Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Vendor Classifieds
Closed Thread
Old 01-24-2008, 03:42 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Racecomp's BIG thread for BIG Texas!!!
(mods, we have Nick's permission to post here)
We've noticed we get a lot of love from TXIC, and as a vendor advertiser for this region, we're allowed to make a vendor thread here. So we thought we'd extend some special deals for TXIC only!
__________________________________________
Racecomp Engineering Tarmac Coilovers
Racecomp Engineering Tarmac II Coilovers for Subaru Impreza
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Racecomp Engineering chose KW Suspension to co-brand the Tarmac 2 coilovers due to their remarkable racing heritage, consistent and impressive build quality, and phenomenal presence and support in the United States.
Racecomp is happy to announce the option of having the RCE Tarmac 2 coilovers fully assembled with either Group N strut top mounts or RCE Camber Plates and Rear Pillowball mounts.
Available for:
2002 - 2007 Subaru Impreza STI, WRX sedan, WRX Wagon, and 2.5RS
1993 - 2001 Subaru Impreza Coupe, Sedan, and Wagon
$1899 shipped
With Group N strut top mounts front and rear - $2249 shipped
With RCE Camber Plates and RCE Rear Pillowball Mounts - $2699
shipped
Racecomp Engineering Tarmac I Coilovers for Subaru Legacy
Following the successful release of our coilovers for Subaru Impreza, Racecomp Engineering decided to extend their coilover line to include 2005+ Subaru Legacy. Featuring the same stainless steel technology, limited lifetime warranty, and KW quality as the Tarmac II’s, these coilovers were designed with linear spring rates and valving that mates perfectly for the Subaru Legacy street/track driver.
Available for:
2005 - 2008 Subaru Legacy GT, Spec B, and 2.5i Sedan and Wagon
$1399 shipped!
__________________
Call us for an appointment for installation
www.racecompengineering.com ---
www.GTWORX.com
Cobb - SwiftWhiteline - Cusco - Alpinestars - Prodrive
Ohlins - Moton - KW - Bilstein - STi - Pagid - Ferodo - Piloti
6360 Unit J South Hanover Rd.
Elkridge, Maryland 21075
410-579-1501 Phone
443-370-9000 Mobile
RaceComp Engineering is offline
Old 01-24-2008, 03:42 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Lowering Springs Line-up
Yellow for STi
Rates
Front - 295 lbs/in
Rear - 275 lbs/in
Drop
Front - 23 mm
Rear - 20 mm
$339 shipped
_________________________________________________
Regular Guy “RCE Blacks” for STi
Rates
Front - 285 lbs/in
Rear - 269 lbs/in
Drop
Front - 15 mm
Rear - 10 mm
$339 shipped
WRX Wagon
Rates
Front - 278 lbs/in
Rear - 259 lbs/in
Drop
Front - 28 mm (from WRX height)
Rear - 24 mm (from WRX height)
$339 shipped
Old 01-24-2008, 03:42 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Camber Plates and Pillowballs
Racecomp Engineering Lowering Camber Plates
These front camber plates were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs as they lower any car by 3/8" WITHOUT sacrificing suspension travel.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS
$449 shipped
Racecomp Engineering Non-Lowering Camber Plates
These front camber platers were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs. These do not lower or raise the car, and DO NOT sacrifice suspension travel.
Available for:
$449 shipped
Racecomp Engineering Rear Pillowball Mounts for Impreza
Made with the highest quality available aircraft grade 7075 T651 aluminum and using a new extra heavy duty spherical bearing, these pillowball mounts will be up to the task of both heavy track and street duty. These solid mounts provide quicker reactions, more feedback, and a more direct feel from your suspension. Our Rear Pillowball Mounts were developed specifically to provide a solution for Racecomp Engineering Tarmac II coilover users looking for the maximum possible performance out of their coilover system.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS. Fits coilovers only.
$339 shipped
Old 01-24-2008, 03:43 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
saved for carbon brake ducts
Old 01-24-2008, 03:43 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
GTSpec Braces
$165 shipped -
GTSPEC FRONT Type D Strut Brace
call for carbon and ti versions!!!
$155 shipped - GTSPEC REAR Type F Strut Brace
$155 shipped - GTSPEC REAR Type F Strut Brace for WAGON
$215 shipped - GTSPEC Fender Reinforcement Braces
$155 shipped - GTSPEC 4 Point Front Ladder Bar
$205 shipped -
GTSPEC Front Lower Tie Brace
$655 shipped -
GTSPEC Subframe Reinforcement Brace (3 piece set)
$185 shipped -
GTSPEC Rear T Brace (2 piece set)
CALL 410-579-1501 to order!!!
