Old 02-04-2002, 12:58 AM   #1
malelee21
Guest
Member#:
Question Turbo & High-Tech Performance Magazine Jan 2002 issue READ
Page 43
"XS Engineering Power Intake installed power figures rose by 13.9 horse power and 10.9 lbs-ft. More interesting is the fact that peak power was made earlier in the power band with 182.7 horse power at 5,684 rpm-more than 300 rpm sooner than the stock run....."
vs.
Page 36
"M2 package generaged 189.9 hp and 189.8 lb-ft of torque.... M2 Performance added its upgraded stock-mount intercooler, a 3 inch downpipe and a 3-inch exhaust..." also comes w/ AEM CAI.
After reading this article you might be wondering why M2 package resulted in only 7+ hp advantage over just XS Engineering Power Intake... considering M2 package comes with AEM CAI intake, turboback, and bigger intercooler.
13.9HP gain w/ only CAI is very questionable..... when CAI, turboback, bigger intercooler resulted in 21.1HP gain....
Old 02-04-2002, 01:15 AM   #2
jmott
Member#: 6713
2007 Prius
brown
Default Re: Turbo & High-Tech Performance Magazine Jan 2002 issue READ
many intakes get big power gains by screwing up the mass air sensor calibration to lean the car out.
Originally posted by malelee21
Page 43
jmott is offline   Reply With Quote
Old 02-04-2002, 01:15 AM   #3
malelee21
Guest
Member#:
On pg. 50, they dynoed IS300 w/ Weapon R Intake which only resulted in 3.7hp peak gain.
Old 02-04-2002, 01:27 AM   #4
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
TURBO = B.S.
Its simple math!
Kevin
(though I do think intakes are genraly worthwhile)
Red Rocket is offline   Reply With Quote
Old 02-04-2002, 03:07 AM   #5
mitch808
Member#: 10228
2002 Subaru WRX
Although another mag with a IS300 did a Stillen intake and got close to 10HP... I think in the ballpark of 7 or so.
Too many variables to consider
mitch808 is offline   Reply With Quote
Old 02-04-2002, 08:55 AM   #6
2.5RSt'd
Member#: 1294
12.80 @ 106.99
You are just talking peak horsepower what about torque acrooss the rpm band or horsepower increase across the rpm band...
Peak power is just a start for comparision.. which happens to be the one that everyone looks at but but often should be over looked until weighted against the other variables.
2.5RSt'd is offline   Reply With Quote
Old 02-04-2002, 11:14 PM   #7
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Blegh. Show me something comparing wideband o2 measurements and then we'll talk about your dyno results. Leaning out the car can produce that kind of power without an intake.
On another note, I'd like to see ONE person explain how they measured the "correct" air flow vs. what the meter is reporting. We asked shiv and he had no answer. Then, suddenly, the CAI-damning thread died. Does anyone have thoughts on how the naysayers are doing this? No conjecture, please, I wish to test it for myself, not wait around for someone's own "non-maf-confusing" CAI.
Conduit is offline   Reply With Quote
Old 02-04-2002, 11:25 PM   #8
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Its no BS.
It just proves how important engine management is. With intake, you might get away with few ponies, but when you start changing turbo's and intercoolers, you will do more harm than good if you do not have a properly tuned ECU.
-Alex
Imprezer is offline   Reply With Quote
Old 02-05-2002, 12:36 AM   #9
Conduit
Member#: 6162
No kidding. That's gospel, frankly.
Old 02-05-2002, 12:58 AM   #10
mid9s
Member#: 7777
2002 impreza WRX
Blaze Yellow
is that why Mark and shiv both say that a CAi in not worth anything? Could you make more power with there systems if they tuned them for it? Or not a CAI how about just a cone filter like the Blitz set up?
mid9s is offline   Reply With Quote
Old 02-06-2002, 01:57 AM   #11
Conduit
Member#: 6162
That's not entirely true. Mark said Al gained 20hp by adding the Injen intake when he had the car down there for mapping long ago (before he went Motec).
