Old 01-22-2008, 02:46 PM   #1
Boggie1688
Member#: 165955
2015 WRX Base
Default Cold Start Issue 08 Impreza 2.5i
Hey Everyone,
I recently bought an 08 Impreza and I love the car to death. However, there seems to be an issue with the car when I cold start it. I live in northern california and on a few occasions there has been a strange issue with the car starting in the morning. I put the key in, turn it just enough to let the gauges do their thing and let the fuel pump prime. When I turn it further to start, you hear the car try to start, then suddenly theres a loud clunk and all it quiet. I still contiune to hold the key in the turned start position, and the car trys to start again and does.
Does anyone know what that clunking sound could be?
Boggie1688 is online now   Reply With Quote
Old 01-22-2008, 02:59 PM   #2
drumaboi628
Member#: 152978
i say bring it back to the dealer cause its still under warranty and also its waaaaaay to early to start having problems...
and to answer your question, no i dont know what is wrong...
i live in chicago with like 10 degrees and it still starts fine...
drumaboi628 is offline   Reply With Quote
Old 01-22-2008, 03:10 PM   #3
shemoves
Member#: 80663
2005 STi
I have no idea, but def bring it in to the dealer. Obligatory...make sure all your fluids are at their proper levels.
shemoves is offline   Reply With Quote
Old 01-22-2008, 03:30 PM   #4
mopartodd
Member#: 164929
2014 Impreza Premium
Jasmine Green Metalic
Maybe your having an issue with the starter or interlock relay. Take it back to the dealer.
mopartodd is offline   Reply With Quote
Old 01-22-2008, 04:23 PM   #5
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Bring it to the dealer. Any problems should be covered under warranty.
I live in Denver and it was -3 deg F this morning and it started with no problems.
subyski is offline   Reply With Quote
Old 01-22-2008, 04:30 PM   #6
Boggie1688
Member#: 165955
2015 WRX Base
I guess I'll bring it in. I just don't have another car to drive.
Old 01-22-2008, 05:22 PM   #7
piker28
Member#: 22664
for the issue your having make sure you leave it there overnight so the car will be nice and cold when they try to start it
piker28 is offline   Reply With Quote
Old 01-22-2008, 06:04 PM   #8
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
Not normal i live in norcal and my 07 has no issues.
EvoSpeed is offline   Reply With Quote
Old 01-22-2008, 06:08 PM   #9
drumaboi628
Member#: 152978
oh you dont have to worry about that...if they said they need you to leave the car over night, they should give you a rental with no cost or what so ever.
Old 01-22-2008, 06:33 PM   #10
piker28
Member#: 22664
^^and what makes you so sure on that? Because i know for a fact the dealer i work at would not unless it is warranty work even still they might not if you dont tell them you want one
Old 01-22-2008, 07:01 PM   #11
drumaboi628
Member#: 152978
oh im only speaking from experience....bought it in a couple times and they offered me a rental since it will take more than 3 hours...
but yea, i guess it might be different since its not the same dealer...
GOOD LUCK!
Old 01-22-2008, 09:16 PM   #12
Boggie1688
Member#: 165955
2015 WRX Base
Made an appointment to drop it off this friday and let them try to reproduce the problem saturday morning. Heres to hoping that the problem gets fixed and it doesn't take very long.
Old 01-22-2008, 11:06 PM   #13
GrundleJuice
Member#: 165749
good luck.. curious to know what they find out.
Old 01-27-2008, 09:31 AM   #14
Boggie1688
Member#: 165955
2015 WRX Base
Car didn't do it while it was at the dealership. It was cold and rainy all week, and did it several times in the morning, but the one day they had to the car to start it, no rain. Wasn't as cold as it usually was when I get around at 8 am to start it. I'll keep an eye on it and if it happens more often she'll go to the dealer again.
Old 01-27-2008, 04:27 PM   #15
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Do you have a camcorder? Maybe try to get it on video and show it to them.
HondaH8er is offline   Reply With Quote
Old 01-28-2008, 08:13 AM   #16
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Wow.. I thought the dealership in my town was bad.. but at least they'll give you a loaner.
Old 01-28-2008, 08:23 AM   #17
piker28
Member#: 22664
^well its a cash money business if you give everything away for free where is the money to be made? And yes although we have a large amount of cars to rent out, its not like its enough to cover even half the work that comes in on one day
Old 01-28-2008, 09:05 AM   #18
pleiadi
Member#: 158257
2008 Impreza 2.0R
Newport Blue
Try to put the key in and turn it to the start position immediately.
pleiadi is offline   Reply With Quote
Old 01-28-2008, 04:11 PM   #19
rhinh25
Member#: 148146
2007 Impreza 2.5i
Newport Blue
Hey Everyone,
when you say a "loud clunk", do you mean like a tin-can noise that was crushed by a hand, then released? that type of noise?
and when you were sitting in your car, did the noise come from the arm rest of your car (right by the e-brake)?
because ive had that same problem, but the only difference is that i never brought it in to the dealership, it just never showed again.... just sharing my experience.
rhinh25 is offline   Reply With Quote
Old 01-28-2008, 11:14 PM   #20
joker75
Member#: 168516
2008 Imprexa 2.5i
Spark silver
Thanks for jinxing me. The same night I read this me 08 impreza 2.5i did a similar thing. I started cranking it and it took a little longer than usual, then it made a loud noise and stopped cranking. I cranked it over again and it fired up fine.
After I got it started I realized that the sound was almost like one cylinder fired and the ECU thaught it was started and quit cranking, but the engine did not have enough momentum to continue rotating.
joker75 is offline   Reply With Quote
Old 01-29-2008, 12:49 PM   #21
Boggie1688
Member#: 165955
2015 WRX Base
Sounded like it was coming from the engine, as for the type of sound you describe it pretty well.
Its good to see that I'm not the only one with this problem.
Since we are on the topic of problems, I have another one. On some occasions when I start the, it sounds like the starter whines. Almost as if I hold the key in the start position too long. I told this to the dealership they say its normal when you in defrost mode or the ac is on. However it happened this morning and none of those were on. Anyone else experience this?
Old 01-29-2008, 01:24 PM   #22
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
This is normal, it happens to my car in morning. Its not a nasty whine, more like a "whirr" for a second or two after cold start.
Old 01-29-2008, 01:42 PM   #23
Boggie1688
Member#: 165955
2015 WRX Base
Thanks for the reply. I thought maybe the starter was going out already, or that I was holding the ignition for too long.
Will a Catback for an 08 WRX fit on an 08 Impreza 2.5i? StickyBrokeConfused Newbies & FAQs 5 12-05-2013 11:33 AM
08 Impreza 2.5i 5-speed Throttle Hang Fix? rick92008 Newbies & FAQs 15 04-17-2008 12:34 PM
08 Impreza 2.5i or 08 SI? jtom12 Impreza Forum 8 02-05-2008 06:03 PM
08 Impreza 2.5i ? 240c Normally Aspirated Powertrain 106 01-11-2008 02:10 PM
08 Impreza/2.5i Endlinks are out from Goup A! PATR1KI Brakes, Steering & Suspension 1 12-13-2007 02:13 PM
