come on
Old 01-22-2008, 09:53 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
to follow matt
spark plugs (if you haven't changed them in the last year) -cheap only use ngk
coil pack (put your hand on it while its riunning if you get an incredably bad shock it has a crack)
intake leak
Old 01-22-2008, 10:05 AM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Originally Posted by ScoobaruBoy View Post
....then it gave me a MAP Sensor CEL, I just now changed it(Yes it has a map sensor, I dont car what you tell me that it dont I just changed it on the passenger side by the strut) no CEL now but it bogs when you try to drive it,
There is a filter/pressure sensor is located by the pass side strut is this what you have changed?
if you like, I can take a look at the details of your car
(i work for subaru)
pm me your vin number and we'll sort out if you have a MAP or MAF and what's potentially going on
Jamie
Old 01-22-2008, 02:53 PM   #11
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
plugs got change just before my Maf went out like a month ago, i had an injen intake and it sucked water up and shorted the maf out
Old 01-22-2008, 02:57 PM   #12
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
i will try an get the vin off of it today
Old 01-23-2008, 09:54 PM   #13
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
pmin you the vin in a few
Old 01-23-2008, 09:55 PM   #14
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
and this issue needs to be adressed now, my engine is not the SOHC that is supposed to be in the car, mine is DOHC
Old 01-24-2008, 11:32 AM   #15
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
the bogging and backfiring sounds like a 02 sensor went bad. Thats what mine started doing and I replaced the front one and everything was peaches and cream.
Reebis is offline   Reply With Quote
Old 01-24-2008, 02:37 PM   #16
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
many 1999's are DOHC....
if you are DOHC you have a MAF sensor, not a map sensor.
re-pm me that vin and I'll do some digging for you.
Jamie
Old 01-24-2008, 03:32 PM   #17
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
i assure you, the car has a MAF in the intake, and MAP on the chasis behind the MAF bby the passenger side strut, me an MysteriousXTC off of here have already disputed this
Old 01-24-2008, 04:31 PM   #18
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Yep, vin states EJ253 SOHC
NOT the common EJ251 SOHC
vin shows maf sensor part number 22794aa000
map sensor should be located on the intake (at least mine is?)
the typical RS map sensor is not applicable to your vin
the sensors over by the strut tower show: valve duty solenoid and a vacuum sensor
22012aa070 = vacuum sensor. you're calling this the map sensor?
when did you purchase this car?
I'm assuming you are not the original owner?
Regardless,
your symptoms point to a bad maf or a bad front 02 sensor
but if you are positive your engine has been swapped, it could be the ECU causing these issues.
Jamie
Old 01-24-2008, 04:52 PM   #19
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
bought the car from honda as is about a month ago, like I said it ran fine until the MAF went out and I bought a maf from 99 forester to replace it. So what should I do at this point then?
Old 01-24-2008, 05:13 PM   #20
MysteriousXTC
Member#: 66771
93 L w/ V4 STi RA
Originally Posted by Subie Gal View Post
Regardless,
Jamie
This is what I have been thinking all along for Roy, I don't think the ECU is causing the problems, since it appears to be a 98 DOHC which was also MAF, but beyond that its just the block and heads that were swapped. Intake manifold and all the wiring and such remained untouched, I think lol...
MysteriousXTC is offline   Reply With Quote
Old 01-24-2008, 07:58 PM   #21
ScoobaruBoy
Member#: 100613
2002 2.5 TS Wagon
gonna go buy a MAF tomorrow
Help getting frustrated with jdm USMARINE24M Subaru Conversions 4 10-11-2006 11:26 PM
Very frustrated with my AP (why dont I notice a difference)?! Padge Engine Management & Tuning 18 04-08-2005 04:40 PM
Help my baby a 99 RS is sick Sub25RSDTown Normally Aspirated Powertrain 14 02-24-2005 02:17 PM
Spotted: Legacy Turbo with 99 RS wheels and Tein sticker? mav1c Mid Atlantic Impreza Club -- MAIC 2 07-14-2003 10:00 PM
Looking for Pix of a WRX with 99 RS wheels. Snappy Brakes, Steering & Suspension 2 05-26-2001 12:21 AM
