South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-22-2008, 04:46 PM   #1
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
Default Beatrush rear diff brace installed
If any of you ever install one of these, save yourself some trouble and plan on dropping the subframe right off the bat; about 3/8" will do it. I had extracted the center diff studs to add bushings to the stock brace, and it is just too hard to get all the holes to line up and reinstalled the studs. If you don't pull the studs, there isn't enough clearance to slide the brace over the studs without dropping the subframe anyway. Maybe the included instructions mentioned this, but they are only in Japanese.
DroppedClutch is offline   Reply With Quote
Old 01-22-2008, 04:57 PM   #2
shemoves
Member#: 80663
1997 Outback
good tip, thanks. nice piece btw
shemoves is offline   Reply With Quote
Old 01-22-2008, 05:03 PM   #3
pweizman
Member#: 131268
.... GOD........
What does it do?
It looks like you are putting a brace on an already stout subframe member.
Also, what is the thing sticking out of the plug on the diff.? A sensor?
Later,
Patrick
pweizman is offline   Reply With Quote
Old 01-22-2008, 05:52 PM   #4
DroppedClutch
Member#: 52313
2007 MS3 Black
It's not re-enforcing the subframe, like it may appear. The rear of the differential is carried by a brace. You can see the end of it in the photo; notice the red of its bushing. The Beatrush brace acts in tandem with this stock brace. The two end mounts are bolded to the subframe, but the center ones are only bolted to the diff case. It might look like it's bolted to the subframe in the center, but it's actually passing through two holes and touching the stock diff brace within.
The thing sticking out of the diff is a temp sensor; stock on the STi's.
Old 01-22-2008, 06:04 PM   #5
Chris_M
Member#: 116665
06-7 WRSTI
Team Snail
I've been looking at all their different subframe setups. How is this one? can you tell a difference?
Chris_M is offline   Reply With Quote
Old 01-22-2008, 06:50 PM   #6
DroppedClutch
Member#: 52313
2007 MS3 Black
I can't honestly say that I can tell a difference directly attributed to this brace, because while I was under there I installed bushing on the stock rear diff brace and the front diff brace. I also installed lock out bolts. The combination of all this is noticeable. Launching hard from a stop is improved; feels more... solid... stable. Coming out of a corner with the right foot on the floor shows the most improvement. Understeer tendencies are reduced; the back end comes around and falls back inline with much less drama than before. The knocking from the subframe and suspension is definitely reduced, but not eliminated... for me anyway; the group-n top mounts I have make a lot of noise.
Old 01-22-2008, 09:42 PM   #7
kos
Member#: 118334
S-AWD+TT2 WRX / RS Daily
nice!
i bought this for my friend for xmas and he loves it. he also has the whiteline locking bolts like you
kos is offline   Reply With Quote
Old 01-23-2008, 12:09 AM   #8
joebud
Member#: 55089
nice writeup. It would be a good article for a website or blog.
joebud is offline   Reply With Quote
Old 01-23-2008, 12:13 AM   #9
DroppedClutch
Member#: 52313
2007 MS3 Black
Old 01-23-2008, 02:30 AM   #10
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
nice man, im going to have to invest in this for the RS. how long did it take you to install? me and shemoves found out the hard way for lineing up those stupid diff studs... though it can be done with alot of effort and a jack...
SubeSTIle is offline   Reply With Quote
Old 01-23-2008, 12:52 PM   #11
DroppedClutch
Member#: 52313
2007 MS3 Black
If you think it's hard lining them up normally, you should try it with a third hole to consider and not even being able to visually check if all the holes are in line because of the brace.
If I had to do it again, I think I could do it within a hour... Just the brace and now knowing what I mentioned in the original post.
Old 01-23-2008, 03:41 PM   #12
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
as soon as my car is actually running... ill worry about putting money into making it handle better haha. but soon... oh so soon.. i think this is the first productive thread SWIC has seen in months. thanks for bringing us out of the slums haha
Old 01-23-2008, 03:41 PM   #13
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
nasioc lag ftl
Old 01-23-2008, 04:38 PM   #14
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Double post. BAN
szeny is offline   Reply With Quote
Old 01-23-2008, 04:54 PM   #15
DroppedClutch
Member#: 52313
2007 MS3 Black
You're welcome. I'm channeling the SWIC spirit of two years ago.
Old 01-23-2008, 04:59 PM   #16
Deuce Cam
Member#: 130444
'85 AE86 GTS
You don't need to lower the subframe to install the beatrush piece. Although it wasn't easy, I was able to install it with the studs on the rear diff in place and without lowering the subframe.
I installed the beatrush rear diff support bar and TiC race rear diff mount bushings on my 06 sti at the same time. The beatrush piece didn't seem to fit over the studs/bolts after I reinstalled the rear diff mount and studs. There didn't seem to be enough room to fit the piece between the studs and the underbody of the car.
It does fit, you just have to be patient and creative. Keep in mind that your rear diff isn't bolted in until the beatrush piece is installed so you have some play in the assembly (I had my diff supported by a jack. Also the 2 outer mounting points are bolts which aren't completely fixed like the studs so they give some play as well.
Deuce Cam is offline   Reply With Quote
Old 01-23-2008, 06:48 PM   #17
DroppedClutch
Member#: 52313
2007 MS3 Black
Fast and easy (like my mom) still gets my vote.
Group Buy GC8 Beatrush Rear Diff Support RallySport Direct Vendor 'Group Buy' Classifieds 124 08-25-2009 06:37 PM
WTB: Beatrush rear diff bar for GC body calmnothing Private 'Wanted' Classifieds 1 06-27-2008 02:14 AM
FS: Beatrush Rear Diff Support Bar beaviscih Suspension/Brakes/Handling 21 09-02-2007 06:20 PM
STI GroupN Rear Diff Brace **NEW** PJMAN2 Private Vehicle 'For Sale' Classifieds 1 11-25-2006 06:42 PM
Cusco front, rear, and rear triangle brace installed (pics) Dirty Underwear Gang Brakes, Steering & Suspension 18 05-03-2002 05:24 PM
Message Board Statistics All times are GMT -4. The time now is 06:21 AM.
