Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 01-22-2008, 01:30 PM   #1
botboy
Member#: 40393
1985 MB 300DT
Maroon
Default End of my wits problems with '01 forester
Hi guys have problems, I'm a mechanic/lurker and not really a subie guy but my subie friends tell me this is the place to get advice and man, do I need it...
I'm at wits end with a car that came into the shop. '01 Forester L, AWD, 2.5, automatic
The car at idle, will "lope", that is the RPM's fluctuate slowly like the car has a big cam. I can smell that the car is running lean, it will lope slowly, then even out, and repeat. It does this even worse when stopped in gear
When trying to drive it, the car bogs down badly and has no power ,then will suddenly recover and accelerate like normal
As part of maintenance (car had been neglected when it came in) the plugs, wires, fuel, air filters have been replaced
another mechanic recently also replaced both 02 sensors
I've determined that the car is running lean, and starving for fuel when it bogs down by hooking a DMM with a duty cycle function to injector wires and having a coworker do a brake stand while I watched the meter. confirmed this by spraying a little carb cleaner into the intake while he was doing a brakestand, and the engine accelerated like it should. Fuel pressure stays constant, and within spec while this is happening. If the other guy stays in the throttle long enough, the car will recover, injector pulse will increase and the engine will accelerate as normal.
The car has no CEL, when it did set a CEL it was for 02 reporting overly lean, I can smell clearly the car is running lean at idle and elsewhere
in figuring this out, I've tried, with no luck, the following items:
- coil pack
- cam & crank sensors
- ECU
- TPS
- Map/intake temp sensor
- idle air control motor
- also tried the "grounding mod" mentioned elsewhere on this site
- removing exhaust
- disconnecting battery for 15 mins
I don't really know what else could cause the injector pulse to decrease with additional throttle/RPM. Anyone have any ideas? Bueller, bueller?
botboy is offline   Reply With Quote
Old 01-22-2008, 02:27 PM   #2
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
any modifications?
Also, you might want to try rs25 in addition to this forum. rs25 is for nonturbo subies.
Good luck man.
Kevin
subikid is offline   Reply With Quote
Old 01-22-2008, 02:36 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What you are describing sounds a lot like what my car does when the front O2 sensor starts to go bad. It will often do this without throwing a code. Maybe whoever did the sensor didn't really change it?
Old 01-22-2008, 02:43 PM   #4
NYCBRED
Member#: 164282
2007 Legacy 2.5i LTD
clogged throttle body??
NYCBRED is offline   Reply With Quote
Old 01-22-2008, 03:06 PM   #5
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
Make sure the battery is grounded well, stock subies sometimes have that problem.
probably too simple though.
bagelicious is offline   Reply With Quote
Old 01-22-2008, 11:16 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
is air getting in somewhere other than your TB? clogged injectors?
yarrgh is offline   Reply With Quote
Old 01-22-2008, 11:28 PM   #7
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
fuel pump or filter?
PhilSine is offline   Reply With Quote
Old 01-22-2008, 11:49 PM   #8
GrundleJuice
Member#: 165749
A vac or intake leak would cause the lean condition and lumpy idle... as for loss of power and injector pulse abnorm's i have no idea. Not knowledgeable with injector systems specifically. have you done a vac check or checked all the intake gaskets/joints? If you do figure it out, please let us know just for piece of mind and future reference. Hope you get some help.
Old 01-22-2008, 11:52 PM   #9
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Would be my first place to start
sense of nature is offline   Reply With Quote
Old 01-23-2008, 12:19 AM   #10
GrundleJuice
Member#: 165749
wouldn't a bad fuel pump or clogged filter cause low fuel pressure?
Wont carb cleaner cause the engine to accelerate no matter what its condition?
Old 01-23-2008, 02:55 AM   #11
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Are you sure the "other" mechanic put the right o2 sensor in? I could be wrong, but I thought the newer siby's used a wideband front, whereas the older suby's use a narrowband. That could cause a problem. I would make sure you dont have any vacuum leaks.
If you know you have spark, and the engine gets power when you spray fuel into it manually.....and you say fuel filters and pressure is good......that would lead me to think the injectors could be clogged. Could also be the fuel pump relay going bad, even though i've never heard of that happening.
~Josh~
ballitch is offline   Reply With Quote
Old 01-23-2008, 10:24 PM   #12
wirolla
Member#: 109725
2001 GM6
SRP
+12345....i agree.
wirolla is offline   Reply With Quote
Help with '01 Forester front crossmember and control arms on '95 Impreza Jard Brakes, Steering & Suspension 8 03-04-2010 03:42 PM
I'm bored out of my wits you lazy sacks of crap! brucelee Off-Topic 36 12-23-2007 03:24 PM
Car chase ends in front of my apt. building with bad results. Erudition Off-Topic 42 12-12-2005 07:38 PM
Well, the end of my time with the RS is here... subyguy2 Mid Atlantic Impreza Club -- MAIC 7 05-24-2004 04:52 PM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 12:23 PM
