#1 |
Member#: 44490
#2 |
Member#: 32503
TXIC
Vehicle:2011 Tribeca 1995 Legacy Wagon |
It'll bolt on, but you will have almost no options for an up-pipe/header that will bolt on to the single-ports. You'll have to get something fabricated - and I think someone on these forums is working on that.
#3 |
Member#: 44490
that no biggie, Iwork in a machine shop and am friends with a welder. Can I use my 2.2 cams too?
#4 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
use your 2.2 cams, they work fine. your CR will be low enough to actually push boost into your frankenbuild.
--keith |
#5 |
Member#: 126217
Vehicle:04 Jetta GLI Blue |
hit up ebay i found single port headers and uppipe on there last night.
#6 |
Member#: 130489
Vehicle:02 WRX Wagon (WRB) 98 OBS-T, 91 Legacy SS |
With EJ22 heads and a WRX block and head gaskets, your CR should be around 9.5:1. Using EJ22 head gaskets will lower your CR to close to 8.8:1.
#7 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Match your head gaskets to your block... Ebay usually has a couple different sizes for that block.
You can use your stock cams, but you could swap them out for aftermarket ones. While you have the motor out. ~Josh~ |
#8 |
Member#: 149442
NESIC
Vehicle:1996 |
How much worse are the 2.2 heads compared to wrx heads?
#9 |
Member#: 157692
NESIC
Vehicle:2004 Widebody WRX Ferrari Corsa Red |
I'm assuming they are the single port single cam heads??? I have them on my EJ22 n/a right now.... they seem to work fine but I doubt that they flow that well..... port seems a bit small. I didn't port the exhaust or anything but I'm sure theres some room for improvement.....
I've heard that they will give you more mid range power versus the DOHCs, but possibly fall a little short up top. |
#10 |
Member#: 157692
NESIC
Now that I look at that again I'm sorry.. that didnt really answer your question at all. I'm sorry :-\
Not sure. |
#11 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
SOHC heads don't flow as well as the DOHC heads. Do yourself a favor, grab some 2.5 NA DOHC heads and put them on an EJ255 or EJ257 block. You'll run boost, and have a good CR for really quick spool.
#12 | |
Member#: 119995
W. Canada
Vehicle:2004 Outback XT Peachy |
http://forums.nasioc.com/forums/show...ighlight=ej22t SOHC has better exhaust flow, not as good intake flow. They are about the same and SOHC is cheaper to upgrade cams and easier to replace timing belts. |
#13 |
Member#: 53558
NWIC
Yeah, the DOHC heads have better intake ports.
After owning a car with SOHC and DOHC heads (2000 BE sedan and a 1998 GT Wagon), I'd go with DOHC heads. The power band is a bit more broad, and you get your torque peak lower. |
#14 |
Member#: 44490
Im trying to go cheap, and use what Ive got. If I were going to buy a new block, and heads then I would just do a jdm swap. Im a tight wad, thanks for the input though.
#15 |
Member#: 44490
How does the original 2.2 block compare to the wrx 2.0 block as far as boost is concerned anyway?
#16 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 05 Legacy GT 06 Armada |
If you look at COBB's test you will see that they are not measuring the static flow of the bare head. They are measuring a fully assembled stock head with stock cams. The stock SOHC cams have more slightly more intake lift and a lot more exhaust lift then the stock DOHC Cams. If your planning to do an all out race motor or higher horsepower street motor like mine where you will be swapping cams and springs I wouldn't go with anything but the DOHC.
However the best bang for your buck for a fully assembled head set for turbo application would be the WRX heads. The 04+ heads have shimless buckets. So if you buy a newer set make sure they come fully assembled. Otherwise a valve adjustment could cost you a fortune. The SOHC EJ25 has a larger head volume then the DOHC (SOHC-46.6cc/DOHC-50cc). Using the SOHC heads over the DOHC heads will lower your compression ratio a little more. Upgrading Cams would definitely be cheaper for the SOHC heads. I'm just not totally confident in using the SOHC heads in combination with high lift cams or stiff springs in a high boost application. I just don't know about the reliability of those rockers. |
#17 |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
Everything I have checked out in the past states that the DOHC heads do have larger ports, and have a little greater potential.... BUT they are ZERO clearance heads, and leave alot less piston options as well. Plus, you have 2 more cams which equals more money for cams.....though I do believe the JDM sti v2 cams are a direct swap...
If I didn't need to keep my stock heads in order to pass emissions, I would be ALL over swappin out the DOHC |
#18 |
Member#: 74907
NWIC
MY 99 2.5GT, those head volumes are backwards, the sohc EJ25 has 50cc head volume, the dohc has the 46.6cc.
The wrx block was a turbo block from the factory, so I'd guess it can handle some boost. If you wanted to go really cheap you could just throw your heads on an EJ18. Best part is, if you blow it up, you're not out a lot of money. This is, of course, not a good idea if you already have the wrx block. Or you could find a set of SOHC EJ25 heads and throw them on your EJ22 block. Also, fill out your profile so we can all see what car you have. ~Josh~ |
| Thread Tools | |
| Display Modes | |
| FS: 97 OBS 2.2L Single Port 2.2L, ECM, 03 WRX Alternator, AC Pump | munkis | Tri-State Area Private Classifieds | 1 | 10-23-2008 11:16 AM |
| 98 2.2 heads on 02 wrx block? | rufracer | Subaru Conversions | 9 | 01-23-2008 09:37 PM |
| Headers for 2.2L single port | G.Subramaniam | Normally Aspirated Powertrain | 1 | 07-08-2004 02:03 PM |
| will jdm exhaust bolt onto stock USDM WRX? | DV Motorsports | Factory 2.0L Turbo Powertrain | 12 | 04-01-2002 07:34 PM |
| Will the Garrett AR60 turbo fit bolt onto my REX?? I am getting one for free | Saco1997 | Factory 2.0L Turbo Powertrain | 17 | 07-30-2001 01:18 PM |
