Old 01-21-2008, 09:58 PM   #1
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Default Having My 06STi Retuned
It's an Open Ecu Tune. I currently have a Catless TBE and running on a XPT Stage 2 Map with a bit of tweaking with Enginuity(A local subaru member). First log with the XPT Stage 2 Map after a week of just driving it was only boosting 16psi. We tweaked it up to 18.5psi(cold weather expected to go down when it gets warm) but no difference when TESTED "at the track" against an EVO IX(Bone Stock). I actually had a hard time trying to pull away from him. Any tips before I spend my money on the tune? Or if you know what could be wrong?
tux121 is offline   Reply With Quote
Old 01-21-2008, 11:23 PM   #2
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Bump^^ We tweaked the map from 16 to 18.5psi but no more power, no better pull.
Old 01-21-2008, 11:29 PM   #3
slo06sti
Member#: 144043
06 Stage 2 sti
OBP master tuned 298/313
did you also adjust the wastegate duty cycle it could be that, that is what is holding you back. There is an initial setting and it will only go up 15% from there. once it reaches its max and will not allow anymore boost.
slo06sti is offline   Reply With Quote
Old 01-22-2008, 01:08 AM   #4
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Post your logs.
mickeyd2005 is offline   Reply With Quote
Old 01-22-2008, 05:29 PM   #5
varmint007
Member#: 13626
0298 M5M3
E39E36
so many variables: driver, shift points, from a roll vs. dig, etc...
How did you do against the evo before the reflash?
varmint007 is offline   Reply With Quote
Enkei RP01 18x8.5 +45mm on my 06STI bwilliams373 Tire & Wheel 3 06-03-2010 05:47 PM
My landlord is having my house appraised, I have questions TheRex Off-Topic 26 02-20-2009 01:48 PM
had my 06sti for a bit.. finally a few images.. STI_SLC Member's Car Gallery 14 07-17-2006 11:04 AM
Cols, OH: Anyone have a plasma torch or know where I can have my bumper beam cut? imprezive one Mid West Subaru Owners Club Forum -- MWSOC 13 01-11-2004 03:31 PM
I have to have my synchros replaced again? SoLiDbReAkZ Warranty Issues & SOA Problems 2 09-05-2002 11:32 AM
