Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 01-22-2008, 02:21 PM   #1
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Default starting problem
My friends 2.2L Impreza will sometimes not start, but after 10 minutes it will sometimes start. It has full power but will not turn over. When she turns the ignition there is one click and then nothing.
My guess that it probably is the starter or the solenoid, but I want to confirm before I tell her to get a new starter.
Can anyone confirm or give me advice on how to know for sure.
Thanks
maciek is offline   Reply With Quote
Old 01-22-2008, 05:50 PM   #2
fuelforthought
Member#: 168944
97 impreza gc8
he he primer
I think autozone or the like can check it. Not very hard to pull out. If you replace it and it still doesn't work you can always take it back. Not the easiest way to diagnose a problem, but it does work in a pinch.
fuelforthought is offline   Reply With Quote
Old 01-22-2008, 06:19 PM   #3
novacivic
Member#: 117980
2005 sti
wr blue
it is most likely the starter ehich comes with the solenoid but could also just be a bad cable. And parts stores dont allow you to return electrical parts that have been installed.
novacivic is offline   Reply With Quote
Cold start problem.. I Love Turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-15-2002 04:36 PM
Very intermittent no start problem NotAnRS Normally Aspirated Powertrain 6 05-15-2002 08:39 AM
Starting Problems Yanofsky Service & Maintenance 15 02-05-2002 08:39 PM
Can the unichip cause cold-start problems MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-04-2002 02:00 PM
Cold Start Problems? Kapwi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 04:36 PM
