Old 01-25-2008, 12:00 AM   #1
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Default Piston Slap with 2.5's...how many have it?
I know this subject has been mentioned, because I have done some searching, but I'd like to see just how common this is. Specifically, how many miles when it was noticed, how long it lasts (10 to 15 minutes is common), and what was done about it. Or if you just live with it.
I believe it is more common on N/A engines, correct me if I'm wrong.
In my case (05 Baja 5 speed) it started at about 10000 miles, and when the temps dropped to around 10 to -10 it was almost constant unless I drove for an hour or so. After a complaint at the dealership, and an e-mail directly to Subaru of America, I left my car overnight at the dealership for a mechanic to listen to cold. Subaru replaced two pistons (drivers side) and all four sets of rings at 24000 miles. At about 32000 miles it slowly started to come back, now at 48000 miles and recent temps of -6 to 35 above it is almost as bad. I have installed a block heater which does help slightly, but it is still very noticeable for the first 15 to 30 minutes of driving. When the temp is 0 or below, it takes at least 30 minutes or more to really quiet down, but it can still be heard when idling.
So, anyone else with the slap ?
Buck
Buck Rogers is offline   Reply With Quote
Old 01-25-2008, 12:26 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Are you saying its a constant slap, not an occasional knock?
Old 01-25-2008, 12:37 AM   #3
PROWL
Member#: 162353
'04 WRX Wagon
Yeah I've got piston slap too, especially at colder temps like yourself.
From what I've read it's pretty widespread, and with the engine configuration being flat doesn't help in the matter.
PROWL is offline   Reply With Quote
Old 01-25-2008, 12:58 AM   #4
Skateboardpro
Member#: 45346
1993 Impreza L
Satin Black
at least 10-15minutes of driving from a cold start will make it go away.. I just take it easy when it's warming up
Skateboardpro is offline   Reply With Quote
Old 01-25-2008, 08:25 AM   #5
ScottyB
Member#: 155883
2005 Impreza 2.5RS
bacon rage
i have it when it goes below freezing. if i can keep the revs below 2500 and light throttle i can't hear it. as soon as i use heavy throttle or go above 2500 i can hear it up past 3500 or so. as a rule i never romp on the car when cold so i don't have trouble keeping the car from slapping.
it only takes about 10 minutes to go away and my car still makes great power and uses no oil so i'm not too concerned. if it got significantly worse i'd take it to the dealer.
ScottyB is offline   Reply With Quote
Old 01-25-2008, 12:29 PM   #6
imprexaRS03
Member#: 145883
2008 wrx
psm
i know the flat 4 makes some strange noices when its cold.including a lil knocking ,especially when i start up my car
imprexaRS03 is offline   Reply With Quote
Old 01-25-2008, 01:50 PM   #7
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
It is constant when the car is first started and lasts until the car has been driven for about an hour (not noticeable above 3000 rpms) after an hour of driving it is normal sounding unless the car is idling, then it is a very low knocking noise. I don't think it does any real damage, as the car has plenty of power and doesn't use any oil. In the summer the noise goes away in about 10 to 15 minutes. The purpose of this post is to see how common it is and what, if anything was done to quiet it down.
Old 01-25-2008, 02:16 PM   #8
03wrx05rscouple
Member#: 154106
yes 03wrx, 05rs
psm wrx, cgm rs
i too have the same problem both in my 03 wrx and the 05 rs and my friends that have subies all have that same problem so i have never stressed over it.
03wrx05rscouple is offline   Reply With Quote
Old 01-25-2008, 07:18 PM   #9
GrundleJuice
Member#: 165749
i have an 07 with 8K miles, and its in a warm/humid climate (central Florida) i have heard nothing at all yet. had about a week of cold days/nights (45F day/30F night) and it seemed the same as ever. I may not have enough miles to be at risk, so maybe im no help at all!
Old 01-25-2008, 08:09 PM   #10
cmiovino
Member#: 134005
2004 WRX Premium
I can here my 2.2 do it... happens in the morning, first time driving for the day. After warming up, it goes away mostly. It's still very faint though even when warm. On my rip home, it always goes away and stays away. This is near zero degree temps. In the summer and fall, I don't really hear it all.
Old 01-25-2008, 08:25 PM   #11
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Our '99 Forester had it light at 60K, slowly lasting longer after warm-up until now (112K) it can be heard lightly at all times, more under load. Of course now in the cold it sounds catastrophic at start-up, but subdues to normal after full warm-up. Power is unchanged (not much, it's auto) and it does not burn oil. We would love to replace it with a 2009 Forester. It has otherwise been a very sturdy car.
surowrxa is offline   Reply With Quote
Old 01-25-2008, 08:57 PM   #12
bullworm562
Member#: 166091
1998 Outback Limited
Green
what exactly does piston slap sound like? because i prolly have it too but i dont know what to listen for.
bullworm562 is offline   Reply With Quote
Old 01-25-2008, 09:56 PM   #13
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
From inside the car, on the drivers side, a metallic clack/knocking sound, very noticeable when starting the vehicle after a cold night. As the engine revs increase it will not be as loud, and as the engine warms and the pistons expand (10 to 20 minutes) it fades to a light knock only heard from inside the car.
Other than the noise the Suby has been one of the best cars I have owned
Old 01-26-2008, 03:16 AM   #14
kimoman
Member#: 97476
2006 Impreza 2.5i
Aspen white
I have it on my 04 wrx. Started at around 35k car currently has 58k. No loss in power. Goes away after 10 min. On my 06 2.5i nothing yet about 17k mi.
kimoman is offline   Reply With Quote
Old 01-26-2008, 06:26 AM   #15
wanbol
Member#: 167353
2004 Legacy (BL9)
Does anyone have a sound clip to be more specific? I might have it on my 2.5 too...
wanbol is offline   Reply With Quote
Old 01-26-2008, 04:12 PM   #16
nardvark
Member#: 145108
2002 Impreza TS
I have a minor case of this (I think). When it's started for the first time for the day, it takes maybe ~5 minutes for this to go away. For me it's more of a heavy vibration than a metallic sound. To be honest, the plastic on the door resonating and buzzing makes more noise than the engine itself. It is most noticeable at idle, and by the time I get out of my neighborhood and past a stoplight or two, it's gone until the engine is cold again.
Can't tell you an exact mileage of when it started, because I got it used with about 70k on it.
nardvark is offline   Reply With Quote
Old 01-26-2008, 04:30 PM   #17
lamaale
Member#: 143718
2005 WRXwagon
Got it too, my subi dealer replaced the piston number 2 and 4 as well as the rings under warranty...
lamaale is offline   Reply With Quote
CP Pistons clatter/slap. How many have it? kakarotoni Built Motor Discussion 29 03-25-2010 01:33 PM
how many have build race cars? how long did it take? spazegun2213 Motorsports 46 09-13-2006 09:12 AM
Those with GT35 kits: how many have coated or wrapped piping syoung0298 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-24-2005 12:26 PM
How many People run with cats and how many have 0 cats? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-04-2004 07:03 PM
cobb stage 2 owners, how many have lost boost with headers? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-08-2004 03:29 AM
