Old 01-22-2008, 01:25 PM   #1
SubieNOVA
Member#: 97533
Question Crank Pulley Stuck- NOT Crank Pulley Bolt
While installing a new pulley today I ran into an issue... I was able to easily get the crank pulley bolt off that seems to give some people problems- Yet when I tried to remove the stock pulley itself it will not come free from the motor. I tried applying even force on both sides as indicated by the install vid on HSPN. I have also tried using some PB Blaster.
I searched for a solution but so far I have not found anything useful. If anybody has run into this issue and has some advice it would be very much appreciated. Thanks!
SubieNOVA is offline   Reply With Quote
Old 01-22-2008, 04:39 PM   #2
UM-WRXer
Member#: 44623
yea same thing happened to me. You just need to wrestle that thing off. It will come off once the crank bolt is off. Be careful though since there is a keyway for the pulley.
Maybe try to tap it lightly with a rubber mallet to 'break it free'.
UM-WRXer is offline   Reply With Quote
Old 01-22-2008, 06:02 PM   #3
SubieNOVA
Member#: 97533
I tried tapping it, but I didn't have much room... I guess I'll try pulling out the fans/radiator next.
Anybody else have other ideas?
Old 01-22-2008, 06:38 PM   #4
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
You can rent pulley pullers at some auto parts stores.
FCmaniac is offline   Reply With Quote
Old 01-22-2008, 07:18 PM   #5
novacivic
Member#: 117980
2005 sti
wr blue
take two pry bars or screw drivers and put one on either side and gently pry back and forth to walk it off. be careful not to pry too hard on the timing cover so you dont break it. this works every time for me. and remember to put some loctite on the bolt wjen reinstalling because I have seen many crank bolts loosen and then the key way strips and efs rendering it no good
novacivic is offline   Reply With Quote
Old 01-22-2008, 07:19 PM   #6
novacivic
Member#: 117980
2005 sti
wr blue
have you ever looked at the amount of space between the radiator and crank pulley. If not take a look and you will realize there is no way to get anything like that in there.
Old 01-22-2008, 07:23 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Its pretty easy to pull the radiator. I would have even attempted to change the pulley with doing it. With the rad out you may be able to get a gear puller on there.
Old 01-22-2008, 07:33 PM   #8
SubieNOVA
Member#: 97533
I did try prying gently with two large screwdrivers, but to no avail...
I will def. look into the puller idea, and see if there is enough space to work with. Thanks all for the suggestions.
Old 01-22-2008, 07:37 PM   #9
FCmaniac
Member#: 142029
2013 Forester
good point, this is my first flat four
Old 01-22-2008, 07:45 PM   #10
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
1. spray with PB blaster
2. enjoy a couple of fine brews
3. tug on pulley
4 repeat!
jay25RS is offline   Reply With Quote
Old 01-22-2008, 07:56 PM   #11
SubieNOVA
Member#: 97533
^^^ Best advice so far! I'll do it whether it works or not!
Old 01-22-2008, 08:07 PM   #12
sfe
Member#: 109712
2005 STi
2 large pry bars is the way to go. The trick is to pry evenly in a jerking motion on the exact opposite sides. Make sure you leave the crank bolt in a bit so the pulley doesn't fly into the radiator.
sfe is offline   Reply With Quote
Old 01-22-2008, 08:35 PM   #13
Arctic Penguin
Member#: 119532
2006 WRX
pb blaster and a deadblow hammer
give a couple whacks on either side and it should come off in a jiff
mind you dont loose the woodruff key!
Arctic Penguin is offline   Reply With Quote
Old 01-22-2008, 09:15 PM   #14
rkramer
Member#: 118209
2015 WRX Limitec
torch/heat gun to the center of the pulley will help, just don't set anything on fire!
Old 01-22-2008, 09:19 PM   #15
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
You would have to be extremely careful I would think. Isn't the factory center made out of rubber?
Old 01-22-2008, 09:46 PM   #16
ejh25
Member#: 65267
Good point, but maybe try it immediately after running the car. Not as hot as it would get under a torch but probably a lot warmer then ambient air temps.
ejh25 is offline   Reply With Quote
Old 01-22-2008, 10:11 PM   #17
SubieNOVA
Member#: 97533
Heck yes, my engine gets hot as hell... but wouldn't everything else get hot/expand the same way the pulley might?
Old 01-22-2008, 11:01 PM   #18
rkramer
Member#: 118209
2015 WRX Limitec
but if he isn't trying to salvage the stock one, not an issue. (maybe a heat gun instead then...)
Old 01-22-2008, 11:03 PM   #19
rkramer
Member#: 118209
2015 WRX Limitec
yes, but when you have one cylinder outside another cylinder, the metal expansion rates are related to the size. End result is that there will be more space between them when heated.
Old 01-23-2008, 01:15 AM   #20
bkwilliams
Member#: 26254
02 WRX
I had this problem also. Got the bolt out easy, couldn't get the pulley off.
I ended putting the bolt back in and torquing it down to spec. Took the bolt back out and the pulley popped right off. Strange.
bkwilliams is offline   Reply With Quote
Old 01-23-2008, 12:36 PM   #21
SubieNOVA
Member#: 97533
Got it off this morning! It was a combination of engine heat, PB blaster, and prying that finally got it to budge. Since I had tried the PB blaster and he prying previously, I believe it was the heat that made the difference. Thank you to all for the suggestions, I appreciate the help!
GFB light weight alternator/ A/C pulleys- not crank phuhs04 Private 'Wanted' Classifieds 1 05-20-2008 06:44 PM
207 crank vs 205 crank... drill or not to drill... japslapr Built Motor Discussion 31 03-14-2008 05:23 AM
WTT Brand new gold cobb crank pulley for polished crank pulley IllNastyImpreza NESIC Private Classifieds 2 03-02-2007 05:08 PM
Stuck rear rotor..magic bolt didn't work... Rusty Brakes, Steering & Suspension 9 03-03-2005 03:42 PM
AC and UD Pulley, damage to crank? byl-23 Normally Aspirated Powertrain 18 12-28-2000 12:34 AM
