Old 01-22-2008, 12:08 AM   #1
slo06sti
Member#: 144043
06 Stage 2 sti
OBP master tuned 298/313
Default Logging and tuning my06 sti
I was wondering if anyone would be willing to take a look at some maps I pulled off my06 sti tonight. I started with the xpt free stage 2 base map and have been doing some changes with a buddy of mine and I was just
wondering if someone would like to take a look at a couple maps. PM me if you have time and I'll shoot the maps over.
Thanks in advance.
btw: mods are 3" catless gpmoto TBE
drop in K&n
snorkel delete
Also the map is setup for 18 psi target boost (which I'm obviously going over)
slo06sti is offline   Reply With Quote
Old 01-22-2008, 02:32 AM   #2
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
It looks like you are trying to tune boost. You're logging a lot of stuff that is not necessary, like AFR correction #1.
For tuning boost, I like to log the following parameters:
Time
Engine Load (Direct)* (g/rev)
Engine Speed (rpm)
Ignition Total Timing (degrees)
Knock Correction Advance (degrees)
Manifold Relative Pressure (psi)
Mass Airflow (g/s)
Throttle Opening Angle (%)
Primary Wastegate Duty Cycle (%)
Turbo Dynamics Integral Cumulative* (absolute %)
Turbo Dynamics Proportional* (absolute %)
Of course, I only do this if I am not having a lot of problems with knock. If you start seeing a LOT of weird KC changes then you will need to log Feedback correction, Fine Learning Knock Correction, and IAM.
You will also need at least one log with IDC but you already have that so you are good to go.
I also like to start my WOT runs from 2000 rpm. For tuning LGTs, I do 2nd and 3rd gear logs to redline and 4th and 5th gear logs from 2000 to about 4000 rpm.
BTW, I highly recommend that you get a WBO2.
mickeyd2005 is offline   Reply With Quote
Old 01-22-2008, 03:10 PM   #3
varmint007
Member#: 13626
Agree with MickeyD.
Turn your boost down, your IDCs are over 100.
varmint007 is offline   Reply With Quote
New map flashed, help tune, logs and LV posted inside.- Stage 2 91 Octane osecurom MAtwal Vancouver Impreza Club Forum -- VIC 13 03-06-2010 05:04 AM
Dell Inspiron 7500 laptop - Great for logging and tuning - BEST OFFER 2xhighpsi Accessories & Misc 6 03-29-2009 02:47 PM
Map and log posted - 16bit 20g modded home built and tuned Fongers Open Source Reflashes 4 02-09-2009 05:23 PM
First time log before tuning, what to log? ogboot Open Source Reflashes 3 07-10-2008 03:01 PM
UTEC road tune...Can someone log and tune while I drive? tm999xxx Tri-State Area Forum 8 06-24-2004 06:12 PM
