#1 |
Member#: 35205
South East
Vehicle:2002 Rubisu 2002 CBR1100XX |
Hey all,
Problem is affecting an '02 WRX wagon. Cruise control no longer working. Here's what happens and what I've done. 1)Main switch activates and lights up. 2)Checked all rear brake lamps and are operational 3)Clutch safety switch 'seems' to be working. The plunger is still there and in and out with the clutch pedal. 4)Car was retro fitted long ago with the clip to retain the cable over the throttle body. Is there any systematic way of testing the control unit without being a Certified Suby Dealership/Mechanic? Is there a way to test the clutch safety switch to make its doing what it should be doing, i.e., grounding when clutch depressed or closing the circuit when depressed. Any suggestions/insight would be appreciated. Thank you.
#2 |
Member#: 100994
W. Canada
Vehicle:2005 Acura NSX-T 2000 Toyota Tundra |
Does your horn still work?
#3 |
Member#: 35205
South East
#4 |
Member#: 48838
BAIC
Vehicle:2008 Stage 2 STI A.W. |
you can test the resistance of the clutch switch using a DMM. sorry i dont have the specs.
| Thread Tools | |
| Display Modes | |
| Strut Tower Issues. any suggestions? | slim617 | Brakes, Steering & Suspension | 28 | 05-04-2009 03:44 PM |
| New Gaskets, Crusie Control, Rear 02 sensor, Ashtray | Josey Wales | MWSOC Private Classifieds | 6 | 06-01-2007 09:34 AM |
| Will you still be able to use crusie control after getting a TBE/EM | SubyWRXSti | AccessPort | 5 | 10-08-2006 10:56 PM |
| crusie control | Impreza RS tec | General Community | 2 | 12-09-2005 07:06 PM |
| question about crusie control | RSimport | Mid Atlantic Impreza Club -- MAIC | 3 | 06-26-2003 09:52 AM |
