Old 01-24-2008, 10:09 PM   #1
Sasco
Member#: 70237
1998 Impreza L
Glacier White
Smile WRX axleback on a 1.8 L?
A WRX axleback recently came into my possession. I figured I might as well put it to good use and install it on my car. I knew it might not be the right size, and it wasn't! So I come to you, Nasioc, asking for help. What do I need to make this ish fit?
Sasco is offline   Reply With Quote
Old 01-24-2008, 10:14 PM   #2
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
dunno. i always like a welder on hand but I have no idea because i havent seen a wrx exhaust in a while. I put a full 3" borla on my 96. that went well, and all i needed was a welder and a cutting wheel.
96SubyImpreza is offline   Reply With Quote
Old 01-24-2008, 10:36 PM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
It should have bolted right up...
The impreza and wrx are basically the same car. As far as wheelbase is concerned.
What is it about the axleback that doesnt make it fit right?
~Josh~
Old 01-24-2008, 10:44 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's the angle of the flange to the midpipe. Any competent exhaust shop can fix that for cheap. Another option is to use a split clamp that looks like 2 C-shaped pieces with a hole at each end for bolts to go through. Simply clock the clamp to the desired angle and bolt through the axleback, using the original flange to pull things tight.
I ran one on my Brighton for awhile. No difference in power, sound was slightly better, looked better too.
One of the hangers may be in a different position....but Kartboy hangers on the end is plenty to keep it from moving too much.
Jay Storm
Old 01-24-2008, 11:00 PM   #5
Sasco
Member#: 70237
1998 Impreza L
Glacier White
~Josh~
Two of the exhaust hangers fit fine, the third isn't in the right place and will not reach. No big deal. But the pipe on the WRX axleback is larger than the L axleback. Didn't measure them so I don't know the exact sizes. The holes on the WRX axleback were farther apart than the old one so they didn't line up right, and also it was a bit ****-eyed. It looked like this
So basically i need some sort of converter pipe or something. Completely lost here as I know almost nothing about exhausts..
Old 01-24-2008, 11:17 PM   #6
Sasco
Member#: 70237
1998 Impreza L
Glacier White
Jay Storm
Got a picture of the split clamps so I can visualize better ?
Old 01-25-2008, 02:02 AM   #7
Sasco
Member#: 70237
1998 Impreza L
Glacier White
bump :O
Old 01-25-2008, 05:23 PM   #8
Sasco
Member#: 70237
1998 Impreza L
Glacier White
bump >:O
Old 01-25-2008, 06:53 PM   #9
Skateboardpro
Member#: 45346
1993 Impreza L
Satin Black
we rigged one up to a 93 1.8L, we just took a drill to the flange and modified the WRX flange holes to match up with the 1.8's... fit fine everywhere else..
you can see the 1.8 in the middle here
here's a simple side shot.. sorry i can't get under there right now and take a better pic for you, but it really was simple with a drill and big bit.
Skateboardpro is offline   Reply With Quote
Old 01-25-2008, 08:08 PM   #10
Sasco
Member#: 70237
1998 Impreza L
Glacier White
The larger diameter of the exhaust flange didn't cause an issue? Did you get the angle of the flange adjusted?
Old 01-26-2008, 02:38 AM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Take it to an exhaust shop and have them make it fit. Costs $40-80 at most.
You can either have the modify the midpipe to fit, modify the muffler, or have them make a whole new midpipe (best option) to fit.
WRX axleback on my OBS...SPT or STi instead? kaisersouse Normally Aspirated Powertrain 8 07-21-2009 02:14 PM
wrx axleback on sti? RexisMe Newbies & FAQs 1 07-22-2007 12:30 PM
Install 04 WRX axleback on 06 2.5i? cstyker1111 Newbies & FAQs 3 05-03-2006 05:16 PM
WRX axleback on GC8 atmosphere Normally Aspirated Powertrain 5 07-26-2004 02:17 PM
