Old 01-22-2008, 02:17 PM   #1
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
Hybrid,07 6spd, BW Roated
Default STi ECU plug and play in WRX?
well i have a 2.5 block in my WRX and wondering if 04-05 STi ECU's simply plug in the WRX harness or will need modification or i'll need STi harness to go with it.
UpSideDownDesi is offline   Reply With Quote
Old 01-22-2008, 02:27 PM   #2
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
To answer you question, no, 04-05 STi ECU's are different. You would have to convert whole car to STi, rear harness too. Why are you wanting a Sti ECU in your car?? Just because you have a 2.5L you do not need a Sti ECU, just need a re-tune on your stock ECU. Hope that helps.
icslowmo is offline   Reply With Quote
Old 01-22-2008, 02:29 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
You'd have to change a lot of stuff, add wiring, change the manifold for the drive by wire, change to the drive by wire pedal, etc. Why would you want to swap ECUs anyway????
Old 01-30-2008, 04:06 AM   #4
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
i wish someone would make a tut on how to make a sti drive by cable insted of drive by wire. i have everything to change a wrx to a sti harness, but i dont like drive by wire
mikeis300 is offline   Reply With Quote
Old 01-30-2008, 08:42 AM   #5
Tea cups
Member#: 103136
There's a guy that swapped an 07 STi motor, wiring harness, ECU, immobilizer, etc. into an 02 wrx. I think it was in the subaru conversions forum. Looked like a PITA.
Tea cups is offline   Reply With Quote
Old 01-30-2008, 03:04 PM   #6
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
me? haha. its an 03 wrx but all of the other information is correct and i did the full drivetrain too, but yes it was a pain in the ass. but the car is pretty sweet though
for 90% of the benefit at 30% of the effort, here's what i'd recommend:
get an STi longblock only. remove the STi intake manifold and throttle body. replace with WRX intake manifold and throttle body (good time for a TGV delete as well). install into your car using your original WRX wiring and ECU. voila.
you'll need to get a cam position sensor adapter from gruppe-s but otherwise it should be very straightforward. its a lot less effort and money than doing the whole swap like i did, the only drawback is you will not have active AVCS. otherwise, you're good to go, and this would use drive by cable with the STi engine of course.
TROLL is offline   Reply With Quote
Old 01-30-2008, 03:41 PM   #7
Tea cups
Member#: 103136
yes definitely cool.
MY04 Sti HIDS direct plug and play in MY05 WRX? remborsky Electrical & Lighting 22 12-31-2007 09:13 PM
What STI cluster plug and play in 06 TR nipcup101 Interior & Exterior Modification 0 11-10-2007 10:56 PM
06 STi head unit plug and play in a 04 STi? Sev Car Audio, Video & Security 2 03-26-2007 03:18 PM
STi headlamps plug and play with WRX? litlechina Electrical & Lighting 4 11-18-2005 05:27 AM
Nakamichi head unit: plug and play in WRX? superg Car Audio, Video & Security 3 09-02-2005 05:46 AM