The only measurement I've seen other than dyno results for some CAIs (which are hard to trust, given the potential maf confusion that has been suggested) are the measurements I posted for the pressure drop across the stock airbox/maf/post-maf-neck vs. my AEM. There was a significant difference. I really do want to test this maf confusion issue (that aftermarket intakes cause "wrong" measurements), but again, noone can tell us how THEY tested it, let alone how to do it. I know experience can go a long way, but these blanket statements are a little suspicious.
Old 02-06-2002, 02:06 AM   #12
mid9s
Member#: 7777
2002 impreza WRX
Blaze Yellow
I would think that the size and depth of the tube that the MAF is in is how they change the reading.
Old 02-06-2002, 02:36 AM   #13
Conduit
Member#: 6162
I thought the same, but if you think about it, the larger tube, while flowing more air overall, will have a lower velocity, so less gets measured within X-time (as I was told here).
You are starting to see the problem
Old 02-06-2002, 03:07 AM   #14
nmyeti
Member#: 4980
You sure about that? Because i remember a conversation with mark where he was talking about Al's power meter numbers, and saying something to the effect of "its not showing up on the dyno"
-Nathan
nmyeti is offline   Reply With Quote
Old 02-06-2002, 10:47 AM   #15
WRBLUEWAGON
Member#: 10745
2006 VW SUV
The power meter is a toy. So those numbers are high. I could think his is getting good numbers with a big turbo but 20hp from the intake is just off
WRBLUEWAGON is offline   Reply With Quote
Old 02-06-2002, 11:44 AM   #16
TurboRex
Member#: 8635
04 STI, 07 FXT
I feel that changing the size of the tube is how they trick the ecu. If the CAI has a slightly larger tube, then the maf thinks there is less air (lower velocity) even though the same amount is flowing at a certain rpm and thus lowers the amount of fuel. This is why it would lean things out.
If the tube size is the same, then maybe the turbulance and change in air flow caused by the stock air box is the problem. I would like to see results with the stock air box with the filter taken out. An elbow with a cone filter is then used instead.
I have another question on the CAI. Is there a way you can modify the filter so that it is not so loud? Seems like there would be a way to have free flowing air that is more quiet.
Greg
TurboRex is offline   Reply With Quote
Old 02-06-2002, 01:18 PM   #17
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I totally believe that Al got 20hp by adding the intake. However, his car was already so modified that the intake was becoming a restriction.
Well, the WRX maf uses a heated wire MAF. This means that with a bigger tube, the maf will see a lower air velocity and thus lower cooling for the same amount of air. Since the MAF is reading less air, the ECU injects enough fuel for the reading... BUT there is actually MORE air than the maf is reading so the engine is lean. I don't see the problem here...
Leaner means more heat/detonation, better fuel economy, slightly more power. CEL's too if you're lucky.
nhluhr is offline   Reply With Quote
Old 02-06-2002, 01:25 PM   #18
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default more
also, since the wire is a heated element, I'm assuming the MAF works by monitoring the voltage require to keep the wire heated to a certain temp. More voltage required = more air cooling the wire.
Alternatively, it might measure the resistance through wire, which will increase with temperature. So if the air is not flowing fast, the temp of the wire is high and resistance is high. Thus, you'd get lower resistance at higher cfm through the intake.
The actual method the factory maf uses is unknown to me. Jon [in CT] please chime in if you know!
Lot's of magazines: Sport Compact, Turbo High Tech Performance.... blackturbo Tri-State Area Private Classifieds 1 05-25-2009 11:26 PM
TURBO& HIGH TECH PERFORMANCE MAGAZINE is done tekfoc General Community 22 12-07-2008 07:06 AM
January Issue of Turbo & High Tech ERaab212 Tri-State Area Forum 23 11-07-2004 05:23 AM
Super Street, Import Tuner, Turbo and High Performance and Sport Compact Car Magazine VolkWRX Private 'For Sale' Classifieds 0 09-26-2003 12:16 AM
Jan '02 issue - "Automobile" magazine ScoobieRu Tri-State Area Forum 8 12-22-2001 01:17 PM
