Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 01-24-2008, 12:40 AM   #1
ronnie s
Member#: 168261
Default injector latency?
Anyone have a good guide on this? I don't know where the injectors came from but I know they are 650cc.
ronnie s is offline   Reply With Quote
Old 01-24-2008, 08:35 AM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Need to which ones .
Some require more latency than others , look @ the stock inj times Figure out the difference i.e stockers are 420 so if you had 840's you'd double the times , get it ?
Some like deatschwerk may not need to adjusted like that I use stock times on my 650's from them
sense of nature is offline   Reply With Quote
Old 01-24-2008, 10:53 AM   #3
ronnie s
Member#: 168261
ya thats what i've done and it seems to work ok. Someone should come out with a nice guide for this. I tried the sti values at first and it helped out then I went up from there until I saw the values I wanted. I guess if the number works its good for now.
Old 01-24-2008, 11:49 AM   #4
benw
Member#: 103320
2005 wingless
aspen white
Deatschwerks injectors are the same as stock, so the physical coil latency is unchanged. However, different ECU latency settings are required to achieve the final fueling result that allows for the least amount of AF correction.
benw is offline   Reply With Quote
Old 01-24-2008, 01:25 PM   #5
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I disagree. I use DW650 on my LGT. The LGT and STi stock injectors are the same. The DW650 definitely have different latency than stock.
In closed loop (low load), do a scatter plot with load on the X-axis and total correction on the Y-axis. If the latency is correct, the scatter plot will be cloud around +-5%.
At high load, the latency has almost no effect. At low load, the latency affects the AFR correction the most. This will guide you in how to adjust latency versus scalar.
mickeyd2005 is offline   Reply With Quote
Injector Latency Value Database hawker800mech AccessPort 18 08-18-2014 10:44 PM
injector latency values between two different injector designs... WRXINTX Open Source Reflashes 1 09-29-2009 07:21 AM
Injector Latencies RC 750's chanders Engine Management & Tuning 0 11-09-2008 02:47 PM
CAR WILL NOT START! ? about injector latency ktulu990 Commercial ECU Reflashes 7 02-06-2008 02:57 AM
Is Injector Latency Linear roybfr Engine Management & Tuning 6 05-23-2006 12:50 PM
