Old 01-22-2008, 05:14 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Camshaft Question
Just wondering if the 2005 subaru wrx sti cams will fit in a 1995 jdm ej25?
Probaly way different...thought id ask
Numbchux where are you?
parkes is offline   Reply With Quote
Old 01-23-2008, 02:01 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The jdm N/A motor? Like the ones that are horrifically overpriced on ebay?
~Josh~
Old 01-23-2008, 12:44 PM   #3
parkes
Member#: 166898
1994 T leg SS
ABM
Default yessss
O ya there way overpriced on ebay.
I got an ecu,motor and transmission for 1000$ from a local importer
But back to the question......
Old 01-23-2008, 09:59 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
IIRC, the sti cams are bucketless or something, and the 95' JDM EJ25 is shim over bucket, or some crap like that. But i'm pretty sure they arent compatible unless you swap over the buckets/shims. Dont know all the details, but from what limited knowledge I have, I think they are different. The info is more than likely already here, just waiting to be found.
~Josh~
Old 01-23-2008, 11:16 PM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Is the JDM motor DOHC?
Counterfit is offline   Reply With Quote
Old 01-23-2008, 11:42 PM   #6
parkes
Member#: 166898
1994 T leg SS
ABM
Default yessss
of course it is... all the 2.5l are. 2 exaust 2 intakes
Old 01-24-2008, 12:21 AM   #7
GrundleJuice
Member#: 165749
except for phase II ej25s, at least USDM versions. they are SOHC but great flowing heads.. or so they say.
GrundleJuice is online now   Reply With Quote
Old 01-24-2008, 12:58 AM   #8
parkes
Member#: 166898
1994 T leg SS
ABM
Default ???
Really... never knew that. But back to the main question!!!!
Does anybody have some real knowledge to back my question up?
Old 01-24-2008, 03:18 AM   #9
Counterfit
Member#: 124254
"The Scoobinator"
4 valves per cylinder doesn't mean it's DOHC. My 2.5i is SOHC.
And I do have to wonder, why do you want to use turbo cams on an N/A engine?
Old 01-24-2008, 12:32 PM   #10
parkes
Member#: 166898
1994 T leg SS
ABM
Default pp
Well i have a 2005 turbo setup and i wanted to see what would would happen or if it was possible....what do you mean by n/a engine?
Old 01-24-2008, 12:49 PM   #11
parkes
Member#: 166898
1994 T leg SS
ABM
Default regrind
Or should i get a good ol regrind from delta cams?
Old 01-24-2008, 07:04 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
You will probably get more knowledgable answers in the "built motors" section. I would search for the terms AVCS, cams, swap, etc...You want to know if AVCS cams will run in non-AVCS heads.
I'm sensing that you need to do ALOT more reading and researching before taking on the project though. The above posts demonstrate a lack of knowledge in the basic structure of Subie motors and will quickly lead to trouble if blindly ignored.
Jay Storm
Old 01-24-2008, 11:18 PM   #13
parkes
Member#: 166898
1994 T leg SS
ABM
Default basicly
Well i lak most knowledge but i know the basics. So far i have got along with just reading but now i have been getting into more complicated workings of the motor.
Thanks for the tip
Old 01-25-2008, 04:18 AM   #14
Counterfit
Member#: 124254
"The Scoobinator"
Look at the first two words of the forum name.
Old 01-25-2008, 10:22 AM   #15
parkes
Member#: 166898
1994 T leg SS
ABM
Default ?
why? i was told by the moderater to post my question in this thread
Old 01-25-2008, 01:36 PM   #16
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I'll go out on a limb and say that I'm pretty sure they will fit.
What is your situation? Do you have either or both of these motors? Are you looking to do some sort of hybrid?
Tim Sanderson is offline   Reply With Quote
Old 01-25-2008, 07:10 PM   #17
Counterfit
Member#: 124254
"The Scoobinator"
N/A = Normally (sometimes Naturally) Aspirated.
Old 01-26-2008, 03:28 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
My concern is the AVCS of the newer cams. I don't know if they'll fit in the older heads. If they did, it certainly won't have AVCS functioning.
Jay Storm
Old 12-02-2008, 08:36 PM   #19
Battlesnake99
Member#: 163066
08 2.5i sedan
as far as N/A subies we have AVLS not AVCS, and this AVLS will most likely be retained, meaning a smooth idle and decent emissions
Battlesnake99 is offline   Reply With Quote
Old 12-03-2008, 04:40 AM   #20
Counterfit
Member#: 124254
"The Scoobinator"
I don't think AVCS cams would retain AVLS.
Old 12-03-2008, 11:54 AM   #21
Battlesnake99
Member#: 163066
08 2.5i sedan
i know i was referring to the N/A cams that are coming out soon. sorry for the confusion.
Timing Belt/Camshaft Question gryph Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-02-2005 04:46 PM
Camshaft questions John*G Normally Aspirated Powertrain 2 04-29-2004 07:50 AM
I have a camshaft question. Intake vs. exhaust lift Eric SS Normally Aspirated Powertrain 15 05-22-2002 05:14 AM
camshaft question Jayson_K Normally Aspirated Powertrain 18 01-16-2002 11:27 AM
COBB Tuning's Performance Camshaft question iceman Normally Aspirated Powertrain 1 11-20-2000 05:33 PM
