Old 01-24-2008, 05:14 PM   #1
Tea cups
Member#: 103136
Default Turbo Dynamics and boost control explained
Tea cups is offline   Reply With Quote
Old 01-24-2008, 05:14 PM   #2
Tea cups
Member#: 103136
This was a sticky on the Enginuity site before it went down.
Old 01-24-2008, 05:33 PM   #3
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Thanks!
Infamous1 is offline   Reply With Quote
Old 01-24-2008, 06:44 PM   #4
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Cheers for the info Tea Cups.
Do you have any other "stickies" from the Enginuity site that you could post that will help?
--- Start Ignore ---
Also, was there ever a "beginners tuning guide" or similar for Enginuity? Something that shows the steps involved in tuning and what all the features/settings/parameters mean in Enginuity?
---End Ignore ---
My bad, I did some googling and found a link to Scoobypedia's Open ECU Tuning Guide and Documentation Index that has all the info I was after
wrxsti.l is offline   Reply With Quote
Old 01-24-2008, 07:04 PM   #5
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Thanks!
+1 on any good info from enginuity.
ExpO is offline   Reply With Quote
Old 01-24-2008, 07:09 PM   #6
Tea cups
Member#: 103136
The only other sticky I had was the "closed loop to open loop transition and delay explained", but I don't have a copy of it and can't find it cached anywhere and I don't want to redo it from scratch as I know it is out there somewhere.
Old 01-24-2008, 10:35 PM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I hope someone stickies this thread. This is the best description of Subaru boost control that I have found. It is a closed loop (feedback) system. Check out Proportional Integral Derivative controller in wikipedia.org.
http://en.wikipedia.org/wiki/PID_controller
Many of the tunes that I have seen block out the turbodynamics so that boost is controlled strictly by either minimum or maximum WGDC. The problem with this is that boost is then only controlled for one type of driving (e.g., 3rd gear from 2000 to redline). If you drive in any other way (different gear or start from a different rpm), you will either underboost or overboost.
Take a look at this PID feedback example:
And compare that to what happens when overboosting occurs in 5th gear and underboosting in 2nd gear.
The best way to learn more about turbodynamics is to log TD Integral and TD proportional and log all kinds of driving:
1. 2nd gear from 2000 to redline
2. 3rd gear from 2000 to redline
3. 4th gear from 2000 to 4000 rpm
4. 5th gear from 2000 to 3500 rpm (only if your intake doesn't resonate)
5. 3rd gear from 3000 rpm to redline
6. 4th gear from 2500 rpm to 4000 rpm
7. 2nd gear to 6500 rpm and then shift to 3rd and continue WOT
You will see that the WGDC needed to hit target boost varies depending upon time (related to load) and previous boost state.
mickeyd2005 is offline   Reply With Quote
Old 01-25-2008, 10:36 AM   #8
legav05
Member#: 51287
2015 Tesla P90D
What happens if your intake resonates?
legav05 is offline   Reply With Quote
Old 01-25-2008, 11:41 AM   #9
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
That's kind of off-topic, but it can cause knock due to the air surging which causes momentary lean spikes.
I have seen it in 5th gear at 18 psi at 2700 rpm with the LGT K&N intake and I have also seen it happen in 4th gear at a much lower psi with the SPT intake at about 2500 rpm. I's not a problem for big turbos since they don't build up that much boost at low rpm.
Old 03-27-2008, 03:43 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
One thing I don't understand is what is your final wastegat duty cycle?
In other words
How is the final wastegate duty being apply to the car calculated from
Intial Wastegate Duty
Max wastegate duty
Compensations
TD proportional
TD Intergral + / -
Thanks
Bad Noodle is offline   Reply With Quote
Old 03-27-2008, 07:44 PM   #11
Tea cups
Member#: 103136
In other words
Max wastegate duty
Compensations
TD proportional
TD Intergral + / -
Thanks
The wg compensations are applied to both initial and max wgd (they are relative, so 10% compensation of 50% WGD = 55% WGD). However, TD correction is absolute.
x = initial wgd (post-comp) + TD prop + TD integral cumulative
if x > max wgd (post-comp) then x = max wgd
if x > "Wastegate Duty Limit (Maximum)" then x = "Wastegate Duty Limit (Maximum)
final wgd = x
Old 03-27-2008, 08:15 PM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ thanks man, you rock
Anyone have a nice clean way to mount a greddy turbo timer and boost controller? Cards2323 Interior & Exterior Modification 14 05-16-2007 11:28 AM
Turbo Inlet and Boost Controller Lines 02 WRX MyMY02WRX Private 'Wanted' Classifieds 2 09-01-2006 11:44 AM
GREDDY turbo time and boost controller for sale!! HighEndWRX Private 'For Sale' Classifieds 1 02-06-2004 12:22 PM
turbo timer and boost controller instal wrxnut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-09-2003 06:09 PM
Turbo timer and boost controller questions yeloREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-19-2001 11:41 PM
