Old 01-23-2008, 07:10 AM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Default The STi Brembo Brake FAQ - including "will STi Brembos fit on [x]?"
Not gonna try to get it all in one shot
General STi Brembo information
What replacement rotor options do I have?
-dealer prices
-cheap options
-blingin' 2-piece options
Update! It looks like NAPA now sells cheap blanks. Woohoo! Ken @ WRXBrakes sells em.
http://forums.nasioc.com/forums/show....php?t=1683074
What wheels clear the Brembos?
http://forums.nasioc.com/forums/showthread.php?t=448097
The pads that come in my Brembos dust too much.
What can I use for touch-up paint? My Brembos are a little scratched.
The original popular answer was Honda Inca Pearl or something like that. But some people have had better luck (a more accurate match) with... nail polish
http://forums.nasioc.com/forums/show...highlight=inca
Can I paint my Brembos another color?
http://forums.nasioc.com/forums/show....php?t=1076545
http://forums.nasioc.com/forums/show....php?t=1262317
How can I repair the threads in my Brembos if they get nicked?
http://forums.nasioc.com/forums/show...rembo+helicoil
Thanks jac04!
How can I disassemble my calipers?
http://forums.nasioc.com/forums/show....php?t=1600335
Where can I get a rebuild kit for my calipers?
http://forums.nasioc.com/forums/show...7&postcount=50
Old 01-23-2008, 07:10 AM   #2
Butt Dyno
Member#: 17301
is the "dark side"
Brembo swap information
The Brake Interchangeability FAQ is also a great resource!
http://forums.nasioc.com/forums/show....php?t=1529797
What do I need to swap Brembos onto a WRX?
You can either
a) Swap 04 Brembos over - easiest if you can find them
b) Swap 05 Brembos over - a lot more work, though there are advantages to using the larger hubs and whatnot
Very cliffnotes version:
Originally Posted by Turn in Concepts View Post
Fronts will bolt up, but you will need the rotors, pads, calipers, and bolts.
Rears, not so much, and you have to use a brake caliper adapter. I believe [email protected] has one, [email protected] has one, and [email protected] has one.
Originally Posted by girodisc View Post
04-08 Subaru Brembo Caliper will swap on the any RS or WRX no problem. You will need the 04-08 Caliper and an 04 Rotor (5x100).
The to do the rears you ether need a bracket and the special rotor Brembo makes for the swap or you need to get an 04-07 STi Rear Hub Assy (04 only if you staying 5x100). However, you can swap to a 06-07 WRX rear Caliper (same as JDM 2 pot) and run a stock 06-07 WRX or 04-07 Legacy GT rotor with the special l bracket Kartboy makes for the swap.
The two main differences between STi and WRX hubs is the diameter of the e-brake assy and the mounting points on the hub for the caliper.
A recent thread with some more detail about the rear parts you need
http://forums.nasioc.com/forums/show....php?t=1699740
General swap information:
http://forums.nasioc.com/forums/show....php?t=1225904
http://forums.nasioc.com/forums/show....php?t=1389105
http://forums.nasioc.com/forums/show....php?t=1535742
Information about getting the rears on:
http://forums.nasioc.com/forums/show....php?t=1136862
http://forums.nasioc.com/forums/show...hlight=brembos
http://forums.nasioc.com/forums/showthread.php?t=811621
What is pad knockback?
http://www.stoptech.com/whitepapers/knockback.htm
Why would swapping Brembos onto a WRX cause pad knockback?
http://forums.nasioc.com/forums/show....php?t=1165064
Is the WRX master cylinder OK with STi Brembos?
http://forums.nasioc.com/forums/show....php?t=1456630 *updated and better than the next link
I want to swap the front Brembos ONLY (not the rears) onto my WRX/L/whatever.
Can I use Evo/350Z Brembos?
CTS-V:
Evo to STi:
Evo to WRX:
http://forums.nasioc.com/forums/show....php?t=1453829
Old 01-23-2008, 11:52 AM   #3
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
Wish this thread was here when we did the 06 wrx with brembos!
This will help lots of people. WRXBrakes (Ken) knows tons of info on the swap!
rhinotech is offline   Reply With Quote
Old 01-23-2008, 12:06 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
Anyone with any ideas for FAQ's, please post
I will gradually fill this thing in, but help is always appreciated.
