Old 01-21-2008, 09:36 PM   #1
cpages2
Member#: 4711
2015 WRX
Default Very Loud Ticking noise
So I just picked up an 01' RS with 113K Miles.
Well the engine has a very loud ticking noise coming from the engine when the car is running. I had a friend who works on race cars (drag) come over and look at it with me.
He doesnt know much about subaru engines, and says it sounds like a lifter or rocker to him.
Any ideas or opinions, I know its tuff without hearing or seeing the car, just need some advice.
- Mike
cpages2 is offline   Reply With Quote
Old 01-21-2008, 11:29 PM   #2
sc00ter
Member#: 117767
2015 WRX
CWP
- Mike
Is it like a "knock" or just some ticking?
my 05 RS has a weird little ticking when I hit the throttle. It has had it for over a year now. Still can't figure out what it is.
sc00ter is offline   Reply With Quote
Old 01-21-2008, 11:29 PM   #3
sc00ter
Member#: 117767
2015 WRX
CWP
- Mike
I've had a weird little ticking when I hit the throttle. It has been there for over a year now. Still can't figure out what it is.
Old 01-21-2008, 11:35 PM   #4
imprexaRS03
Member#: 145883
2008 wrx
psm
you should check you belts.dont put wd40 on it if it is that will make its qweeeeeek!if that doesnt do anything check the slave cylinder
imprexaRS03 is offline   Reply With Quote
Old 01-22-2008, 09:23 AM   #5
Roodizzle
Member#: 159844
2003 Toyota Matrix
Gold
Does the ticking go away after the car runs for a couple of minutes, or is it constantly there? I know the pulleys/tensioners on our timing belts have a tendency to go bad and click when the car is cold, but the clicking goes away after 5 to 10 minutes (Depends on the weather.) If the clicking is constantly there, it's prolly something internal like your friend mentioned.
Roodizzle is offline   Reply With Quote
Old 01-22-2008, 10:13 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
stick a stethoscope(or your ear on a screwdriver) on different places on the engine. Try to see if it's the heads or the block. The lifters in the heads on your 01 tend to be kinda noisy when they need adjustment(pretty easy). If it's in the block, that may be a tad more expensive. Does it happen at a certain time? right at startup? only when cold/warm? does it go away? does it come back? on the 2nd tuesday of the month when the bells ring?
Old 01-22-2008, 11:03 PM   #7
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
/\ +1 need more info about the ticking
GrundleJuice is online now   Reply With Quote
Old 01-23-2008, 07:10 PM   #8
tspaniol
Member#: 40215
Default bet it is the tensioner for timing belt
This sounds like my 04 Impreza - the tensioner begins to contact the block. Louder when you first start the (cold) engine, less loud when fully warmed up. They replaced mine at 99,000 when I had the timing belt replaced - under extended warranty thank goodness. I still have the old tensioner on the shelf in the garage, and you can see where it was constantly hitting the block (but a very small area).
tspaniol is offline   Reply With Quote
Old 01-25-2008, 07:06 AM   #9
cpages2
Member#: 4711
2015 WRX
I will check it out this weekend and see if the ticking goes away when it warms up.
I will also look at the tensioneer and see if its hitting
- Mike
Old 01-25-2008, 08:21 AM   #10
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Some people think the accessory belts are the timing belt and the a/c pulley is the timing belt pulley. Just want to clarify that the timing belt is under the black plastic covers on the front of the engine. You probably know that, but just in case.
garface is offline   Reply With Quote
Old 01-26-2008, 08:00 AM   #11
cpages2
Member#: 4711
2015 WRX
Well I started the car last night (cold) and the noise was very loud, but I notice if I press the gas in, as soon as the car begins to rev the noise goes away.
Does this help at all?
Old 03-06-2008, 08:50 AM   #12
ttatsumi
Member#: 85763
Same here...2002 LGT w/ 60.5k miles my extended warranty expired 2/29/08...I called them to make an appointment on 2/22/08 but they said they couldnt...and i go back there today and they said my warranty is expired...NO *****!!! anyway, they wanted to charge me $95 to check whats wrong and then parts+labor...ridiculous!
Is this something thats going to get worse in the soon or long run? do i need to fix it right away? *TSPaniol* Do u have the pic of where it was hitting against the block? TIA
ttatsumi is offline   Reply With Quote
Old 03-06-2008, 11:56 AM   #13
chris07outback
Member#: 146017
2008 Volvo XC70
black
thats a typical suby sound just piston slap. most of the 00-04 legys and ob's and some imprezas seem to make it. dont worry about it.
chris07outback is offline   Reply With Quote
Old 04-04-2008, 08:29 PM   #14
mprother
Member#: 176401
So I have a 05 STI and when a rev the engine (in nuetral) and the revs drop ~2500 a get this loud ticking noise from the engine?? Sound like the same problem? Any Ideas?
-Mike
mprother is offline   Reply With Quote
Old 04-05-2008, 11:56 AM   #15
firefighter1
Member#: 131963
A loud ticking noise is most likey just the valve contacting the lifter/rocker. It gets especially bad with the SOHC 2.5L as they did not use hydralic lifters. You probally just need to have your Valve lash adjusted back to spec which can be a pain especially on your drivers side. Even when they are adjusted properly there is still a ticking noise, it's just a downside to the design Subaru chose to use. Also it could be your timing belt tensioner it uses hydralic pressure to keep tension but as it wears the tensioner develops slop which can cause it to move making a ticking noise.
firefighter1 is offline   Reply With Quote
Loud ticking noise coming from motor. Help prestofilipo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 12-17-2011 10:17 PM
loud Ticking noise? turbo2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-15-2004 08:22 PM
Problem-VERY loud ticking noise coming from motor? pntballfreak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-12-2003 04:23 PM
Loud ticking noise SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-18-2002 06:12 PM
loud ticking noise after turbo installed? RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-09-2002 08:51 PM
