Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 01-22-2008, 10:22 PM   #1
JLW2007RS
Member#: 162089
2008 G37S IPL
Default Na Gauges
anyone have a gauge pod in there NA, post pics and info
JLW2007RS is offline   Reply With Quote
Old 01-22-2008, 11:07 PM   #2
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
RICE
olsen726 is offline   Reply With Quote
Old 01-22-2008, 11:32 PM   #3
JLW2007RS
Member#: 162089
2008 G37S IPL
alright nvm
Old 01-22-2008, 11:39 PM   #4
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Subaru parts has a triple gauge pack for NA cars. It replaces the clock pod, and has voltage, iol temp, and vac.
It's a clean pod and totally stock, not rice at all.....now if you have a pillar gauge pod on your 2.5i I could see where people would say "rice". It is nice to have those gauges as a bit of insurance. Look them up on subaruparts.com
camshaft06 is offline   Reply With Quote
Old 01-23-2008, 12:02 AM   #5
kos
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
Originally Posted by olsen726 View Post
RICE
coming from the n00b
gauges serve a purpose, not for bling "homie"
kos is online now   Reply With Quote
Old 01-23-2008, 12:04 AM   #6
imprexaRS03
Member#: 145883
2008 wrx
psm
RICE
whata no0ob!
imprexaRS03 is offline   Reply With Quote
Old 01-23-2008, 12:38 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
oil pressure, water temp, and volt have been the 3 most common extra gauges added onto cars for years - even N/A ones. Now if you have a boost gauge on your N/A car...that's another story
rougeben83 is offline   Reply With Quote
Old 01-23-2008, 01:18 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
But most boost gauges also have a readout for vacuum, and that can be useful info also.
~Josh~
Old 01-23-2008, 01:49 AM   #9
Major Johnson
Member#: 120705
2007 FXT Sports Stg2
Urban Grey Metallic
Keep in mind this is in a '99 RS
Major Johnson is offline   Reply With Quote
Old 01-23-2008, 01:54 AM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Personally, I'd be most interested in Oil Temp, Water Temp, and EGT. And a knock/shift light. Oil and water will let you know when the car is ready to be beat on and when you've been beaten on it for too long. EGT is good for a "what the crap just happened I shouldn't be seeing 1900F!" sort of thing and the knock light will be your first warning about bad gas. The shift light is just a convenience.
Oil press FTL because it's mainly going to tell you that you just lost your engine about 10 seconds ago.
Old 01-23-2008, 01:57 AM   #11
Major Johnson
Member#: 120705
Urban Grey Metallic
Haha very true. I have the scan gauge 2 above the pod and it reads RPM, MPH, water temp and one any other random thing (MPG, TPS, Load, etc), to go with the Vac, Volt, and Oil temp. Mainly have it because main cluster reads in Km/H.
Old 01-23-2008, 03:22 AM   #12
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
RICE!
wait... what does that make me?
subikid is offline   Reply With Quote
Old 01-23-2008, 04:05 AM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have a DEFI DIN gauge pack with oil temp, water temp, and oil pressure. Quite helpful for monitoring the engine during track days.
For a N/A car I can't imagine why you think EGT would be more useful than oil pressure.
RICE
Please don't sully the Olsen name with stupid, uneducated comments like that.
Pat Olsen
Patrick Olsen is online now   Reply With Quote
Old 01-23-2008, 04:11 AM   #14
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
EGTs will rise if the ECU retards timing or the engine runs significantly lean. If either happens, you'd better figure out why.
As far as why not oil pressure, mainly because it tends to show OK or failed (yes, yes, I realize you can extract other data on it such as wither or not the correct weight of oil is being used, etc, but I'm interested in gauges for the ability to kill the engine or take corrective action before engine damage occurs). If it's showing failed, you better hope you caught the moment it indicated.
Old 01-23-2008, 09:27 AM   #15
JLW2007RS
Member#: 162089
2008 G37S IPL
keep this thread going and Maj Johnson, how are you pushing almost 60hg of vaccuum, even my ram would only push 20hg
Old 01-23-2008, 09:58 AM   #16
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
oil pressure, can also warn you of a failing or about to fail oil pump. I have a oil pressure gauge on my truck, and I know my oil pump is going because, the pressure is fluctuating, where it used to be constant. I know in my 2.5I, I'm planning on putting in, oil temp, water temp, oil pressure, voltage, trans temp, AFR, and EGT. I'm also a mechanic and like to know exactly what is going on in my car, and I'm planning an STI swap.
also major johnson what compass thing is that under radio?
