Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-24-2008, 04:40 PM   #1
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
Default help with grounding mod
hey watsup guys ... i got a 06 impreza 2.5i
and i was trying to put more ground wire
but i got into little trouble ...
i've searched but couldnt locate those bolts in my car
1. battery neg to driver side chassis
2. battery neg to passenger side chassis
3. battery neg to passenger side one of the strut bolt
4. battery neg to both heads ..........................
5. battery neg to bolt near firewall ...................
i couldnt find # 4 and 5 which is 3 bolts...
and i thought 8 wires all togather ... does anyone know where 8 wires going into ??
any pics ??
06impreza2.5i is offline   Reply With Quote
Old 01-24-2008, 06:03 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Here's mine:
I'll look for the online instructions I used, but I can't seem to find them so far.
Old 01-24-2008, 07:27 PM   #3
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
Subaru Banner
does this help at all???? if so how
acemyles2.5i is offline   Reply With Quote
Old 01-24-2008, 07:29 PM   #4
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
pre model's are same as 06 ??
Old 01-24-2008, 07:34 PM   #5
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
i got a terrible lag on 1st gear below 2500 rpm ...
so i wanna put more ground to get rid this lag
Old 01-24-2008, 08:53 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
It was to show where the bolts were... the EJ engines are basically the same. If you need them pointed out in the picture, let me know.
Old 01-25-2008, 12:21 AM   #7
2.5~rs
Member#: 158794
xxxx wrx
put them where ever the furk u want. theres bolts all over u can use
2.5~rs is offline   Reply With Quote
Old 01-25-2008, 02:57 AM   #8
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
Try to remember where mine are...
1) Alt
2) Headlight
3) Strut Tower
4) Throttle body
5) Intake Manifold
6) Near or on tranmission
7) Near slave cylinder
8) Can't remember...
Major Johnson is online now   Reply With Quote
Old 01-25-2008, 08:50 PM   #9
GrundleJuice
Member#: 165749
anyone have links or dyno sheet to show what gains the grounding mods will give?
Old 01-25-2008, 09:03 PM   #10
SilverSubie2.5
Member#: 136144
2006 WRX Wagon
CGM
I'm not really sure the grounding mod makes enough of a difference to need to be proved on a dyno, but I could be off. Pretty sure its main effect is making revs and overall driving smoother, more consistent with better throttle response.
SilverSubie2.5 is offline   Reply With Quote
Old 01-26-2008, 02:23 AM   #11
06impreza2.5i
Member#: 150106
2006 Impreza 2.5i
SGM
i just wanna try everything to get this lag out of my car ...
i even tried wot at 4th gear ....it did worked but it keeps comming out
Old 01-27-2008, 12:47 AM   #12
GrundleJuice
Member#: 165749
well better throttle response and smooter revs means more efficient breathing and it should show up on dyno.
Huh?
Old 01-27-2008, 08:01 PM   #13
SilverSubie2.5
Member#: 136144
2006 WRX Wagon
CGM
It does?
help me with grounding mod 06impreza2.5i Tri-State Area Forum 3 03-31-2008 03:47 AM
need help with grounding kit mcgizzle General Community 2 10-26-2004 02:28 AM
help with ground controls/koni csleee Texas Impreza Club Forum -- TXIC 1 05-21-2004 03:01 PM
Help with grounding mod wrichiex_sti Electrical & Lighting 6 12-18-2003 05:23 PM
Need help with Ground Control installation skyliner33v Brakes, Steering & Suspension 3 12-24-2001 06:07 PM