Old 01-23-2008, 12:19 PM   #5
SagaWRX
Member#: 32694
03 WRX
World Rally Blue
I just recently installed a full set of Brembos on my car.
I will try to write an install thread, especially for the rear including brackets, when I have free time.
SagaWRX is offline   Reply With Quote
Old 01-23-2008, 01:02 PM   #6
Butt Dyno
Member#: 17301
is the "dark side"
...just a few thoughts...
It would be nice to have:
- Info/part numbers for the rebuild kits, hardware (pins, clips, mounting bolts), etc.
- Torque specs for the bleeder screws & mounting bolts
- Bleed sequence (inner or outer bleed screw first?)
- Maybe a link to the "wheels that fit the STi" thread for wheel choices.
*noted
Old 01-24-2008, 11:30 AM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
using TCE's brake bias calculator you can see the effect of running Brembos w/ different combos in the rear-might be worth running the numbers ie Brembo front/ oe 266mm rear, Brembo front/FHI two pot rear, Brembo front/Brembo rear etc
Old 02-24-2008, 04:26 PM   #8
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Legacy777 has a spreadsheet that calculates that stuff and has the piston sizes and effective diameters already in it.
http://www.main.experiencetherave.co.../brakemath.xls
Also, could we have a summary of what it takes to swap brembos? Something like this:
Originally Posted by me
Brembos, like most other Subaru brakes, are interchangeable between models. However there are a few extra things that are needed.
Rotors:
The 05-08 STi has 5x114.3 rotors, where all other Subarus are 5x100. This means only 04 STi rotors will fit on other cars.
Rear Backing Plate:
The rear Brembos are 2-pot fixed calipers, and they will not bolt up to cars with 1-pot rear calipers. They will bolt up to an 06-07 WRX. To install them on another Subaru you need to swap backing plates (a pretty involved process requiring a press), or buy some adapter brackets. Kartboy manufactures adapter brackets and they are sold through various nasioc vendors.
Rear Parking Brake:
The STi has a 190mm parking brake. Most other Subarus have a 170mm parking brake. That means if you put 04 STi rear rotors on your car the parking brake will not work. Previously the options were to deal with it, have some spacers made to fit in the rotor, or buy expensive taller brake shoes from Godspeed in the UK. Fortunately DBA has started making a 5x100 Brembo rotor with a 170mm parking brake drum.
So, to swap brembos you need:
-Calipers and bolts (any 04-07 will work)
-04 front rotors
-kartboy rear adapter brackets
-DBA 2657 rear rotors
The 08 rear end is different and I don't think the calipers are interchangeable. You could use the 08 black front calipers though.
jamal is offline   Reply With Quote
Old 02-24-2008, 08:53 PM   #9
Butt Dyno
Member#: 17301
is the "dark side"
Yes, excellent suggestion. Sorry, just laziness on my part, and I am also hesitant to write something about doing a swap that I have never done. Yours sounds good tho
Old 02-26-2008, 07:12 PM   #10
Butt Dyno
Member#: 17301
is the "dark side"
Bump - added the new "master cylinder OK?" thread.
Old 03-06-2008, 08:55 PM   #11
atvracer111
Member#: 112179
2015 0RS,15STI,16wrx
Red, Black, Black
Just to add to the list. If your doing the Brembo front swap and use 07 sti Hubs, Rotors and Brembors on an 06 wrx you will need front struts and 05+ STI rims with the larger 5x114 also. I just did the swap and had to get STI struts for the front swap. This was all part of my swapping an 07 STI tranny into an 06 WRX. Still working on the wiring issue.
atvracer111 is offline   Reply With Quote
Old 03-24-2008, 03:17 PM   #12
Lynk
Member#: 47047
2004 wrx
just in case anyone comes in to find the obvious.. but do the limited black brembos pretty much follow the same guidelines as the gold brembos? same brakes right? would just need 04 sti front rotors like that other guy said to put it on any wrx. sorry been searching for that forever and i think it would be easier if someone comes in here and sees that.