RCE
Old 01-24-2008, 03:44 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Cusco Braces
$145 shipped - Cusco Front Type-OS Strut Tower Bar
$145 shipped - Cusco Rear Type-OS Strut Tower Bar
$149 shipped - Cusco Lower Bar Version II
$120 shipped - Cusco Rear Subframe Brace
Old 01-24-2008, 03:44 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Whiteline Suspension
Whiteline Adjustable Swaybars
27mm Front Adjustable Sway Bar - $202 shipped
27mm Rear Adjustable Sway Bar - $202 shipped
24mm Front Adjustable Sway Bar - $174 shipped
24mm Rear Adjustable Sway Bar - $184 shipped
$294 shipped - Whiteline Max-C Camber Plates
$304 shipped for motorsports/coilover version
$191 shipped - Whiteline Anti-Lift Kit
$205 shipped for motorsports version
$174 shipped - Whiteline Roll Center Kit
Swift Springs
$279 shipped - Swift WRX Springs
Cusco
$254 shipped - Cusco Motor and Tranny Mounts
GTSpec
$184 shipped - GTSPEC Rear Differential Mount
Old 01-24-2008, 03:44 PM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
KW Suspension
$1449 shipped - KW Variant 1 Coilover
fits 2002-2007 WRX and 2004 STi.
inexpensive coilovers that don't suck.
Ohlins Suspension
$1889 free shipping - Ohlins Fixed Perch Struts
$2129 free shipping - Ohlins Fixed Perch Struts with any of the following springs:
RCE Yellow Springs
RCE Black Springs
RCE Wagon Springs
Swift Springs
Prodrive STi Springs
fits all years and models Subaru Impreza
Old 01-24-2008, 03:45 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Pagid Brakes
Pagid Street and Race Pads
STi Pads Only
$402 shipped - Black 4-2-1 (Street Only) - Front and Rear Set
$402 shipped - Blue RS5 (Aggressive Street/Light Track) - Front and Rear Set
$456 shipped - Yellow RS29 (Track Only) - Front and Rear Set
Performance Friction Brakes
PFC Race Pads
STi Pads Only
$463 shipped - PFC01 (Track Only) - Front and Rear Set
Ferodo Brakes
Ferodo Street and Race Pads
STi Pads Only
$285 shipped - DS2500 (Street/Light Track) - Front and Rear Set
$445 shipped - DS2500 (Track Only) - Front and Rear Set
Hawk Brakes
Hawk Street and Race Pads
STi Pads Only
$196 shipped - Hawk Ceramic Performance Pads (Street) - Front and Rear Set
$535 shipped - Hawk DTC-70 (Track Only) - Front and Rear Set
Old 01-24-2008, 03:45 PM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Tarmac 2 Coilovers for GC Impreza
These are the latest offering from Racecomp Engineering, geared specifically to our GC guys and girls. We wanted to offer our Tarmac II coilover system for the lighter and smaller GC chassis.
http://www.rs25.com/forums/showthrea...=68852&page=17
RacecompEngineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. RacecompEngineering chose KW Suspension to co-brand the Tarmac 2 coilovers due to their remarkable racing heritage, consistent and impressive build quality, and phenomenal presence and support in the United States. RacecompEngineering and KW Suspension have jointly worked on and added many differentiating options and features to the design of an already tried and proven damper. After emerging as an exceptional knowledge resource for Impreza suspension applications through years of first hand experience with nearly every suspension option available for the Subaru Impreza, RacecompEngineering can now provide their own solution that truly caters to the core of Subaru track day and race enthusiasts.
Description continued: 345/240 optional with 400/340 standard. Actual dampers will come with yellow springs and black perches and reservoirs on front and rear. To be used with group-n tops, RCE topmounts or Cusco front plates with group-n rear, etc.
EDIT: One other thing I wanted to add...for a GC these would be able to handle up to a 550lb spring front and rear for people that autocross/track.
Warranty:
Warranty goes through KW and is the same lifetime warranty on parts and 2 year warranty on parts and labor.
$1499 shipped. ONLY 1 at this price.
In stock and ready to ship.
Regular price is $1799.
Old 01-24-2008, 04:07 PM   #11
lackofhp
Member Sales Rating: (15)
Member#: 149001
09 Caliber
ex 07 WRX
spring rates and drop on the Swift Springs? 07 WRX Sedan
lackofhp is offline
Old 01-24-2008, 05:59 PM   #12
the_poser
Member Sales Rating: (4)
Member#: 106234
'o8 5.7 Tundra
'07 sv650s
dude the RCE wagon springs look sweet
*goes and adds to list*
the_poser is offline
Old 01-25-2008, 12:15 AM   #13
JustA4
Member Sales Rating: (7)
Member#: 58210
2004 35r STi
186mph - standing mile!
Awesome. Have always had great customer service from you guys (even when just calling for their opinions).
JustA4 is offline
Old 01-25-2008, 01:19 PM   #14
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
thanks!
- drew
Old 01-25-2008, 01:22 PM   #15
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
190 lbs front
151 lbs rear
25mm or 1 inch drop front
20mm or .8 inch drop rear
One of the better springs out there for WRX.
- Andrew
Old 03-03-2008, 05:39 PM   #16
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
okay....new thread coming soon.
Closed Thread
This thread tastes like Texas Toast: RCE Suspension and Brakes BIG TEXAS SALE!!! RaceComp Engineering TXIC Vendor Classifieds 14 05-14-2008 08:15 AM
big giant for sale thread. something for everyone. LatentWagen Tri-State Area Private Classifieds 68 11-07-2007 02:52 PM
Noplace but Texas (another thread for the TXIC haters) cloudbase Off-Topic 19 12-11-2006 04:33 PM
big huge for sale thread, something for everyone. CHEAP. LatentWagen Engine/Power/Exhaust 51 08-15-2006 08:16 PM
Are Subaru's big enough for big people? Diabolical1 CC General Community 29 12-30-2005 12:48 PM
