Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-23-2008, 09:17 PM   #1
Vmiz
Member#: 115744
Default Is there points for coolness
Got to work monday and just wanted to try something different.
hurt power but gotta be points for a cool setup
Just thought i d share a picture
Vmiz is offline   Reply With Quote
Old 01-23-2008, 09:22 PM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
How does the Airflow sensor work?!
+1 for coolness though. =P
formula91 is offline   Reply With Quote
Old 01-23-2008, 09:42 PM   #3
WeakSauce2.5i
Member#: 150006
2009 Nissan 370z
18g Bugeye (sold)
different. . . ima have to give +1
WeakSauce2.5i is offline   Reply With Quote
Old 01-23-2008, 09:42 PM   #4
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
thats insane.
Subyroo2.5 is offline   Reply With Quote
Old 01-23-2008, 09:46 PM   #5
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
That's still workable, dude. Nice job! If you put stacks inside the plenum boxes before you welded it, maybe it's the hot air straight off the motor hurting power. If that's two pieces that bolt together, consider an intermediate flange with the stacks on it, bolted between the two.
Get two 90 degree bends of whatever diameter you've got there and put the filters on the other end. The air needs to accelerate a touch. You did a nice job on all that hard work already. Don't give up yet. I considered that exact setup. It just needs a bit more length, IMO. There's no boost pushing the air in, so it needs more velocity.
HamFist is offline   Reply With Quote
Old 01-23-2008, 10:07 PM   #6
Vmiz
Member#: 115744
no flow sensor on a hydra
hamfist runners have a radius in the plenum and yes was gonna try a cold air of some sort to try to get a little air speed
as far as engine temp was 40 with the doors open when we dynod it tonight with fans so heat wasn t that big of a issue
i ll play with it a little before i make a tunnel ram for it for fun ,haven t seen a subie with a plenum out of the hood yet so it ll be fun
had a 06 manifold on it before with nice runner length but i really don t care for the runner size so i ll throw something together this week and try it
Old 01-23-2008, 10:21 PM   #7
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Cool. I think 12-18 inches long and maybe a bit over 2in. diameter pipe. If it's possible, point the throttle bodies out instead of in while you're goofing off and see what happens. It's not so much the colder air, as it is the extra distance. A mandrel bend makes smooth air acceleration .
I moved the throttle blades away from the port, very much on purpose for velocity and a bit smoother response. But, there's a tuned length above that I haven't figured out yet. From the intake valves to the throttle plate is about 8 inches, but the injectors are still right next to the port.
I'm also opening my throttles towards the top of the ports for improved velocity, since that's where the air travels the fastest. I notice your's open left to right. That's something else to consider.
Old 01-23-2008, 11:24 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Turn the intakes into a ram air setup and it might work...
Old 01-23-2008, 11:30 PM   #9
Vmiz
Member#: 115744
yes hamfist i know all about runner lentghs and size have built a few manifolds over the years as well as hours and hours on flow benches making manifolds on different apps this was just messing around to see what it would do
i appreciate the input though some of the guys here don t know as much about shapes and sizes so its always good to share the info with the ones who would like to know and better understand it
Old 01-24-2008, 12:44 AM   #10
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
vern always impressive work, can't wait to see what the ram air will look like. sorry I didn't get a chance to say goodbye to you guys before I left.
LA is offline   Reply With Quote
Old 01-24-2008, 01:05 AM   #11
imprexaRS03
Member#: 145883
2008 wrx
psm
dam thats clean..whats the little blue box near the fire wall for??
imprexaRS03 is offline   Reply With Quote
Old 01-24-2008, 01:07 AM   #12
rougeben83
Member#: 115154
2005 Outback XT
White on grey
You're one step away from ITB's. Any of that in the works?
rougeben83 is offline   Reply With Quote
Old 01-24-2008, 04:21 AM   #13
GFimpreza
Member#: 40674
94 Impreza wagon
1.8L + 657cc's
That's awesome!
Any chance at viewing the dyno graphs?
GFimpreza is offline   Reply With Quote
Old 01-24-2008, 08:29 AM   #14
Vmiz
Member#: 115744
hey LA
little blue box is a vacume block
as far as graphs thers one around here that i posted on the cars 187hp run this setup so far lost 10-15,i ll tweak it a bit and see what i can do with these pieces suprizing enough can t really feel the power lose on the street as much as i thought i would
Old 01-24-2008, 10:06 AM   #15
Kyle86NA
Member#: 165576
1998 Legacy GT 5mt
Youre not really going to have much gains from that set up unless you have a huge intake cam... And if you do, I am sooo jealous. I had ITBs on my 86 MR2, and I miss the noise Oh so much...
Kyle86NA is offline   Reply With Quote
Old 01-24-2008, 10:23 AM   #16
yut_to_that
Member#: 124753
thats really awesome man, i love it!
yut_to_that is offline   Reply With Quote
Old 01-25-2008, 10:18 PM   #17
Vmiz
Member#: 115744
well i ll keep it to put on and play with another day or for meets
today i put a believe it was off of a legasy we had around here the plastic manifold i like the shapes of the runners will try it on the dyno tomorrow to see what it does
in the mean time i ll be building a long runner manifold to try with dual throttle bodies
just want to make the motor have more bottom end for around town fun
Old 01-25-2008, 10:45 PM   #18
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Nice fabrication, neat & clean
Buck Rogers is offline   Reply With Quote
Old 01-25-2008, 10:52 PM   #19
alejo
Member#: 170081
2004 2.5RS
blue
why did it hurt power? really nice work by the way
alejo is offline   Reply With Quote
Old 01-26-2008, 12:52 AM   #20
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Because he paired the wrong cylinders. But i give him a major +1 for dong something different.
When you pair two cylinders on the same head on a boxer motor you get two intake pluses close together then a pause. Not the best thing for even flow entering each cylinder.
I wonder if there is a way to have two separate plenum's going across the motor.
RS_to_WRX_swap is offline   Reply With Quote
Old 01-26-2008, 08:21 AM   #21
Vmiz
Member#: 115744
hmm didn t think about that just did it never seemed to give a problem on old vws and porshes but nothing but a little welding to try it out i ll let ya know
is there copper for sti 2.5l? FadiSTI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2006 09:13 PM
Is there room for a cat... cperkins Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-11-2006 12:13 AM
Is there a really cool place to celebrate a girl's birthday in Riverside? OLMEK Southern California Impreza Club Forum -- SCIC 23 01-07-2004 05:35 PM
Is there a really cool place to celebrate a girl's birthday in Riverside? OLMEK Off-Topic 11 01-06-2004 03:59 PM
Glovebox light kit. Is there one for the Impreza? david2z4 Interior & Exterior Modification 1 10-17-2000 05:07 PM