Lynk is offline   Reply With Quote
Old 03-24-2008, 03:58 PM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
same-o except color
Old 03-24-2008, 04:10 PM   #14
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
i JUST found what this meant and would be helpful to put in possibly?
brownbo's , lol
paulmofyourhand is offline   Reply With Quote
Old 03-24-2008, 04:51 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Just be careful with the 08 rear sti calipers. Someone reported on IWSTI that they do not fit the rear even with older sti hubs. I have not been able to verify this yet however.
Tony
Old 03-30-2008, 02:04 PM   #16
Lynk
Member#: 47047
2004 wrx
What about the use of stainless steel lines.. they interchangeable with others? how about doing STi Brembo upgrade on a WRX, would you use say the 04 STi SS brake lines?
Old 03-30-2008, 06:37 PM   #17
NC2008STI
Member#: 175516
I have an 08 STi and want to change the pads out for a track event. Anyone know what pads will fit the 08? Is it the same as the 07?
NC2008STI is offline   Reply With Quote
Old 04-10-2008, 11:10 PM   #18
wrxdragger
Member#: 73052
2002 WRX Hybrid
CandyBluEcutek,GT30,?whp
So the rotors just change on the brembos in 05 5x114 and up. The 04 rotors are 5x100. But does the calipers change how the bolt up ?
wrxdragger is offline   Reply With Quote
Old 04-12-2008, 10:06 PM   #19
BIGSKYWRX
Member#: 7958
09 GH B+
calipers are the same
Old 05-11-2008, 05:48 PM   #20
mars636
Member#: 74547
2005 WRX
WR Blue
Does anyone know if a 06-07 rear rotor work with STi brembos on a 05 wrx and keep the E-Brake?
mars636 is offline   Reply With Quote
Old 05-22-2008, 04:57 PM   #21
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
I too want to know about this. I've heard the only difference is length but I'd hate to be realizing they won't bolt up when I'm too far into the project!
Abnormal is offline   Reply With Quote
Old 05-30-2008, 12:08 AM   #22
god910
Member#: 95443
2003 WRX
Sonic Yellow
If you look the Goodridge lines are the same for the WRX and STi. I have 04 STi Brembos on my 03 WRX.
Just so you KNOW they will work, I specifically installed the part # 24215 I still had the package, the funny thing is it's in the trash can on the curb. Trash pickup is in 10 hours or so.
god910 is offline   Reply With Quote
Old 08-22-2008, 06:58 PM   #23
MrSlowbaru
Member#: 129231
2005 wrx
cgm
where can i find a rebuild kit for brembos?
MrSlowbaru is offline   Reply With Quote
Old 08-23-2008, 12:14 AM   #24
god910
Member#: 95443
2003 WRX
Sonic Yellow
A little bird told me that Brembo pretty much says that your caliper should NEVER need to come apart... and thus, they don't sell a rebuild kit of any kind for them. I was looking so I could un-ass them for coating... no such luck, and I'm not about to take them apart with the hopes that I can just use some beefy o-rings to put it back together.
Another note... I was just reading the last link in the op, and it says TWICE in that thread that the torque spec for the Brembos is 114.3 lb/ft and "over 100".
I'm pretty sure that's bull****. The 2 manuals I checked showed 59 lb/ft... damn near half of what they are suggesting. I wonder why they had stripped threads?
Old 08-23-2008, 12:22 AM   #25
BIGSKYWRX
Member#: 7958
09 GH B+
they sell caliper rebuild kits for both the front and rear Brembos- available from your dealer or anyone that deals in Subaru parts
the caliper doesn't come apart, but the pistons are removed to replace the boots/seals- if you run track days a fair chance you'll at some point need to rebuild them
WTB: Passenger side gold brembo brake caliper for 06 STi sti-06 Private 'Wanted' Classifieds 0 02-12-2010 09:42 PM
FS:(IN) Front Brembo Brake Calipers from 04 STi teesutt Suspension/Brakes/Handling 23 01-23-2010 09:14 PM
Garage part out, swap leftovers, brembo, brake adapters, v3 gc8, Sti, ZEX, topsecret TurboCharged97L Complete Car Part-Out 35 05-06-2008 11:59 PM
FS: 05 STi Brembo Brakes, 05 STi HID Headlights, Aspen White 05 STi Hood w/Scoop ProdriveRex NWIC Private Classifieds 18 01-06-2008 07:04 PM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 07:41 AM