H-Dtech is offline   Reply With Quote
Old 01-23-2008, 10:18 AM   #17
ScottyB
Member#: 155883
2005 Impreza 2.5RS
bacon rage
i notice alot of people going with an extra water temp gauge...is the stocker particularly innacurate, or too slow to respond?
if i had to pick 3 gauges for a pod i'd probably go with oil temp/press and EGT.
ScottyB is offline   Reply With Quote
Old 01-23-2008, 10:44 AM   #18
Rocketjones
Member#: 142754
2005 RS Wagon
Oil pressure and volt meter if you have any extra electrical load(ie. lights, stereo equip, etc).
Rocketjones is offline   Reply With Quote
Old 01-23-2008, 10:48 AM   #19
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
the stock subie water temp gauge is basically a dummy gauge, its only moves at set temps. so when your car is first warming up it won't move until a set temp, then when it is at normal operation temp. it won't move until temps get into a dangerous area. basically they didn't want every commuter idiot that didn't know anything about cars bringing in there car every time they got stuck in traffic and the temps climbed abit. so the stock gauge only gives you enough info to get into trouble, and not enough to prevent it.
Old 01-23-2008, 12:05 PM   #20
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
Just in regards to looks: I think a pillar pod would definetly look stupid or rice or whatever you want to call it, and i think thats where olsen1234's RICE comment came from. However i think an oil pressure/ water, maybe voltage would be cool in an NA car if placed somewhere sleek. I woud think it would be more necessary in a more modded or older car then my new 07 but if i could place them somewhere sleek and attractive i would be onboard. Maybe i should look at the turbo forums for placement ideas.
EvoSpeed is offline   Reply With Quote
Old 01-23-2008, 12:19 PM   #21
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
I think gauges are a great idea, I bought my sister the triple gauge pack for her birthday, and installed them for her, and they look great, I don't know if she uses them....but my thought was that she is not the best about maintaining her car, and she drives around with my niece in there, I just wanted a little peace of mind for myself and her that if something is going to go wrong, maybe she will have a little advance warning. I care about my family, that's why I made her get the Subie instead if another honda like she had!
Old 01-23-2008, 01:16 PM   #22
JLW2007RS
Member#: 162089
2008 G37S IPL
3 pack? was it a glowshift pack? genuine subaru or prosport?
Old 01-23-2008, 01:49 PM   #23
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Well see, here's my problem with the whole A-pillar as "rice" comment; it's a logical place to put a set of gauges since it's easily within normal eye level when driving. If you don't have a nifty center gauge pod available, as is the case on a lot of cars, it is the next best option. Other than that, what use is it having gauges that are mounted 2 feet below and 1 feet to the left of your normal sightline? Or individual cups drilled into your dash (which looks even more messy than the A-pillar) Might as well not have gauges at all if you don't look at them, or you take your eyes off the road for too long of a time to look at and interpret your gauges...
Old 01-23-2008, 01:54 PM   #24
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
I agree, theres not much else in way of location to place them. I just feel if you dont have a modded turbo then the pillar mounted guage pod just looks out of place. At least make them blend in the same color. Not like red gauges on a black interior or anything like that.
Old 01-23-2008, 01:55 PM   #25
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
+1 the pillar is the best mounting point, and I like the look of them there to. you guys only say they are rice, because all the cars paul walker drove in the movies had them.
definition of rice: a part that is put on the car that is purely for aestetic use and doesn't provide any benefit. i.e. a FWD civic with a giant wing. you can't call it rice just because you don't like it.
Na Na Na Na Na Batman! Brad Pittiful Off-Topic 30 04-10-2012 03:35 PM
da na na na na...da na na na na na na na Evil_STI Off-Topic 33 11-14-2008 02:32 AM
The final countdown! Na na na na! Na na na na na! Na na na na na! Final COUNTDOWN!!! Asinine Off-Topic 53 03-26-2007 03:30 PM
Operation CAN OPENER: Dun dun da na! Dun dun doo doo! DUH NA NA! DUH NA NA! DA DA!!! Asinine Off-Topic 43 06-16-2006 12:55 PM
MA: White faced Subaru gauge pack for NA engines + gauge hood for RS Aphex28 Private 'For Sale' Classifieds 3 10-31-2005 12:12 PM
